Old 07-04-2012, 09:12 PM   #1
gottarollwithit
Cooks with motor oil
Default NPR Intercooler fitment
So i'm contemplating installing my NPR intercooler. My car is an 88' 740ti.
What do you guys do for mounting/securing the bottom part of the intercooler?
I want to keep the stock airbox setup. The thickness and width of the intercooler work fine, but it is a few inches too short. The bottom of the intercooler is a few inches away from the lower radiator support brackets. What do you guys do to mount the intercooler onto these brackets? Any of you guys fabricate a big rubber riser or bushing to fit into the brackets?
I saw Simon's NPR intercooler installation vid and he uses a piece of wood. I'm trying for a long term solution here and wood will eventually rot/compress/degrade. Any ideas?
1988 740 turbo wagon/squishmobile!
gottarollwithit is offline   Reply With Quote
Old 07-04-2012, 09:15 PM   #2
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
Originally Posted by thebornotaku View Post
So basically I can't go strap a turbo on to my car
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
1980 262c/b28/m46 'Black Knight' (getting roof/ext resto and engine swap)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is offline   Reply With Quote
Old 07-04-2012, 09:28 PM   #3
Coupe' de Grace
Old 07-05-2012, 12:48 AM   #4
gottarollwithit
Is that...styrofoam???
Doesn't that stuff compress a little bit and rub away with friction?
Old 07-05-2012, 01:19 AM   #5
2fast242gt
cheeseland highschool kid
2fast242gt's Avatar
you could use rubber, pvc aluminum be creative!
1980 241gt
*6.0 lq4 swaped*
Old 07-05-2012, 01:25 AM   #6
gottarollwithit
I was going to use rubber, but where the heck do ya get a block of rubber that big! I figured i could carve a couple pieces of rubber to work as a big intercooler mount, but just couldn't find a big rubber block.
I considered and aluminum bracket, but that intercooler is probably going to jump/vibe/shake around and eventually the alu mount will gall and damage the intercooler.
Old 07-05-2012, 02:48 AM   #7
gsellstr
Vintage anti-ricer
gsellstr's Avatar
I've actually had wood on the bottom of mine for.....counts....4 years or so? Never really had any issue thus far.
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 07-05-2012, 06:38 AM   #8
DET17
Reformed SAABaholic
Worried about wood? Use pressure treated deck planks....think they are about 3/4 thick. Otherwise, fab some supports out of mild steel and weld/bolt them in.
The vintage American iron: http://s699.photobucket.com/albums/vv357/DET17/
Old 07-05-2012, 07:32 AM   #9
swiftjustice44
Marshmallows anyone?
swiftjustice44's Avatar
Styrofoam works well. There is nearly no downward pressure; it's held by the pipe connectors. Still, I opted to build a sheet metal ledge.
swiftjustice44 is offline   Reply With Quote
Old 07-05-2012, 08:24 AM   #10
Coupe' de Grace
what do you think cars are made out of these days
Old 07-05-2012, 09:06 PM   #11
dalek
Benchracer Tribe
dalek's Avatar
Papier-Mache?
Feedback!
Old 07-05-2012, 10:38 PM   #12
Lando
Hunting with Ray Charles
Lando's Avatar
Rubber lift pads cut to fit?
Originally Posted by 740tankDriver View Post
go shove an M camshaft in a b230ft you coward. you are nothing more than a poster.
Lando is offline   Reply With Quote
Old 07-05-2012, 10:46 PM   #13
2fast242gt
2fast242gt's Avatar
Rubber wheel chocks cut them up. Be creative.
Old 07-05-2012, 11:07 PM   #14
odinthewanderer
oh i know, bricks?
cute right?
ask my what kind of stupid i am today?
PM ME IF INTERESTED IN PURCHASING R-SPORT GAUGE PACK
. i neeeeeed $$$$
92 745tic (driver)
92 245 modified (currently parting)
77 244 dl (almost done)
odinthewanderer is offline   Reply With Quote
Old 07-06-2012, 09:44 AM   #15
Coupe' de Grace
may i suggest unistrut™? i was going to use that next or have nathan make me something permanent
Old 07-06-2012, 08:04 PM   #16
Boris740
Broad Member
Boris740's Avatar
Cedar worked for me. Light and it doesn't rot.
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
Old 07-07-2012, 02:43 AM   #17
holtzboy
Converted to Washingtonia
holtzboy's Avatar
I cut up used radiator hoses and stuffed them underneath, just added a little barrier so it wasn't metal on metal contact. Like others said the hoses/clamps held it in place.
-86 244DL- 1st car & Owned for 10 years, 25mm sways, iPd springs/fronts cut 1 coil, HDs, 2.25" exhaust, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
-79 242DL- B21FT, Getrag 265, 405 head shaved 0.30", B Cam, iPd gear adv 6°, 60/63 turbo, 3" exhaust, NPR, Bilstein HDs, Hydras
My feedback thread
holtzboy is offline   Reply With Quote
