Old 06-28-2012, 07:11 PM   #1
Wilford Brimley
Wilford Brimley's Avatar
Default Anybody used this cat before?
http://www.summitracing.com/parts/MPE-54959/
Thoughts? I'm looking for a 3" cat
'89 744T, Ebaycooler, ported 90+, .57trim T3/T04E, 16 psi, 3" Exhaust, TurboXS RFL bov, AC delete, accum modded AW71, cut springs, dual sways, camber mod and some nifty gauges. 16v in progress
http://forums.turbobricks.com/showthread.php?t=198511
Of course you could always invest in a $20 compression tester at harbor freight if you don't have an onion.
Old 06-28-2012, 09:24 PM   #2
grnmachine02
Indicating?
grnmachine02's Avatar
Had one on my s70. Went through emissions fine, and is still working well as far as I know. cat is now 5 years old I wanna say.
1990 745t- b230f+t, t5, Cosworth turbo (billet t04e wheel shoved into a t04b housing), MsNs, leaky exhaust, loud tires, bent wheel, and lots of memories.
Originally Posted by 500dollar744ti View Post
"well if you just (insert something about not being hard headed) and would have done (insert advice that was not given) your car would be (insert some sort of non-fail status)"
grnmachine02 is offline   Reply With Quote
Old 06-29-2012, 01:46 AM   #3
245Mike
245Mike's Avatar
How about this 3" cat?
very-small-cat
-Mike
1987 245 RatRod work in progress...
http://forums.turbobricks.com/showthread.php?t=221318
245Mike is offline   Reply With Quote
Old 06-30-2012, 10:38 PM   #4
15A
World's Oldest Brewery
15A's Avatar
I usually use Catco's (when I actually put one on). Summit sells the 6907 (3") for $127. As with most converters on Summit, you can find them cheaper, like here:
http://www.ebay.com/itm/CATCO-6907-U...-/220819547683
$78 shipped.
Irony is watching an IRS agent plead their 5th Amendment Consitutional right to avoid self incrimination.
15A is offline   Reply With Quote
Old 07-01-2012, 05:37 AM   #5
dieselboy
Whooty patrol
dieselboy's Avatar
Have one on my 242 right now. Seems to be ok.
'82 242t turbo+, intercooled, 3" exhaust, 13" brembos, coilovers, saabspoiler, 18"s, flathood, dying m46, etc.
'97 f-250 psd, d60, locked, chromoly axles, shortened and bob'd.
'91 940irs rallybil, holset, gutted, olive drab rollered on paint, browntops etc
'90 F-250 project. Lots of links, tube, and coilovers.
dieselboy is offline   Reply With Quote
Old 07-01-2012, 01:42 PM   #6
Krepotkin
Busy Mooseterbating
Krepotkin's Avatar
Have it on the 740. No issues. Sounds great.
90 744ti
M-46, ported 15g, MBC ~13psi, 3'' exhaust turbo-back, SE/Aero hybrid kit, ported manifold, e-fan, HD radiator, Blaster2, e-codes with HID's, S90 handles, S90 mirrors, S90 moonroof/headliner, Momo "Corse" wheel. Head Rebuilt 09/2012.
96 850R
14psi, silicone hoses. Soon to be retARDed.
This Sig Brought to you by Carl's Jr.
Krepotkin is offline   Reply With Quote
Old 07-01-2012, 10:17 PM   #7
smokeyfan1000
Owner of a Loyal Pit Bull
smokeyfan1000's Avatar
Link to cats> http://www.google.com/#hl=en&output=...w=1536&bih=749
But seriously, why you want the bullet type cat? MagnaFlow's 53000 series looks like stock cat with 2", 2.5" or 3" in/out for less $$ from Summit.
Seriously afflicted with CVOCD.
Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083
Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000
Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000
Please Help Keep the South Beautiful, Put a Yankee on the Bus...
smokeyfan1000 is online now   Reply With Quote
Old 07-01-2012, 10:25 PM   #8
Wilford Brimley
I was looking for something a little more hipo and I like the smallness of this cat, it would work well with the side exit
Old 07-04-2012, 04:37 PM   #9
bigreddog
Post
I have a 3" spun cat and i dont think there is enough flow. It may be my car, but i think i would go for the standard size 3" if you have room.
bigreddog is offline   Reply With Quote
Old 07-05-2012, 01:45 PM   #10
Dakar09
The Blue Baastard
Dakar09's Avatar
I'll be going with this exact cat myself precisely for the same reason Wilfordy mentions. It's tiny but still works.
Tony
1958 Volvo PV444
1983 245 Turbo - The Project - Targa Newfoundland entry - Sold
http://forums.turbobricks.com/showthread.php?t=225396
2002 BMW M5 - Sold
2011 F150 FX4 Screw with Ecoboost V6
Past bricks - '95 855 manual, '98 V70 T5 Manual, '04 V70R 6-speed, '10 XC60 T6
Dakar09 is offline   Reply With Quote
Old 07-05-2012, 02:04 PM   #11
1983_242
building a "turbo"brick
1983_242's Avatar
FWIW, that is a performance cat and has a spun stainless substrate which can't melt down from rich running conditions like the ceramic substrate cats will. If you plan on keeping the cat on the car for a while, and you're running on chipped ecus that make you run overly rich, this would be the perfect candidate for the job.
EDIT: NVM what I said before, that cat has a ceramic substrate. Look for a stainless substrate cat. Do you have to run a tailpipe smog test?
My Epic Compound Turbo Project
1983 242-B23/M46 DD'er
1982 244-Build Thread Here
2011 MS3-Wife's Beater
1983_242 is offline   Reply With Quote
Old 07-05-2012, 02:12 PM   #12
1983_242
1983_242's Avatar
Buy one of these instead. vvvv
http://compare.ebay.com/like/1708047..._lwgsi=y&cbt=y
Old 07-05-2012, 03:46 PM   #13
Dakar09
The Blue Baastard
Dakar09's Avatar
They do make that in metallic substrate, just $20 more...
http://www.summitracing.com/parts/MPE-59959/
Old 07-05-2012, 04:00 PM   #14
1983_242
1983_242's Avatar
This is the same one in the ebay ad, but getting it from Summit will make it about $30 more after shipping is involved.
Old 07-06-2012, 12:36 PM   #15
Dakar09
The Blue Baastard
Dakar09's Avatar
Good call, dude. Didn't realize it was the metallic one until I referenced the part # from my post. I'll be going the ebay route now.
Old 07-11-2012, 11:30 PM   #16
Wilford Brimley
Nice!
Old 07-11-2012, 11:45 PM   #17
1983_242
1983_242's Avatar
So did you get a cat?
Old 07-11-2012, 11:58 PM   #18
Wilford Brimley
Not yet. Thank god...I would have made a mistake haha
