Old 12-03-2008, 01:29 PM   #1
belldar
belldar's Avatar
Default one more noob thread about resistor packs
i searched for resistor pack and found a beautiful diagram of the resistor pack retrofit, im a little confussed as to the wiring. where is the best place to get the 12v for the grey wire? and do i just piggyback the greens to the existing fuel injector wiring? OR do i now use the green wires as the power for the injectors. thanks in advance. oh and its a 92 244
belldar is offline   Reply With Quote
Old 12-03-2008, 01:45 PM   #2
740ATL
Guest
You'll need to remove your intake manifold and pull it back from the head. This exposes the bundle of wires below where the injector wiring combines. On a late model 240, the 12v positive wire is orange... and just about near the oil separator, that large orange wire branches out to 4 orange wires for the injectors. You need to cut this wire and splice in your resistor pack. On the resistor pack, you connect your large green-red wire to the large orange, then the four green wires to the four orange wires.
The other option is to ditch the resistor pack and use high impedance, high flow injectors... like those found on 850turbo cars, or supercharged ford thunderbirds. bosch 785 or 756 respectively.
Mike
Old 12-03-2008, 01:54 PM   #3
belldar
belldar's Avatar
thanks mike thats alot of help, will there be a problem running the 850turbo injectors without the increased boost?
Old 12-03-2008, 02:02 PM   #4
740ATL
Guest
Shouldn't be. The 850T injectors flow the same as the low impedance "greentops" found on 740/940turbo vehicles.
Old 12-03-2008, 02:30 PM   #5
belldar
belldar's Avatar
are the browntops better than the 850 turbo injectors, they are the same price 34.95 each
Old 12-03-2008, 02:56 PM   #6
740ATL
Guest
They flow a bit more, but they are low impedance.
Old 12-03-2008, 03:10 PM   #7
SlowRide
Bearded Road Rager
SlowRide's Avatar
Go with the 850T injectors and forget about the resistor pack wiring, it's what I am going to do when and if I +T.
Good luck!
-Justin
SlowRide is offline   Reply With Quote
Old 12-04-2008, 12:45 PM   #8
belldar
belldar's Avatar
thanks for all the help guys, just picked up some 850t injectors at the junk \yard, im gona clean them and then throw them in the car. 21 bucks for 10
