Old 01-25-2012, 08:16 PM   #101
DennisvdB
DennisvdB's Avatar
Yup, you can use slotted or non-slotted, doesn't matter for you. Slotted is for head mounted distributors.
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 01-26-2012, 04:48 PM   #102
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
time to raid on of my 360 head's i got here!
Got these in the mail today from germany too!
Update on the whole swap thing that i did not think of/knew and taking care of now, things bold are already done just need to pickup/install
- AW71 drivetrain from a 240, 740 does not fit
- Plug for head
- distributor
- rear axle from +86 240 (diff with speedsensor)
760 Turbo '86|Volvo 360 cup|Volvo XC90 04|
My Seller Feedback
Old 01-26-2012, 05:11 PM   #103
JW240
All idiot, no savant
JW240's Avatar
You may run into an issue with the rear brake lines where the steelflex line attaches to the axle, the form of the coupling can be wrong for the hard line on the axle. The thread fits but the end of the steelflex line is like this > and the end of the hard line is like that too <. You need > to > flared. Kinda hard to explain here but on my 240 i ran into that issue, also have Goodridge lines but maybe this seller sells the correct set? Fixed it by modifying the copper tubing on the rear axle.
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 01-26-2012, 05:34 PM   #104
Mr.Borrie
Mr.Borrie's Avatar
i asked him 4 times if he was sure (seller in germany) he assured me these would be the ones i need. But now i will install a +86 axle so i really hope thats still the same.
This is a set for a 242 from 77' as far as i know. If not that guy will have to help me out. Got it for 140 EUR shipped. Seems pretty cheap cause usally they are around 30 euro's a line at least so i was already not to sure if i would get them
Old 01-27-2012, 10:04 AM   #105
Ruben
Ruben's Avatar
Why not just get normal hoses/lines instead of the SS brakelines? E140 is quite an investment. (compared to what I'm used to, 360 has only 3 lines which makes it a lot cheaper.)
Not meant as critisism, just sounds like $$$$$. Normal ones are only E4-7 a peace on ebay.
Looks like this will become a nice ride.
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 01-27-2012, 10:14 AM   #106
Mr.Borrie
Mr.Borrie's Avatar
Puting in a turbo engine means making some updates to the brakes too, lines where busted anyway and needed replacing so i decided to update. And yes its costing more than i hoped for but that's the price for a safe and fun ride...
Still 140 is a good deal for 6 quality SS lines so im not complaining
Old 01-27-2012, 01:23 PM   #107
Funkee
Funkee's Avatar
WTF cut the shaft down?
Boris, you also need this to block off the hole where the distributor used to be.
http://www.vomd.nl/index.php?main_pa...roducts_id=760
I'd say go with Buchka WastedSpark. That way you don't need to put in the shaft for the distributor, and the distributor itself. Plus it has better, consistent spark. Might be better for your LPG. I think what you already got for that MS setup is suitable.
Haha mind my words, TB style. I've seen some conversions where the small shaft where the rotor slots onto was cut down.. not my style. Not even TB style actually, seen it on Garaget or 240tic or something.
Old 01-27-2012, 02:08 PM   #108
B-lennium
TB style, you REMOVE the shaft, and than wonder why your oil pressure went down
I had Goodrich Benelux (delft) made me some SS line's for my 164, I have never driven a 164 that braked that nice! I only paid €120,- I provided the measurements.
Volvo 164e B30e, Megasquirt MSII extra
B-lennium is offline   Reply With Quote
Old 01-27-2012, 04:19 PM   #109
Mr.Borrie
Mr.Borrie's Avatar
120 euro's is not bad at all! if you look online for premade sets for 200 series you can easly spend 200 euro's
Old 01-27-2012, 06:00 PM   #110
JW240
JW240's Avatar
i think i got my set (Goodridge) for 110 shipped incl stainless steel couplings? but thats some time ago. The set you have has all stainless steel couplings, thats nice, some cheaper Goodridge sets have normal steel couplings.
