Old 10-12-2004, 11:59 AM   #1
boostdemon
creative mastermind
boostdemon's Avatar
Exclamation FAQ: Links to commonly discussed topics (PLEASE READ)
Some of the better threads for reading that get asked over and over again so you can catch up and maybe ask something new about the topic. I have noted what my exact search terms were and basically just grabbed some of the longer ones.
Feel free to add to the list
Transmission/Gear Ratio discussions
  1. T5/Getrag/M46/M90 comparions - http://forums.turbobricks.com/showthread.php?t=104624
16v conversion topics: (searched "16v" in the subject line only)
  1. 16v Turbo FAQ - http://forums.turbobricks.com/showthread.php?t=31900
  2. 16v DOHC vs. 8v SOHC - http://forums.turbobricks.com/showthread.php?t=2794
  3. 16v questions - http://forums.turbobricks.com/showthread.php?t=4748
  4. 16V tuned length turbo header available - http://forums.turbobricks.com/showthread.php?t=1518
  5. B234 16V - http://forums.turbobricks.com/showthread.php?t=3027
  6. Loads of Volvo 16v Info - http://forums.turbobricks.com/showthread.php?t=16750
  7. Valve Reliefs info request - http://forums.turbobricks.com/showthread.php?t=12163
  8. 16v Motor Build Up - http://forums.turbobricks.com/showthread.php?t=21873
  9. 16v Turbo Pictures - http://forums.turbobricks.com/showthread.php?t=26256
  10. 242GT 16v progress - http://forums.turbobricks.com/showthread.php?t=25259
  11. i think i found the cheapest 16v tensioner! - http://forums.turbobricks.com/showthread.php?t=19356
  12. ovlov.net DOHC on b230 tensioner/belt kit! - http://forums.turbobricks.com/showthread.php?t=6038
  13. 16V valve reliefs http://forums.turbobricks.com/showthread.php?p=1708755
Heads/porting/design/etc.. (searched for "head" or "531" or "405" in the subject line only)
  1. 160 vs P&P 398 vs 405 pics - http://forums.turbobricks.com/showthread.php?t=3670
  2. 531 head question - http://forums.turbobricks.com/showthread.php?t=22742
  3. Modified cylinder head - http://forums.turbobricks.com/showthread.php?t=16935
  4. HP Gain of the 531? - http://forums.turbobricks.com/showthread.php?t=18246
  5. What were the reasonings for 530 beating 531? - http://forums.turbobricks.com/showthread.php?t=8523
  6. can I use a 405 head? - http://forums.turbobricks.com/showthread.php?t=5413
Blocks/stroke/penta/etc.. (searched for "block" or "penta" in the subject line only)
  1. Update on B23 Stroker Engine - http://forums.turbobricks.com/showthread.php?t=20579
  2. Penta FAQ - http://forums.turbobricks.com/showthread.php?t=24675
  3. Old question rehashed: Maximum bore - http://forums.turbobricks.com/showthread.php?t=25961
  4. is short stroke/high rpm worth it? - http://forums.turbobricks.com/showthread.php?t=23427
Cam questions (A/B/K/VX3/V15/etc) (searched for "cam" in the subject line only)
  1. M cam vs. B cam vs. K cam - http://forums.turbobricks.com/showthread.php?t=1392
  2. Additional M vs. K cam testing - http://forums.turbobricks.com/showthread.php?t=1427
  3. Reveiw of VX Cam, IPD 2.25" exhaust (N/A) - http://forums.turbobricks.com/showthread.php?t=23522
  4. IPD turbo cam versus VX - http://forums.turbobricks.com/showthread.php?t=19799
  5. New Adjustable Cam Gear - a fine-tuning advantage - http://forums.turbobricks.com/showthread.php?t=1575
