#101 |
guess
1994 944 bf230t - custom open intake, 15g @ 15PSI With dual stage Electronic boost controller, IPD Turbo Cam & gear, IPD performance Wires, Mike's chips, 24X12X3 ebay IC.Coming soon: new turbo!!! 3 inch turbo back, 44lb/hr injectors, Lots of suspension stuff Project Thread
#102 |
HAHA! Hey Gonz, I'll let you have a rematch on Dec 5th! ;)
Sean Williams ...joined the dark side... '94 850 Turbo Sportwagon!!1juan!!11! ![]() '90 VW Corrado G60 - The Track Wh0re! ![]() WWJND? http://www.youtube.com/watch?v=zOfjkl-3SNE |
#103 |
Power UP!!!!!
this ought to be interesting. I am still flat out amazed you pulled a 13.9 quarter on a 13C 940 at 100mph. Thats very impressive. I guess you had a VERY healthy motor.
PJ
84 242Ti 16V build up 83 245Ti daily driver lots of common mods 1992 745Ti stock 16V Block mounted LH2.2 distributors for 16V conversions on 240's, now for sale, just click this link Pics Of the 242 and other stuff http://www.pbase.com/fast242 |
#104 | |
Other than that...mod for mod, 13.9 @ 100 @ 18psi w/ 110 oct., stock tires, full weight. The 110 is worth a lot. |
#105 | |
fender rubber
I couldnt believe how worn down the brushes were, i was basically driving off of my battery ![]()
Welcome to Camp TB, Here is your bag of Zipties 93 245 +Ti 15g, M46 w/ lh2.2 flywheel turned into lh2.4 , Lostart chips, IPD 25/23 sways, 16" Borbets E types, 3" Maf, 42lb. Brown Tops, RX7 Oil Cooler, G80
#106 |
I've gone through voltage regs before in a couple other cars. Always made me happy to see that's what the problem was because it's cheaper and easier than an alternator.
You all better be planning to hit the drags on the 5th, it's our last chance for EvW '09 entries! |
#107 |
DUUUDE i need to check this section more often..guess Igot used to only Norcal having meets so stoped checking.
.I'd like to meet some of you brickers..I'm local , Fountain Valley..next time...
Things my '85 244 Swede needs(respectively): -Poly/rubber fnt bushings (thanks Cameron -Black floor trays(mainly pass.)(thanks 242ti) -Ball j's -Frunt sprangs(drops?) -RearTABushings -Green fog light switch and relay -Black Carpet under drvr/pass feet(front) -finally...... a paint job. |
#108 | |
fender rubber
I should be fine, Im not sure i'll have the clutch in by then but if people want to help lets say in a week or more then Im more then willing, I just need to get the flywheel done |
#109 |
Have you called them about the flywheel yet? Their turnaround is only a couple days. I'm sure we can get the labor part handled.
#110 |
fender rubber
#111 |
#112 |
Got Boost?
| Thread Tools | |
| Display Modes | |
