Old 06-21-2012, 07:46 PM   #1
malloy1
malloy1's Avatar
Default '93 heater valve removed
The PO took out the heater valve that is on the engine side (vacuum line is plugged). I'm going to be replacing all the coolant hoses (including the heater hoses), and now wonder if I should install the new heater valve I bought. The AC seems to blow cold, and the heater seems to work fine. What is the use of this heater valve if there is another valve somewhere else that controls the coolant to the heater core? Will the AC be colder?
Paul
Paul
malloy1 is offline   Reply With Quote
Old 06-21-2012, 08:21 PM   #2
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
The purpose of that valve is to shut off flow to the Heater Core when you have the MAX AC setting selected (that little click at the bottom of the temp dial). The AC will blow cooler. The side effect of this is that it stops flow to that back part of the head when the valve is closed.
I am using a GM heater control valve that Gary suggested. It's a 4 port valve and allows flow through the head when the heater core flow is closed.
7/9 Updated Heater Control Valve
That being said, no harm will come from not having that valve.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Gray Car - '92 940T : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 63#/hr CFI injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 06-21-2012, 08:23 PM   #3
Clay
Clay's Avatar
I haven't had a valve in my 940 for 3 years.
Originally Posted by Sir Psycho View Post
Clay's my favorite Mom who's also a 19 year old male.
Clay is offline   Reply With Quote
Old 06-22-2012, 12:35 AM   #4
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Actually Toby, having flow thru the valve when not intended will cause a noticeable loss in performance from the AC system. The air is getting heated by a hot core just before it gets cooled. Found about a 10* difference from a partially stuck open heater valve to a sealed closed heater valve.
The 7/9 series use a blend door system for temp control, which means once you just barely move the lever off the cold side, the valve opens and coolant flows thru the core, with a door controlling the temp. Not quite like the old 240's with a valve that controls the temp.
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 06-22-2012, 10:00 PM   #5
malloy1
malloy1's Avatar
Replaced all the coolant hoses and the heater valve.
Replaced the heater valve with a new Motorcraft one (which I had), but really like that two hose GM valve. I would use the GM one next time (but I figure I have 50K or 100K before I need to change that one again).
Thanks-
Old 06-22-2012, 10:31 PM   #6
Magnum TE
Magnum TE's Avatar
LOL my AC doesn't cool more than 10deg under ambiant temp anyhow, so I've got no frame of reference.
Old 06-22-2012, 10:36 PM   #7
Clay
Clay's Avatar
The air conditioning in my 940 blows between 38-42 degrees when I'm moving. All original air conditioning.
Old 06-22-2012, 10:37 PM   #8
andysbeta
no point
andysbeta's Avatar
Yeah running without a heater valve won't hurt anything but indeed the A/C won't be as efficient without one as I've too experienced about the same difference in vent temps without vs. with.
50 degree dash vent temps are okay with the heater valve missing, but if you get a drop of 10 degrees to say 40 degrees at the dash vents, then that is getting pretty darned good and nice cold A/C indeed.
andysbeta is offline   Reply With Quote
Old 06-22-2012, 10:49 PM   #9
Clay
Clay's Avatar
That's what I run with the heater valve bypassed.
