#76 |
6082 was the only grade listed that my supplier could give me for U channel and plate
6082 welds real good and is a strong alloy incase it gets a belt from grounding the sump |
#77 |
Its also nice and strong after the heat cycle of welding
#78 |
Yayayaya, hohohooo!!!
Wow...that thing is going to be a BLAST to drive. In a tiny little Caterham 7? Talk about FUN!!!!!!!!
Sean Williams '94 850 Turbo Wagon (daily) :: 14.0 @ 98.5 B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend '75 244GL (project) :: 8.4 @ 85.6 B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar) CLICK HERE for the 244 BUILD THREAD! BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details! |
#79 |
Icey Brick Boyz
![]() Join Date: Jul 2002
that sums it up nicely, thanks
costs less and machines better? I can understand why its so common in europe.
#80 |
For those who are into turbo's this was the engine that I was going to put back in the car before I decided it was too much power for the car
Focus SVT turbo motor, destroked to 1858cc with every mod possible running a GT35 ![]() |
#81 |
It's a match!!
![]() Join Date: Dec 2006
#82 |
Adopt me.
#83 |
#84 |
Owner: DeathWagon
![]() Join Date: Jul 2005
whats the injector on the top of the valve cover with the two hoses for?
-Sam
God Created turbo lag to give V8's a chance.. 95 Nissan 240SX swapped 2JZ 9.8@151mph 870+whp? 08 Nissan Frontier 6speed 14.5@92mph <-tow bi*ch.. 91 Volvo 244 GL 11.9@111 "old" ......... 90 245GL "new project" Kennys 1990 740 GL Volvo Saved my life 5-13-2010 . . Heebing stuff up since 1980..
#85 |
#86 |
lapping scottyd
Won't it burn out with no fluid to cool it?
#87 |
No its an air injector
The works Ford World Rally Cars have been using them for years If its good enough for a works team is good enough for me Last edited by AustenW; 11-06-2009 at 05:00 PM.. |
#88 |
muhahhahaahhhaaa
hoegaarden mmmmmmmmmmmmm. looks good austen .
![]() muhahhahahhhahhaha !!!!!!!!!!!!!!!!! |
#89 |
#90 |
After reading the racecar engineering article I came away convinced the volvo 5 banger (whitebolck for that matter) architecture is the wrong starting point for a 300 hp n.a. engine.
why not, for instance, a honda k24? compact, light, spins like mad, and comparatively cheap. This is the second k24 dyno I looked at, a very easily achieved 280 hp: http://www.honda-tech.com/showthread.php?t=2623974 I love Volvos, have owned many and will own more of them, think they are a bargain, praise be and all that. But I personally would move to a more modern architecture. Which, begs a question, respectfully: Why the na volvo motor? Last edited by olivet5r; 11-06-2009 at 10:50 PM.. |
#91 |
Wants u 2 use your brain.
It sounds better.
#92 |
Derby Widow
#93 |
#94 |
Its an all alloy engine and it has the right stroke to make upto 10k rpm (77mm stroke)
Rod ratio is also very good at 2:1 Steel crank as standard 20 valves as apposed to 16v And the 5 cyl sounds awsome IMO And no one has tried to do a high power Nasp 5cyl for the road that I know of so I though I'd be different |
#95 | |
Jackstand Queen
![]() Join Date: Sep 2002
I suppose they have shorter cranks than the sixes which helps, but I dunno how the firing order etc affect things. Should be interesting! |
#96 |
I'm using a Rattler crank dampener and having the full assembly dynamically balanced at vibration free here in the UK
They balance F1 engines and originally did the balancing for TWR for the volvo touring car engines |
#97 |
#98 |
You make it seem like your major focus was 300hp naturally aspirated. It that's the case then maybe u should go with the honda k series... just my opinion anyway. IF you're prejudice against honda, you can make that power with a Ford Duratec.
#99 | ||
BEWARE OF PORTLAND TRIPLE
You COULD. Volvo's aren't for everyone. Go back to Hondalandia.
XBL:yeliwmots |
#100 | |
That said...so long as you can find a decent set of cams for the whiteblock, 300 n/a should be a relative cakewalk. The engine has enough going for it in terms of displacement and valves. It certainly won't be cheap - I'd HATE to see the price tag of custom cams and full headwork with O/S valves - but it would be easily possible if you had the money to invest in it. ...does anyone even make off the shelf "sport" cams for the whiteblocks? I've never even bothered looking. |
| Thread Tools | |
| Display Modes | |
