Old 08-13-2011, 09:17 AM   #201
550
Would you looook at that! Veerrrry nice
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 08-13-2011, 11:41 PM   #202
stick70
All the gauges
stick70's Avatar
Well, I spent most of today with a grinder, and I'm beat. But I got my collector done. Its just tacked onto the flange right now, I'll weld that up tomorrow. I cut the end of the pipes at a 15* angle to get them to clear each other, seemed to work out ok. Also, heres a couple pictures showing my intercooler as well. I had to cut the sheetmetal behind the headlight to get the thing to fit, but its perfectly sized.
Preliminary tacking of the tubes
They were then cut and welded to each other
After still more grinding
Welded together and tacked to the flange
Nice transitions on the inside, will port match after final flange welding
All in all not bad for my first collector ever, now on to the tubes...
Old 08-13-2011, 11:41 PM   #203
stick70
All the gauges
stick70's Avatar
So nice it posted twice
Old 08-14-2011, 10:39 PM   #204
MrBill
fige=500Dollar Mistake
MrBill's Avatar
so nice indeed buddy!
btw I talked to towery yesterday and I didn't get any negative comments about him bringing you the trans.
Someone say crazy rays?
Old 08-14-2011, 10:40 PM   #205
MrBill
MrBill's Avatar
Old 08-14-2011, 10:45 PM   #206
stick70
All the gauges
stick70's Avatar
WIN! It may not be in by SE, but I'm damn sure going to try
Old 08-27-2011, 03:27 PM   #207
stick70
All the gauges
stick70's Avatar
A little wheel test fit. I think I may just be able to squeeze a 235 in the rear, but there is no way in the front with adaptors, its pretty damn flush right now, so I may have to go 225-215. Hopefully not the latter of the two. I am going to have to roll the hell out of the rear fender lips thats for sure...
Old 08-27-2011, 03:30 PM   #208
mavawreck
The son of Chico Dusty
mavawreck's Avatar
That looks sick. I may have to copy your style.
Blue collars don't pop, they're too soaked with sweat.
- The Saturday Knights.
mavawreck is offline   Reply With Quote
Old 08-28-2011, 01:26 AM   #209
stick70
All the gauges
stick70's Avatar
Got the #4 runner all tacked up, it took me forever to get the flange to fit my engine. Whats left of the EGR was all in the way under the ports so I had to clearance them. I'm hoping to have it all tacked up tomorrow but we shall see.
Old 08-28-2011, 08:37 AM   #210
olov
doing something stupid
good luck
thinking about doing a "dc crew rear 1/4 pull"?
Old 08-28-2011, 11:17 AM   #211
towerymt
the real Towery
towerymt's Avatar
Refresh my memory, what's the wheel width, offset, and spacer sizes? Looks like a lot of lip rolling in the rear. Front shouldn't be too bad, but rolling the front lip flat w/o rippling the outside edge of the fender lip is a bit more tricky.
Old 08-28-2011, 11:40 AM   #212
stick70
All the gauges
stick70's Avatar
17x8 et20 with 20mm adaptors. The rear sits in from the edge of the fender ~10mm, its not nearly as close as the front is
Old 08-28-2011, 12:25 PM   #213
towerymt
the real Towery
towerymt's Avatar
The front will be fine with the lips flattened. Extend the lower supports a little if you need some more room.
Rear will be tight with a 235. With the lips flat, it's going to be really close. Or pull the quarters a little, run a 245/40 as low as you want it to go.
Old 08-28-2011, 04:13 PM   #214
stick70
All the gauges
stick70's Avatar
Ive got a 225/45 and a 235/45 to play with so I'll see what I can do with those, I'm not sure what tire size I'm going to end up on though.
More header work, but I ran out of elbows, I'll order a few more this week so I can finish this next weekend.
Heres #3 added
Then #1
And I threw it on the car to check clearance. I should be able to get to all of the studs no problem, and the spark plugs should be accessible as well if I run the downpipe right.
I'm also going to move the radiator forward, I have n/a brackets that I have yet to put on. I need to get longer radiator hoses.
Old 09-04-2011, 11:34 PM   #215
stick70
All the gauges
stick70's Avatar
Got all 4 runners tacked up, I'm in the process of final welding everything now, hopefully I can get it all done tomorrow. I also recently purchased a new steering wheel. Its a deep dish drift wheel or something off of ebay, cost a whole $20.
But heres a couple pics to show header progress.
All tacked up and on the stand
Test fit in the bay to check clearance
It just does kiss the coolant hose, but that shouldnt be hard to fix
Clears the frame rail and the strut tower with room to spare
The downpipe is going to be a little tight, but there is enough room to fit it without rattles.
Old 09-04-2011, 11:48 PM   #216
fige
KING OF TBOT
fige's Avatar
Didn't have to roll my style 5's too much with 225's.... but then again I have 225's on a style 5 without adapters.
They look good!
Almost wish I had center caps.
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 09-05-2011, 12:02 AM   #217
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I like that header. nice work Kyle.
Old 09-05-2011, 08:40 AM   #218
550
I think I asked this before... but I'm not finding it. Are you migging the whole thing or where you just taking it and having someone TIG the rest of it?
Old 09-05-2011, 09:49 AM   #219
stick70
All the gauges
stick70's Avatar
Thanks guys, I'm pleased with how its coming along. Should be smooth sailing to getting this ready for SE once I get this finished.
Joe I'm migging it unfortunately, but its turning out good so far. I have a good millermatic welder to use so I'm not concerned with it. The welds aren't as nice looking as a tig welders would be, but being steel I'm going to paint and wrap it anyway to try and keep some of the heat in so its not like your going to be able to see them lol.
Old 09-05-2011, 10:11 AM   #220
550
I think it should be fine as long as it's braced as well. I user a miller 140 w/ jokeautoset.
I welded an uppipe for my buddy so we shall see, he will be mounting an hy35 onto it lol! If it works out well, I'll be migging my manifold as well.
Old 09-05-2011, 03:07 PM   #221
stick70
All the gauges
stick70's Avatar
Yeah I'm getting good penetration so it'll be fine. I'm grinding them all smooth too so any flaws will show up then.
Old 09-05-2011, 05:38 PM   #222
XxJenoxX
Skin Suit
XxJenoxX's Avatar
That steering wheel looks awesome. Unfortunately, my arms are already too close to the wheel in my 242. I couldn't run a deep dish wheel. Was that just an individual deal you stumbled upon, or an actual vendor?
- amerbritcan
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 09-05-2011, 05:55 PM   #223
Sander
Good news everyone!
Sander's Avatar
Nice work on the header, looks good!
Old 09-05-2011, 11:42 PM   #224
stick70
All the gauges
stick70's Avatar
- amerbritcan
I think they sell for 35? Mine has a scratch in it, I fixed it up and it looks fine now
Old 09-11-2011, 05:18 PM   #225
stick70
All the gauges
stick70's Avatar
Finished the header and put it on for a heat cycle. Seems to be A-ok. It sounds insane with just the header on there, like half a cammed v8. I'm doing the oil return and feed next week when I get back home so maybe just maybe I'll get it all put on.