Blow-Off Valves (BOV) (searched for "BOV" or "Blow" in the subject line only)
  1. BOV on b21ft w/ T3 - http://forums.turbobricks.com/showthread.php?t=1537
  2. Blow off Valve on an 240 turbo 83 - http://forums.turbobricks.com/showthread.php?t=11141
  3. LH 2.4 ECU info, BOV work or not? fuel cut @ what voltage? - http://forums.turbobricks.com/showthread.php?t=16099
  4. How bad is the rich spike if I put a BOV on my 740? - http://forums.turbobricks.com/showthread.php?t=4086
  5. DSM BOV mod for quick release and higher boost - http://forums.turbobricks.com/showthread.php?t=12105
Limited Slips/Lockers/Diferentials (searched for "LSD" or "diff" in the subject line only)
  1. Whats the weakness in the Dana 30? - http://forums.turbobricks.com/showthread.php?t=22367
  2. 90+ Locker Differential In Pre 90 1031 - http://forums.turbobricks.com/showthread.php?t=15284
"Flathood" Owners | Motorcyclists | Guitarists
boostdemon is offline   Reply With Quote
Old 10-12-2004, 06:44 PM   #2
n xntrx volvo
n xntrx volvo's Avatar
fuel system faq
making turbo headers
common abbrev for t-bricks
intercooler options
powerstoke ic fitting
v8 conversion faq
cheap upgrades
staged 700/900 upgrades
staged 200 suspension upgrades
main page for modifications
and for 16v
tensioner
deleting balence shafts
header flanges
header pipe/ prices (sch 40)
alt to header
adapting a 8v manifold
ford conversion info, mostly correct
gen info
intake issues
240 spec intake issues
part numbers
gen noob thoughts/ good gen info
parts
Place to buy diy header
place for ready made headers
manditory reading
anthony hyde
ryan wynott
ovlov site
tis all for now, i'll do up a better version of v8, 16v, and ic, when i get a chance. i'll just summerize it all into one thread like i did w/ the penta and fuel system threads(16v, will be huge).
-Aaron
my cars (click me)
I'm not here, Please leave a message after the tone........(or email me).
n xntrx volvo is offline   Reply With Quote
Old 05-14-2005, 12:51 AM   #3
sethfc
Originally Posted by Alphanumeric 244Tic
where are the T5 trans swap topics?
no idea if you will find this helpful:
http://www.v-performance.com/pr_t5swap.html
sethfc is offline   Reply With Quote
Old 05-31-2005, 02:59 PM   #4
JW240
visst
JW240's Avatar
A nice link for replacing the intermediate shaft is found here. Essential for using a B230F or B230FT etc out of a 740/940 in a 240.
240 | 1991 | 271 KKm | B230F+T | M90H | fuel:E85
Amazon/121 | 1968 | finished 2016+?
Old 11-23-2005, 09:48 AM   #5
frpe82
Guest
Cam specs: http://www.turbobricks.com/resources...ontent=camspec
Old 01-22-2006, 08:23 AM   #6
DaButcher
Do a Burnout!
DaButcher's Avatar
Tutorial: Fitting of Volvo Original Spacerkit, step by step (with pictures).
DaButcher is offline   Reply With Quote
Old 12-23-2006, 07:51 AM   #7
brucepick
brucepick's Avatar
Chinese Water Torture (a SeaFoam recipe)
http://www.turbobricks.com/forums/sh...ad.php?t=35053
brucepick is offline   Reply With Quote
Old 01-02-2007, 07:49 PM   #8
frpe82
Guest
http://forums.turbobricks.com/showthread.php?t=84817
It includes:
FAQ about chips for the LH2.2 and LH2.4 + EZK.
FAQ about LH2.2 and LH2.4 + EZK.
How to retrieve, understand and reset OBD fault-codes.
