Old 07-06-2012, 01:09 PM   #26
83Rabbit
I also did.the pan gasket and filter screen and gasket.
Dont bother with.the strainer, its a waste of time. Mine was spotless despite the fluid looking like liquid doodoo
83Rabbit is offline   Reply With Quote
Old 07-06-2012, 06:45 PM   #27
FITZ5
just do the flush you will be fine i flushed the zf22 on my na car and you should have seen the blacker than black soot stuff that was being pumped out of it no negative effects either
i also had my aw71 flushed out and no negative effects shop charged me 150 per car too
1987 Volvo 740GLE B230F(stock)ZF22-4HP 4spd-automatic Bosch Super+ copper plugs.285,000 mile's Lowered with ipd springs and 16 inch Hydras with 205/55/R16 Yokohama S drive
1988 volvo744 Ti stock for now 193,000 miles ice cold A/C-R12 new Garrett turbocharger stock wheels with 205/55/R15 yokohama S drive Billstien on all corners
FITZ5 is offline   Reply With Quote
Old 07-08-2012, 11:58 AM   #28
volvoboy90
volvoboy90's Avatar
Just flushed my trans today what came out was pretty brown to begin with... Good thing I did it when I did. It seems to shift smoother... not sure if that is slipping or if it is good... *shrug*
Originally Posted by 92Sedan View Post
Alright, however I am curious to know how they handle without their sway-bars.
Originally Posted by TrickMick View Post
like a squid on shore leave after a 9 month cruise...
volvoboy90 is offline   Reply With Quote
Old 07-08-2012, 12:12 PM   #29
TrickMick
TrickMick's Avatar
Lucas TRANSFIX????
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 07-08-2012, 12:15 PM   #30
volvoboy90
volvoboy90's Avatar
I did. I did. I do my best to follow your instructions accurately.
Old 07-08-2012, 12:20 PM   #31
ovlov760
Daddy. Coma.
ovlov760's Avatar
I've flushed several aw71 and aw52 transmissions without incident. If it shifts fine now it will probably benefit from a flush.
1997 850 200k
1997 850 T5 125k ARD white tune
1988 760 Turbo - Sold
Old 07-08-2012, 12:23 PM   #32
volvoboy90
volvoboy90's Avatar
I just did the flush... Anyhow... since the lucas trans fix said it stops hard shirfts, I presumed that the softer shifts were a good sign.
Old 07-08-2012, 09:24 PM   #33
volvoboy90
volvoboy90's Avatar
Shifting as it should now. Fluid was low. The dipstick was reading wrong.
Old 07-08-2012, 11:14 PM   #34
TrickMick
TrickMick's Avatar
*ATTA BOY*
Old 07-08-2012, 11:26 PM   #35
volvoboy90
volvoboy90's Avatar
That trans fix stuck to the tube and kept making my dipstick read full
Old 07-09-2012, 08:48 AM   #36
TrickMick
TrickMick's Avatar
I mix the TransFix into the last two quarts of ATF I'm throwing at the trans....
if it's COLD outside, I leave the bottles in the house and add them straight-away
when I fetch them....at the shop, I can just sit them on the floor near the stove
and cruise that way.....
