Hey guys, I picked up this 1980 "264" but it has a b21 in it, from what I have read that year it was an option(?).
Anyways the car hasn't ran, in what I can tell, years. While first trying to start it I found it had a dead battery, so charged that up and I found it cranks but doesn't even try to start.
I pull cylinder 1 plug and ground the threads and found I was getting no spark. Next I went to the coil and tested the wire off that, turned it over and no spark.
So I replaced the coil, plugs, wires, cap, and rotor, all good quality parts(Bosch and NGK).
Tried to fire it up again, nothing.
I pull the oil cap and find that the top end is still moving while I crank it, so timing belt is good.
I pulled the fuel pump relay out and found one corner had gotten a little warm at some point. I took off the casing and was able to get the pump to audibly run. I then replaced the fuel pump relay thinking that was the problem, this time I pulled the injector and found I'm getting no spray.
Pulled a plug I'm still not getting spark with the new ignition parts.
I'm starting to think the ICM(which mine is on the passenger side attached to the washer tank) maybe toast? But I can't seem to find anywhere that's says that also has play in to the fuel system.
I can't seem to find much on these early cars so any help would be great
