Old 06-21-2012, 08:56 PM   #1
JR Webb
Question car mixture keeps changing
Its seems like when it's hot out it leans out down to 15% then I adjust it back and where good until I put it to the floor in 3rd hall ass come back home check it and the mixture goes down again wtf I have no vacuum leaks everything runs good until I climb a hill then on the top it starts to back fire bad any ideas?
Neal JR
JR Webb is offline   Reply With Quote
Old 06-21-2012, 09:04 PM   #2
CEHepp
FWDFTW
First things first: What?
Next: Make, model, year, fuel system, transmission/transaxle, etc?
Third: What are you using to measure the mixture?
CEHepp is offline   Reply With Quote
Old 06-21-2012, 09:19 PM   #3
JR Webb
1982 Volvo turbo intercooled/ jettronic
Old 06-21-2012, 09:20 PM   #4
JR Webb
Dwell meter
Old 06-21-2012, 09:26 PM   #5
JR Webb
Sorry 242
Old 06-21-2012, 09:28 PM   #6
JR Webb
m46 tranny it's been awhile since I've looked at it but that that should be it .
Old 06-21-2012, 09:31 PM   #7
JR Webb
Old 06-21-2012, 09:33 PM   #8
CEHepp
FWDFTW
How are you checking fuel mix with a dwell meter? How are you adjusting it?
Old 06-21-2012, 09:49 PM   #9
JR Webb
A very long Allen
Old 06-21-2012, 09:58 PM   #10
vlvman
vlvman's Avatar
Replace the injector seals and the injector holder seals. Make sure you have no vacuum leaks.
Wait...... 15 percent dwell is not leaning out that is rich. Lower dwell is rich, higher dwell is lean.
Make sure the control pressure regulator is getting good current, ie make sure the electrical connection to it is clean and tight and has battery voltage to it. What condition is the engine wiring harness in?
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 06-21-2012, 10:04 PM   #11
JR Webb
Replaced it 2 years ago wiring harness
Old 06-21-2012, 10:09 PM   #12
JR Webb
Did replace both seals last year.
Old 06-21-2012, 10:15 PM   #13
vlvman
vlvman's Avatar
Check line, control, and rest fuel pressures.
Old 06-21-2012, 10:16 PM   #14
vlvman
vlvman's Avatar
Has the car sit for a while?
Old 06-22-2012, 02:09 AM   #15
JR Webb
It did but i had the fuel system run thru new pump,filter,injector seals all of them
Old 06-22-2012, 11:11 AM   #16
JR Webb
Could my injector make my car do what it's doin?
Old 06-22-2012, 11:55 AM   #17
Fitzy
Fitzy's Avatar
Not really, your problem seems intermittent as you have stated. Check fuel pressures; line, control (when warm) and rest. There might be something up with your air meter/fuel dizzy/mixture box.
06 s60R MT
84 242 Ti 4spd - A work in progress...
Fitzy is offline   Reply With Quote
