#601 | |
1993 volvo 960- work hauler, sh** tranny 1993 Notch Back Mustang-2.3 turbo,MS2 P'n'P, Holset HX35, boport stage 3 cam and head(going on soon),gutted & ported intake, stinger mani, blah blah blah. 82 242t/converse conversion:306 HCI+T)omg its taking forever... |
#602 |
the real Towery
#603 |
Turbo, what?
From replacing the cable with a good, new one, or from changing something else?
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 b230 Chumpcar - Oregon Volvo Tuners? - For Sale? |
#604 | |
Fair Enough...
R-Sport International Customer Service For all RSI related messages, please email me (no PM)... Thanks! ben@r-sport.org |
#605 |
Turbo, what?
You can put a small hose clamp behind the adjuster(make sure you screw it all the way in, obviously, it's a tapered fit so that needs to be as tight as possible to lock it in place, I use big pliers to tighten mine) and tighten it down on the metal casing to keep things from moving.
#606 |
the real Towery
Old clevis pin and new. Nice wear pattern, eh? I need to inspect the pedal and swap it out if it's got an oval shaped hole in it now. The end of the old cable was slight ovaled. I removed the original (broken) clutch cable and installed a brand new Volvo brand Made in Germany cable with the metal outer sheathing. Far superior to the aftermarket cable.
![]() ![]() Those three little hose clamps in a row are around a piece of hose cut lengthwise. The sheathing will want to rotate and go towards the back of the car, so this hopefully stops it from rotating. I adjust the cable until there's not much free play at the fork when I pull it back (pulling the cable out). Maybe 1/4". I used to have to get in and try it out first, but now I just set it and forget it. The pedal feels firm until right near the end of the travel near the floor where it gets a little easier. Like pulling back on a bow. ![]() The other side features a washer with a slot cut in the side to slip over the cable. Works great, but I found out my new OEM replacement came in today, so I'll replace this when I do the T5 swap. ![]() |
#607 |
Looks great Mike!!! Let us know how those calipers work out for you.
http://www.pbase.com/242ti/root |
#608 |
Turbo, what?
Ok, so just by replacing worn stuff, not doing anything custom, per say.
#609 |
the real Towery
#610 |
Got Boost?
#611 |
the real Towery
#612 |
the real Towery
Oil temp. The wire always fell off when it was on the bottom, plus it gets cracked/broken on a low car. So when we did the motor, I requested the addition of a 3/4-16 nut on the side so I never have to remove the temp sender drain plug.
#613 |
You're a Subtotal
Best sounding +t at carlisle.
Greg '74 142 '05 LGT Wagon '13 TDI Sportwagen '03 Tacoma |
#614 |
#615 |
the real Towery
#616 |
Rolling...
Well, the engine's not a +T but the car is a +FT...
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe |
#617 |
JohnMc=500Dollar Mistake
![]() Join Date: Jan 2006
paul is weak at terminology.
Judging from the parts, it's a b23-f+ET best sounding b23ET on the showfield |
#618 |
You're a Subtotal
nerds
#619 |
the real Towery
B23F block, B21F rods, B21F crank, B23ET pistons, 531 Penta head.
the_engine_with_no_name |
#620 |
†500DollarSparkMap
![]() Join Date: Jan 2009
yeap, and it does sound good. send the head off yet to kenny? you know you wanna get it hogged out by heeb'.
Matthew 10:28 And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell. ![]() |
#621 |
advocate of k-jet
the only b23et at the show
#622 |
#623 | |
BEWARE OF PORTLAND TRIPLE
#624 | |
![]() Join Date: Jul 2002
lol wow 275 50... thats a lot of sidewall. those are taller then my 305 30 18s |
#625 |
still rides with MrDoug
![]() Join Date: Feb 2007
good job Towery, that time is great especially for what the competition was running.
-Matt 1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes. 1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s. 1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p. the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k. |
| Thread Tools | |
| Display Modes | |
