Old 10-08-2019, 09:27 AM   #451
propav8r
F*ck Edgar
propav8r's Avatar
Is 2019 the year of both our 240s?
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 10-08-2019, 09:33 AM   #452
Stiggy Pop
Stiggy Pop's Avatar
why bother water cooling the wastegate?
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 10-08-2019, 09:33 AM   #453
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Yours, probably.
Kyle's, doubtful.
1971 142 beater/fake racecar
1972 145 sh*t hauler
The incest is implied.
Old 10-08-2019, 09:34 AM   #454
stick70
All the gauges
stick70's Avatar
It's got holes for it, I have the urge to fill them
Originally Posted by vwbusman66 View Post
Yours, probably.
Kyle's, doubtful.
Depends on many things, the future is cloudy
Old 10-08-2019, 09:45 AM   #455
Stiggy Pop
Stiggy Pop's Avatar
unless you're burning up diaphragms I'd skip it, extra cost, extra plumbing, extra points of failure, little to be gained. I've worked on IMSA cars that don't cool the gate... I think on a street car it's pretty unnecessary.
hydro clutch and gearing change will pay off quite a bit.
Old 10-08-2019, 09:47 AM   #456
propav8r
F*ck Edgar
propav8r's Avatar
Yours, probably.
Kyle's, doubtful.
Ehhh idk. If all the stars line up over the next couple weeks, I'll probably get mine done. If they don't, the car will just sit in the basement for another 5 years.
Old 10-08-2019, 09:58 AM   #457
stick70
All the gauges
stick70's Avatar
Oh it's for sure unnecessary
The other things are necessities I agree. I've had multiple clutch cables in this car over the last few years and they have all been garbage. I have most of the parts already for hydraulic clutch, just never did it.
The gear set I'm stoked about to make the car more usable. I mean don't get me wrong cruising 80mph at 2500rpm is sweet and all but I can't even get it in 5th until 55
Old 10-08-2019, 01:28 PM   #458
Stiggy Pop
Stiggy Pop's Avatar
I think our roads are pretty similar, from what I've seen you post up. I'd be pretty stuck with the tall fifth gears, fourth gets buzzy pretty quick, ~2400rpm is a great cruising rpm but not many places I'm cruising at 80mph!
the block... I had a 250k mile stock longblock in my car before the built motor went in. All it had was the cam, everything else was just as-removed from a driven hard turbobricker car. I put a hurtin on that thing. I had all the setup around it, header, intake mani, fuel... was running the HX35 at 25psi and just hammering on the car. I'm sure the car was making 350bhp. I really expected to kill it but it came out a running motor. By the end I was blowing some smoke at 7k rpm rundowns and getting some odd detonation, but it kept taking it. So it might surprise you!
Old 10-08-2019, 03:27 PM   #459
stick70
All the gauges
stick70's Avatar
That's good to hear! This one had 90k when I put it in, so it "should" be fine. I'm only at 16psi on that hy35 now so I haven't even scratched the surface of what it can do. With a new top end and intake it should wake up, not to mention the extra boost I want to throw at it.
Old 10-11-2019, 07:52 AM   #460
Quin
ಠ_ಠ
god, i hope so.
Old 10-11-2019, 10:50 AM   #461
stick70
All the gauges
stick70's Avatar
I robbed parts off of it last night, does that count as work?
Old 10-11-2019, 11:51 AM   #462
2020 is going to be the year of all 240s.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-11-2019, 01:38 PM   #463
stick70
All the gauges
stick70's Avatar
240s unite!
Old 10-11-2019, 04:45 PM   #464
Vol242vo
Keep it clean...
Vol242vo's Avatar
I’ve always loved your 242...way back.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 10-11-2019, 04:54 PM   #465
stick70
All the gauges
stick70's Avatar
Thanks!
Old 01-06-2020, 06:51 PM   #466
stick70
All the gauges
stick70's Avatar
You guys will be happy to know that I put a new driveshaft yoke in this thing and beat it around the neighborhood last night.
Look, I even put gas in it:
Impressions: Man I really hate on this car for being slow but it ain't. It doesn't have 300 hp but slow it is not.
My god it handles good.
Stops even better.
The list I made a while back still (mostly) stands, but the car will at least move around now. My next goal is to get it together good enough to get it to SE. I'd like to at least get the head, intake, and ECU figured out before then but who knows. That would net me a little more power and it would be at it's highest potential when it meets Kenny's dyno. Maybe if I get that far I can put a sebring 5th and a truetrac in it before mountain meet in the fall. All told at that point I will really be at a happy point with the car. I think the only other thing I'd like that isn't on the list is a softer set of engine mounts and the KL racing front control arms for more caster, but those things I'd be fine doing later. Honestly with the caster/camber that I have now it'll make you reconsider your corner speeds on the street.
Old 01-06-2020, 07:05 PM   #467
You should make the trip over to the best coast for IPD or Davis. Either airline or 242 is fine.
Old 01-06-2020, 07:44 PM   #468
stick70
All the gauges
stick70's Avatar
Id actually love to beat this thing out there, it would do really well.
Old 01-06-2020, 07:51 PM   #469
vwbusman66
vwbusman66's Avatar
Well I'll be damned. I spoke too soon. Both in one weekend, no less!
Yours, probably.
Kyle's, doubtful.
Stops even better.
Old 01-06-2020, 07:54 PM   #470
If you do the Davis drive I will lobby to let the spousal unit let me **** off for 4 days on my birthday weekend.
If you do IPD I'll 100% make the slog across town and throw a house party in your name
Old 01-06-2020, 08:05 PM   #471
stick70
All the gauges
stick70's Avatar
Lmao I'm down with that
Old 01-08-2020, 06:22 AM   #472
Quin
ಠ_ಠ
wasn't jared talking about ipd as well? guess that settles that, then.
Old 01-08-2020, 11:57 AM   #473
If kyle goes, i might too.
Old 01-08-2020, 12:19 PM   #474
stick70
All the gauges
stick70's Avatar
I really would like to, I need to figure out wtf I'm even doing with my schedule first.
Old 01-08-2020, 12:44 PM   #475
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Ya'll talking about driving or flying to ipd?
MikeJr. is online now   Reply With Quote
