Yeah, Colleen's son. My name's Lewis. Thanks for the welcome! It would be nice to set up an account with OVT. Funny that both of our car's were our parents previously...Can't wait to see what it looks like with the new set of tires on it.
Well, it looks the same as always because I just had them put on the Tethys...
The tires ROCK!!! SOO much better than the Hankook Ventus V12 EVO tires, even when they were new. I guess that's to be expected when you slap down 1.5 times the money for tires - sadly, it doesn't always work out that way. Luckily, in this circumstance, it did work out that way. They have so much grip, wet or dry, it's amazing. The car feels sloppy now, needs stiffer springs/shocks/struts...
Then again, I knew that already, it's just that much more obvious when you're booking it around a corner and come across some bumps. I also need to finish rolling the left rear fender. For some reason the top of the fender opening was not rolled and it scrapes the tire lightly when hitting larger bumps.
-I just opened up registration on OVT for a little bit, so you can go there and sign up on the forums as if there wasn't anything wrong.
I'll be locking down the registration in a bit because I get soooo many spam accounts signed up a day.
-Regarding DEQ... MY CAR PASSED!!!!! By a HAIR. Granted, it doesn't matter as I'm not due for another year and I will have something more aggressive in there then. It'll be E85 to the rescue at that point, unless I get a larger catalytic converter. The Hydrocarbons were 210 of 220 allowed.... Haha. That's with a stock fuel computer, 1000rpm idle speed, H cam advanced a tooth(camshaft is ~.047" closer to the crank, so, supposedly ~4-5* retarded in "straight up" position, and advancing a tooth is ~8*, if I remember correctly), valve clearances set loose (.019" intakes/.020" exhausts). I would expect to have less issue passing on a stock or better done/smaller valved cylinder head. Especially with a larger catalytic converter than the small, 200 cell spun, high flow Magnaflow cat on there now.
-I hate that I wrecked my car. I hate that the body shop repairs aren't as good as I would like. I hate that my car is rusting now. I HATE IT! Don't mess your car up, it'll never be the same.
-I bought a beige/brown '87 244 for daily driving duty so I can not feel "bad" about making this car a little less grandma friendly. Not that it isn't, or won't be, but still.
Plans for the engine this year are put the K13 camshaft back in and get a 16V throttle body grafted on the front of a b21F manifold to get rid of the massive restriction of a b230F manifold.
I really want a larger camshaft(the K13 is barely larger than the H, it turns out, and was basically a waste of money), but the cylinder head is not as good as once thought and I'll have to get a different one from Sweden for my goals. There's some flow separation at .035" lift and the flow numbers are all wrong in general because there likely was an air leak on the flow bench setup that was ballooning the flow numbers, especially at low lifts. Once I get that camshaft with 14mm of intake lift and 290+ duration at ~.020", I'll also need to either get a new header or redo the secondary pipes with something a good bit larger. The header on the car now is barely large enough for a stock engine, let alone mine as it is now. It's not worth it to modify it to match the setup this year though, only to have to redo it again later on when I'm actually running the head/cam that I want to. Once the b21F manifold is modified though, I at least won't have to bother with the intake manifold again.
I also need to get a working wideband o2 sensor in the car again so I can tune the fuel chip. With recent developments and minor changes here and there, it's running 14.0-14.1 AFRs at WOT again... No good!
