#1 |
As i prep for the installation of the replacement trans, i wanted to add some better cooling. Here are some coolers i was looking at, and i wondered if it was possible to go to big or too cool.
Note that summers here can stay 90-100f for weeks a time. http://www.amazon.com/70268-SuperCoo...1233440&sr=1-1 http://www.amazon.com/Hayden-Automot...1233440&sr=1-3 http://www.amazon.com/Hayden-Automot...233440&sr=1-12
1978 242DL - 1995 855 T5 ARD Green - 1992 Volvo 745
#2 |
What kind of trans/fluid temps are you seeing that lead you to conclude you need a cooler?
'82 242 5.0L; '08 Cooper Clubman; '00 Accord (M.I.L.'s 42k mile car) |
#3 |
I kept cooking my oil then the trans went kablam! I drive hard and want to keep this next trans as long as I can.
#4 |
I think I may be confusing "T5" -- as in the model 850 you have (auto tranny?) with a "T5" manual trans that is often swapped into the rwd bricks. Which tranny in which car are you talking about?
#5 |
#6 |
Since 1987
Yep that's funny that the general assumption, when hearing "T5" is a NON VOLVO part....
I made that same assumption when I opened this thread.
#7 |
I didn't think cooling a manual was even a thing, didn't cross my mind that it would get confuzzled
#8 | |
doing something stupid
i would think, as big as you can fit, would be the ideal answer
88 244 - m47 - on the bumpstops - 366k on the clock 83 245t - m46 - the green monster - 130k - 260whp/280tq with a lot on the table 94 z28 - t56 - pull me over red - 100k Quote:
#9 |
That was my mind set before i thought bout fluid restriction and possibly running it too cool. i figured maybe i can cover part of it when the weather is cool kinda like what they do on big rigs in the winter.
#10 | |
if the cooler works too well, add a thermostat, just like what is done to oil coolers |
#11 |
i figured you would be limited on size to begin with, you prolly can't easily fit one that's "too big"
but that's just a guess |
#12 |
#13 |
I decided to go with http://www.amazon.com/gp/product/B00...00_i00_details
Here it is after some tinkering this weekend. I still need to do the bottom bracket and then cut and paint them so they don't stick out so much. Also, i need to find a new home for that other horn. ![]() ![]() Last edited by vivalavolvo; 03-19-2012 at 09:16 AM.. |
#14 |
Well, it works well unless its under 55F then the trans needs to warm up other wise it stumbles and the arrow will flicker and if i don't take it easy goes to full on flash. Once warmed up tho it works great, trans even locks the the TC, and that requires a minimum temp to do. I guess ill get on installing a thermostat or some sort of way to dampen the cooling effect on chilly mornings.
| Thread Tools | |
| Display Modes | |
