Turbobricks Forums
-   maintenance & nonperformance (https://forums.turbobricks.com/forumdisplay.php?f=12)
-   -   96 850 T5 misfire when warm - Urgent (https://forums.turbobricks.com/showthread.php?t=286470)
boosticus 10-24-2013 08:47 AM
Hi, symptoms are as follows:
- Car is fine when cold, runs normally, albeit poor MPG
- Car is fine after even 15 - 20 minutes after starting from cold however shortly after this there is a misfire that seems to disappear under hard acceleration.
average mpg is down from about 23 normally to 13/14. It appears to be over fueling, replaced the plugs today and the old ones that are about a year old were badly fouled with sooty deposits.
Does anyone have any ideas what the problem is? There are no codes to be read.
Compression is also good- was tested 4 or 5 months ago for an unrelated issue.
grnmachine02 10-24-2013 09:27 AM
Do you have access to something that can read sensor values? Friend of mine had similar symptoms and his coolant temp sensor was reading in the negative numbers.
TrickMick 10-24-2013 09:37 AM
^^^^^...have done several *nasty* temp sensors for just the
"symptomology" your car is exhibiting...can't hurt to have a looksee!
mtd240 10-24-2013 10:18 AM
Relevant thread:
http://www.matthewsvolvosite.com/for...hp?f=1&t=50124
boosticus 10-24-2013 10:33 AM
So coolant temperature sensor is likely to be the issue.. Not sure if relevant but in-car temperature gauge appears to act normally? + Seems to start up OK when warm
grnmachine02 10-24-2013 10:45 AM
I'm not 100% on this so make sure you double check before you start shotgunning parts at the car. Some models actually had 2 sensors. One was for the gauge, and the other actually sent the signal to the ECM. I don't know if this applies to the 850 or not however.
TrickMick 10-24-2013 11:07 AM
I believe that this is a "twofer"...signal from ECU informs the cluster and
processes the info for the fuel management at the same time...
CHECK THE CONNECTOR carefully before you get $pendy....
Janspeed 10-24-2013 03:32 PM
never trust Volvo temp gauges. They seem to be designed to stay dead in the middle except when the engine is either ice-cold or red-friggin-cookin'-hot.
Apperantly it's a feature so the gauge doesn't freak out the driver when the engine gets a bit hotter under heavy load.