About the fitting problem, not sure if i put the rear lines in the other way, that could explain the issue i ran into. dont think so because that would have been too obvious but im not 100% sure now. The nuts that are threaded onto the line are on the wrong end now i think, thats the end where they are fitted to the limiting valves at the chassis.
Old 01-29-2012, 09:31 AM   #111
Mr.Borrie
Mr.Borrie's Avatar
Next Saturday i will pick up a Pre86 axle with speed sensor so we'll see about the fitments in the rear axle break lines. I have yet to see a websites that sells em cheaper but its fine i got the stuff i need now.
Today i spend 2 hours on the engine bay again. de rusted the front panel and sanded down the spots that got rusty again and gave it a treatment with some zink compound. It makes a chemical reaction with the iron so its not a paint. It should keep the rust away for a while
Old 01-29-2012, 09:32 AM   #112
Mr.Borrie
Mr.Borrie's Avatar
dubble
Old 01-29-2012, 10:08 AM   #113
Funkee
Funkee's Avatar
Since I'm a wheel fetishist; what wheels are you gonna run ?
Old 01-29-2012, 11:36 AM   #114
Mr.Borrie
Mr.Borrie's Avatar
Default This
This
You know its ON when i start buying wheels for cars!
Here are some mint looking Rial 5x108 ET11 / 7J
Old 01-29-2012, 11:51 AM   #115
Funkee
Funkee's Avatar
Nice. Gonna look sweet together with the body kit. Lekker jaren 80
Old 01-29-2012, 02:03 PM   #116
Mr.Borrie
Mr.Borrie's Avatar
Haha thanks , lekker jaren 80 was THE look i was going for!
Old 01-29-2012, 02:12 PM   #117
Mattis
Mattis's Avatar
When I switched the rear axle on my -79 to a newer speedo axle, I just hung up the lines+calipers, switched the axle, and mounted it back once I was done with the axle swap. the lines fit the newer axle as well, also, you don't have to bleed the brakes if you do it that way
Mattis is offline   Reply With Quote
Old 01-29-2012, 04:43 PM   #118
Mr.Borrie
Mr.Borrie's Avatar
calipers are siezed im sure, been parked for 3 years. i wanna take all the brakeparts of and rebuild them anyway. but thanks for the tip
Old 01-31-2012, 03:08 PM   #119
Mr.Borrie
Mr.Borrie's Avatar
Ignition blocked off on the head
Old 02-16-2012, 02:38 PM   #120
Mr.Borrie
Mr.Borrie's Avatar
Oh been a while already, here are a few updates. Mostly just spending money but still results.
Got 2 brand new race seats, simons sport turbo exhaust, some seals and got J2 to weld in bungs for the LH and wideband into the DP Thanks buddy!
Old 02-16-2012, 02:43 PM   #121
Turbosteen
I was born at a young age
Turbosteen's Avatar
More info on the seats? Available in green?:P
Looks nice!
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 02-16-2012, 02:56 PM   #122
Mr.Borrie
Mr.Borrie's Avatar
Looks nice!
http://www.maxicartuning.nl/maxicartuning.nl/shop/
Nope not green just black and beige, got them here found via MP.
I was there to pick up a 360 for parts anyway 10 min from the store so i decided to check out the quality. they are not bad and 240 euro's for 2 of them.. its allot of money but they will look soooo cool and they look like they can take a punch surprisingly.
All i knew is i would NOT rock the seats that are in there right now, you gotta be stoned to sit on those.. now i see why they are hippy mobiles
Old 02-17-2012, 03:05 AM   #123
J2_
J2_'s Avatar
Seats look nice
No problem for the welding bud!
J2_ is offline   Reply With Quote
Old 02-17-2012, 03:06 AM   #124
J2_
J2_'s Avatar
Seats look nice
Old 02-17-2012, 04:39 AM   #125
Sander
Good news everyone!
Sander's Avatar
Those seats look great! Are they comfy?