Old 01-31-2007, 01:41 AM   #9
m4ff3w
m4ff3w's Avatar
Originally Posted by fengler View Post
the link for 700 staged upgrades is dead :(
http://lonestar.utsa.edu/jtillman/volvo/fast700.htm
m4ff3w is offline   Reply With Quote
Old 07-24-2007, 04:08 PM   #10
thelostartof
unbalanced chemical
thelostartof's Avatar
AW71 FAQ of sorts
http://www.turbobricks.com/forums/sh...ad.php?t=64408
Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
thelostartof is online now   Reply With Quote
Old 11-11-2008, 10:38 AM   #11
bdimag
abandon all hope
bdimag's Avatar
*cheap* shocks/struts http://forums.turbobricks.com/showthread.php?t=75151
Brian
1991 244
2004 S60
bdimag is offline   Reply With Quote
Old 12-22-2008, 10:21 PM   #12
cuaz64
cuaz64's Avatar
Please put this Wild Card at the top of the thread to make easier the searches and avoid repost. So, works like this: You want find info about the M90 transmission using the search function, but if you write M90 as a keyword yo got a error, so you put instead M90* and you got your results.
cuaz64 is offline   Reply With Quote
Old 07-04-2009, 08:15 PM   #13
greymatter
helpful thread, found what i was looking for thanks
greymatter is offline   Reply With Quote
Old 12-12-2009, 06:16 PM   #14
Evovavailliot
Evovavailliot's Avatar
Default FAQ Links to commonly discussed topics PLEASE READ
Really new to the ATV world myself, but IMHO, the rev limiter is there to protect your engine. You will not get any additional power by over reving it, only additional broken parts, ie valve springs, valves etc. Again, just my .02
Evovavailliot is offline   Reply With Quote
Old 04-26-2010, 11:28 AM   #15
740nut
740nut's Avatar
is there any highly detailed staged upgrades for 700's around all the mentioned links are dead.
740nut is offline   Reply With Quote
Old 04-26-2010, 11:57 AM   #16
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
http://forums.turbobricks.com/showth...+modifications
Isaac
1995 940 Turbo:
Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Greddy BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 06-02-2010, 10:08 AM   #17
2fast4u
2fast4u's Avatar
Just found a build sheet. Instead of making it a sticky, I will post it in here.
http://www.scribd.com/doc/3941785/TP...B21-B23-part-1
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 07-03-2011, 08:53 AM   #18
740volvo
going to save this thread for sure thanks alot very helpful.
740volvo is offline   Reply With Quote
Old 12-21-2011, 06:17 PM   #19
g3mccotter
Got really excited seeing this info and then got bummed to see everything I was trying to look at was broken besides a 240 service manual when I have a 740. :(
g3mccotter is offline   Reply With Quote
Old 04-02-2012, 06:32 AM   #20
TestPoint
TestPoint's Avatar
Default Small Block Ford Conversion Manual
A rather extensive discussion on installing a small block Ford V8 into a 240 series can be found here:
Your experiences and ways of doing it better as well as questions are encouraged. Additional details on deviations from this engine, transmission and vehicle are also solicited.
The intent is, through contributions from forum members, to create an single source of information that I would have dearly loved to have found 3 years ago when I began this project.
Old 04-16-2012, 05:25 AM   #21
Lol-vo
Lol-vo's Avatar
any articles on here about b230 240 Camshaft installs/Timing ect?
Going to be doing a cam, and adjusting the valves, ect. Just wanna do it right, articles and pics always help me
Screw the haters, I love my bricks with wheels.
Current Volvo's:
1.) 1990 245 DL "Violet" (Beater with a heater)
2.) 1990 244 DL The new project
Other cars:
1.) 1996 Audi A4 2.8 Quattro (Hitler Mobile)
Previous Volvo's:
1.) 96 850 R (MONEY PIT!!!)
Lol-vo is offline   Reply With Quote
Old 04-16-2012, 08:49 AM   #22
Mueller
Mueller's Avatar
haynes,chiltons or bently manual cover that, not a Performance topic.
k-jet.org for manuals you can download (pdf)
Originally Posted by Fraktion View Post
You (Sicko240) and calimeatwagon should become best friends
Old 04-16-2012, 12:50 PM   #23
Lol-vo
Lol-vo's Avatar
oh, I thought since it was a performance camshaft it might be, lol, My bad
Old 08-28-2012, 12:48 AM   #24
DagazEnterprise
Great thread two important questions. I have thelostartof chips, is the computer able to compensate for timing above 20psi? The ability to retard it to compensate for boost. And second, is there a need at some point to install a MSD type ignition?
DagazEnterprise is offline   Reply With Quote
