Old 07-01-2012, 09:21 AM   #1
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
Default 97 960 vent control issues
Okay I just bought this car. It was cheap and is in pretty good condition.
The A/C works fine. HOWEVER:
The vent control doesn't work properly. I did some searching but my situation wasn't documented. It's not a vac leak from the motor I don't think.
Here's the issue. I have the rotary dial-style A/C control. I think later 760s through these 960s had a similar setup. The floor and defrost seem to always be blowing. If I select the front vents, all of them blow. If I select defrost, the front vents turn off and the defrost and floor still blow.
Any suggestions?
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 07-01-2012, 09:36 AM   #2
badvlvo
Bad for Babies
badvlvo's Avatar
Check the blend door and actuator. It could have something like a pen or some other foreign object keeping it from working.
badvlvo is offline   Reply With Quote
Old 07-01-2012, 09:42 AM   #3
15A
World's Oldest Brewery
15A's Avatar
BTDT with my 760 a few years back (its the same part - I replaced mine with a 98 V90's). Right behind the glove box and to the left is a gold "distribution block" - about 2" x4" with a colored assortment of vac lines (purple, pink, etc) coming in and out of it. Can't miss it. These are known issues over time and big $ to buy new. Find one in a yard and replace it. Very quick and easy swap.
If you can't find one, I probably still have a couple known good spares.
“I have come to the conclusion that one useless man is a disgrace, that two become a lawfirm, and that three or more become a congress.”
- John Adams
15A is offline   Reply With Quote
Old 07-01-2012, 10:31 AM   #4
MrBill
MrBill's Avatar
Dumb question:
How far back does the same gold distribution block go?
I have an 86 760 that is being replaced. It has 315k on it and I was thinking about parting it. it has the 'automatic climate control' but it isn't the rotary knob thing. I know it has colorful vac lines inside. The climate control in the 86 works fine - same distribution block?
Old 07-01-2012, 11:46 AM   #5
stove
Owner, Valhalla Volvo
stove's Avatar
88-98 ecc
Originally Posted by turbowagon View Post
Oh ok now I get it. I'll try that this weekend. That makes more sentance
1982 264 GLE (B23[4]fTi)
stove is offline   Reply With Quote
Old 07-01-2012, 12:33 PM   #6
15A
15A's Avatar
Originally Posted by stove View Post
88-98 ecc
What he said.
But as with everything....the newer the better. If I still have mine, they were pulled from a 97 960 and a 98 V90 (68k and 77k).
Old 07-01-2012, 05:26 PM   #7
MrBill
MrBill's Avatar
Okay so I dove under the dash today
First - I find this:
I assume this is the golden box.
Next - on the driver's side, I find these:
I assume these are the vacuum servos?
So I turn the vent control knob and I put my hand on the golden box - every time I turn the knob, I feel a movement in the box. That's a good thing I'd say.
So I looked under the hood and traced the vac lines. Every one of the rubber elbows were cracked/dryrotted/not capable of holding air.
I went to the parts store, got some vac line, and voila! working vents. I did find that when I accelerate the vents seem to fade away. It would seem the check valves aren't doing their job.
Old 07-02-2012, 10:26 AM   #8
FlyingTog
B6304 douche
FlyingTog's Avatar
Mine does that. When people ask why, I tell them the car unlocks the A/C compressor clutch at WOT for moar powar.
Originally Posted by Crazychopstick View Post
Just a 960 bumper returning to its original form.
Originally Posted by auditechjs View Post
Cars blowing up is just God telling you to upgrade.
97 965R M90 My car! It's Purple! 225K+! 16.4 1/4. No more bent valves!
98 V90 Sister's car. Silver. 222k+
98 V90 Mom's new car. Dark Green. 156K+
2 Austin Healey Bugeye Sprites. Project car, driver.
2 94 Mazda Miatas. Weekend fun car, LeMons project.
57 Ford Fairlane 500. Grandfather bought new.
960 build thread: http://forums.turbobricks.com/showthread.php?t=231763
FlyingTog is offline   Reply With Quote
Old 07-02-2012, 10:35 AM   #9
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
it's probably one of the servos. every single 960 does it to an extent but the properly functioning cars will take lots of WOT before the vent flow starts to drop off.
the cars that have a real issue will lose flow to the vents under light load and full load and it will be somewhat intolerable.
i've added a vacuum reservoir to my s90 in addition to the one that's already there. i fault traced and couldn't find any leaks in the vacuum control block, lines or servos. the vents only loose some flow under long periods of heavy acceleration. i've seen every 960/s90/v90 do this to an extent even when they were pretty much new. adding the extra vacuum reservoir has stopped it from happening altogether.
edit:// i thought you were talking about the issue we discussed on the phone, didn't even read your post up there. if the air distribution doesn't respond to the selected position, it's usually the vacuum block itself.
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p.
the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k.
500dollar744ti is offline   Reply With Quote
Old 07-02-2012, 07:25 PM   #10
MrBill
MrBill's Avatar
Yeah I'm going to make a vac reservoir out of some pipe or something.
Old 07-02-2012, 10:19 PM   #11
MrBill
MrBill's Avatar
Okay so I was thinking harder.
IIRC - my 760turbo (86) has a vacuum pump. When I have the hvac system running and the motor isn't running, this pump will often turn on.
Maybe i could set up some sort of vacuum switch (engage if vac is under X) and use that pump?
Old 07-02-2012, 10:25 PM   #12
TrickMick
TrickMick's Avatar
let Frankie Goes To Hollywood guide you:
"Relax, don't do it ...when ya wanna get to it...relax....."
strip a spare set of "vacuum balls" out of a J/Y car and plumb it in-line.....
un-neccessarily complicated shiite tends to back fire on ya... a "spare
set of balls" never hurt anyone......
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 07-02-2012, 10:37 PM   #13
MrBill
MrBill's Avatar
But then I can't go cockswinging with my vac pump
Old 07-02-2012, 10:49 PM   #14
linuxman51
ARRRRHARHAR
linuxman51's Avatar
hahahaha. it's been discussed before, using a vacuum pump to drive the hvac system vs the engine vacuum.
Megasquirt Tuning!
ported volvo heads
