Old 02-19-2011, 12:22 PM   #126
towerymt
the real Towery
towerymt's Avatar
Originally Posted by MrBill View Post
can I just give you the cash for that now? I've needed that turbo forever
Make an offer before it's sold.
Old 02-20-2011, 06:27 PM   #127
550
Originally Posted by stick70 View Post
Fixed the ignition issues tonight, spark was set to inverted. Apparently the 3452 times we went through the settings and the tune we missed/didnt think about it. I thought we had tried this before, maybe we did, idk. I also went through and got all new .ini files and firmware and uploaded it. All is well, she runs like a champ.
This is interesting. Everything I have read says run the 139 inverted.
I haven't gotten far enough to really bother with timing yet, but I know I was running with in one degree of what MS was showing. But was having some idle issues in general.
I may have to try this....
When I was messing around with getting spark ( I couldn't get the damn thing to fire... turned out to be fuel not spark ) I had messed with the 139 both inverted and not and when inverted the spark was HOT HOT HOT. But non-inverted seemed weak from what I could tell.
Glad you got it fixed, hopefully I start finding some luck soon.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 02-20-2011, 09:27 PM   #128
stick70
All the gauges
stick70's Avatar
Yeah changing firmware helped alot, but I could only find one firmware that it really liked. I kept getting odd resets and losing spark with the others randomly. It idles better with the spark inverted, but the timing would advance by itself outside of the table. It was knocking at like 3k rpm and 0* advance in the table.
Old 02-20-2011, 09:29 PM   #129
550
i need to keep an eye out for the timing. And see if mine is going outside the range. You may be able to get a better idle by upping the Advance a bit, it may make up for the difference in inverted spark.
Old 02-20-2011, 10:52 PM   #130
stick70
All the gauges
stick70's Avatar
I'll try that, I knew mine was going outside of the range because when I set fixed angle to a value it wouldnt stay there when revved.
Old 02-20-2011, 11:02 PM   #131
550
http://forums.turbobricks.com/showth...light=throttle
For reference here is the thread I was reading for the timing advance.
Old 02-28-2011, 01:17 PM   #132
stick70
All the gauges
stick70's Avatar
Well the fuel pump went out on it yesterday so I guess its time for a Bosch 044.
Also does anyone know if aeroquip stainless hose is ok to use with power steering? I'm making a pressure hose for my pump setup and I'm just wondering if I should just bite the bullet and get the special power steering hose and fittings vs. just regular AN stuff
Old 02-28-2011, 01:56 PM   #133
I went to a hydraulic shop and had them make me a high pressure line using Aeroquip goods, Use steel fittings on the high pressure side,,, also a line with crimped fittings is usually necessary.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-28-2011, 04:19 PM   #134
stick70
All the gauges
stick70's Avatar
Yeah thats probably what I'll end up doing, steel fittings are $$$ but I really dont want to lose that line so its worth it
Old 02-28-2011, 06:02 PM   #135
RvolvoR
youd be surpised....the line will prbably cost you like $60-70...there is an awesome aeroquip industrial store in charlotte...look it up.
Old 02-28-2011, 06:13 PM   #136
stick70
All the gauges
stick70's Avatar
Yeah, I remember what eamonn paid for his
Old 02-28-2011, 06:51 PM   #137
The Aspirator
It's a girl!
The Aspirator's Avatar
Finally read through this, the car is coming along GREAT! Jealous that you have a lift in your shop.
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 03-01-2011, 12:12 AM   #138
propav8r
F*ck Edgar
propav8r's Avatar
So...you're gonna help me MS my car this summer. Right? Right?
Oh-and I'll be home on Thursday or Friday. Just let me know when you need that fuel pump. I'll be going I-40W to I-85S if you're not gonna be in Charlotte.
Originally Posted by Manbeard
My year of VW ownership has been 100% problem free, therefore all VW products are 100% problem free.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 03-20-2011, 02:37 AM   #139
stick70
All the gauges
stick70's Avatar
Finally got a chance to work on this thing some today. The car cut off because it blew the power fuse for megasquirt, I tried to cycle the pump manually when it broke, but no dice and no spare fuses ftl. So it runs again. Also went to aeroquip this week and got my pressure line made, cost $40, I was expecting more. But that place is officially awesome, I couldnt imagine any more fittings and hoses in one store. Had to use some lowes line on the feed hose for now, but it should be ok for a while. The feed line doesnt see any pressure anyway. Im running a reservoir off of a BMW 5 series of some year I got at the pull a part. Steering feels good, responsive but a little more manual feel than the S70 has. I guess thats just to be expected with a racecar pump, but I like it. Also recently bought a set of heated power mirrors and started getting those in. I had to drill the doors because they mount differently than the -85 ones do, but no biggie. I made a cardboard template and had them drilled and installed in no time. I really like these things, my 84 power mirrors were in good shape but they just weren't clear enough. Also the early pass side mirror isnt scaled so its annoying on the highway. Overall just a little more bling factor and another switch to show off on the dash . Anyway enough talk, pics:
Old 03-26-2011, 12:28 PM   #140
stick70
All the gauges
stick70's Avatar
Fuel pump looks to be good! Pulled the feed line off and dug about 2" of mud out of it and the feed side of the pump . Plugged it all back up and there is more pressure than could ever be asked for, ~6 bar when the regulator was pinched.
Old 03-27-2011, 07:16 PM   #141
The Aspirator
It's a girl!
I used that exact same power steering hose (garden hose) on my first 244 for years, never had a problem, always got funny looks and comments at meets.
Old 03-28-2011, 12:21 PM   #142
stick70
All the gauges
stick70's Avatar
Lol yeah worst comes to worst I change it, its not like its hard to to. Plus I can see how dirty the fluid is/isnt now
Old 04-09-2011, 01:07 AM   #143
stick70
All the gauges
stick70's Avatar
So I was thinking of getting a set of fixed backs for this thing, but its not going to be a race car. Too cool to molest that way in my opinion, Ill save that fate for a poor 244 or something. I saw these and they look nice...
opinions?
Old 04-09-2011, 01:53 AM   #144
Manbeard
#helpbrock2k16
Manbeard's Avatar
those are awesome!
2012 tdi
Manbeard is offline   Reply With Quote
Old 04-09-2011, 05:54 AM   #145
mavawreck
The son of Chico Dusty
mavawreck's Avatar
they look great, how much they run?
Blue collars don't pop, they're too soaked with sweat.
- The Saturday Knights.
mavawreck is offline   Reply With Quote
Old 04-09-2011, 11:24 AM   #146
kampman
dunning-krugersquirt
Corbeaus are hot, and they make a Volvo-specific bracket-I've been thinking about going that route with my 244 when I get a little cash flow. Go for it, I say.
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5M AWD: 145K
Feedback Thread
kampman is offline   Reply With Quote
Old 04-09-2011, 11:27 AM   #147
550
I have heard they aren't so comfortable. Never sat in them myself though. I love my 03 WRX seats.
Old 04-09-2011, 11:40 AM   #148
olov
doing something stupid
get some cheap seats out of a 90's japanese car. eamonn found some out of some toyota(i think) and man do they feel good compared to a volvo seat.
Old 04-09-2011, 03:03 PM   #149
corbeaus are fail... sparco EVO ftw.
Old 04-09-2011, 03:12 PM   #150
Jordan
Jordan's Avatar
Correct me if I am wrong but I don't think they make the GTSII anymore. They are what I was thinking about getting but I couldn't find em so I went with a set of old Recaros and get them recovered.
My Buyer/Seller Feedback Thread
Jordan is offline   Reply With Quote
