Old 05-06-2012, 11:28 PM   #1
blue850t5
blue850t5's Avatar
Default Oil Cooler Question?
Wanting to add an oil cooler to my 850. I plan on mounting it behind the grill in front of the A/C. Here is the question; Do I mount it in series with the stock radiator cooler utilizing both or do I mount it as the sole cooler? Was planning on tapping into the existing lines from the block. Thee cooler is 4 x 11 alum. Thanks, Mark
The Fleet: 97 850T5 "Blue", 96 850R, 75 164e
blue850t5 is offline   Reply With Quote
Old 05-07-2012, 12:31 AM   #2
digital.aaron
is lower than Ken
digital.aaron's Avatar
You probably don't want to connect an oil cooler in series with your radiator. Seems like mixing oil and coolant is not a good thing to do.
digital.aaron is offline   Reply With Quote
Old 05-07-2012, 12:38 AM   #3
blue850t5
blue850t5's Avatar
Haha! The stock oil cooler utilizes the pass side radiator tank. the Drivers side was for the old auto tragic cooler.
Old 05-07-2012, 01:11 AM   #4
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Bypass the in-radiator cooler for that car. Being in Sac it never gets cold enough that you'll need to 'warm' the oil. A straight air-oil cooler will certainly run a lot cooler than the water-air cooler. It'll also take some load off the cooling system.
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 05-07-2012, 04:44 AM   #5
blue850t5
blue850t5's Avatar
Thanks Gary! I will be running it the way you suggested. Any idea on how to calculate cooler size for the application? The one I have came my way via a trade.
Old 05-07-2012, 09:58 AM   #6
Agreed, if you are going to run a separate oil cooler just bypass the factory in radiator stuff.
You might find it takes longer for your oil to come upto temp though.
Old 05-07-2012, 10:29 AM   #7
gsellstr
Vintage anti-ricer
gsellstr's Avatar
No idea really on the sizing. I just went with a decent sized one, a bit bigger than stock since I'm pushing things a lot harder than stock.
