Turbobricks Forums
-   performance & modifications (https://forums.turbobricks.com/forumdisplay.php?f=13)
-   -   240: B21FT Oil Filter Pipe Removal (https://forums.turbobricks.com/showthread.php?t=349211)
dbarton 05-12-2019 07:15 PM
1 Attachment(s)
I have plans for a different style oil cooler and remote filter setup and I want to replace this threaded pipe with a shorter one. I thought it would simply turn and spin out, but it's REALLY TIGHT and now I'm wondering if it's pressed in.
B21FT.
Who knows for sure?
Thanks, Dave
hiperfauto 05-12-2019 07:28 PM
It's screwed tight into the block. Get another nut ("-16) and tighten them up against each other really tight and use the inside nut to remove the stud.
http://hiperformanceautoservice.com/...pterNipple.jpg
Redwood Chair 05-12-2019 07:30 PM
Get two 3/4x16 grade 8 nuts at the hardware store, counter tighten them real snug and use the inner one to turn it out.
They're not usually too tight from the factory, but on a rebuilt engine they can be set in there pretty hard.
sbabbs 05-12-2019 08:26 PM
Pipe wrench if it's real tight is the only way I've gotten them out.
122power 05-12-2019 11:58 PM
Used two nuts here.
Wren 05-13-2019 12:45 AM
Another double nutter here.
dbarton 05-13-2019 10:35 AM
Thanks. I'll try this today.
Dave
dbarton 05-13-2019 12:30 PM
Before I tried the jam-nut method, I put a small monkey wrench in there and sure enough, it turned right away. Pretty sure I probably used that method 20 years ago when doing my stroker motor. Senility setting in.
Thanks, Dave
