Old 01-15-2019, 02:47 PM   #276
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Originally Posted by Cwazywazy View Post
You should go all out with the truck thing and pop a straight 6 diesel in there.
I was thinking either a 4BT Cummins or Detriot 4v71 (2-stroke 4 cylinder).
Old 01-15-2019, 03:17 PM   #277
Duder
Comes with a free Frogurt
Duder's Avatar
The only inline 6 diesel that would really fit is the D24...and barf. to that idea.
If he wanted to do an oil burner I think a 2.0L common-rail TDI would be much better suited. The dieselgate engine. They are amazing little powerplants if you ignore the NOx.
Old 01-15-2019, 03:19 PM   #278
OM606
Old 01-15-2019, 03:42 PM   #279
Stiggy Pop
Stiggy Pop's Avatar
I draw my hipster line a little inside of the point where diesel swaps become interesting
'79 242
943 pickup
Old 01-15-2019, 04:56 PM   #280
Why? Bigger turbo, more fuel pressure, and bam, 35 mpg and easy 13s.
Old 01-15-2019, 05:02 PM   #281
vwbusman66
vwbusman66's Avatar
OM606
I was disgusted the first time I looked at prices for those. I was toying with diesel-swapping the 300TE and figured they'd be as cheap as 617's, but no. You'll spend more on an engine that on a parts car.
Those, and 603's
Old 01-15-2019, 05:07 PM   #282
Stiggy Pop
Stiggy Pop's Avatar
I've never owned a diesel so here's my assumptions: stinky, noisy, clattery, dirty, unsmooth, powerbands I don't like.
it's like the total opposite of that glassy smooth toyota motor, in my mind (which, btw, I already have in the yard!)
Old 01-15-2019, 09:53 PM   #283
240wagonguy
you are not alone, I am not a fan of diesels myself. Stinky loud af moneypits. The fuel is more expensive too. The prices for parts is absurd. I don't even like filling up at the combined gas/diesel pump, everything is covered in smelly black goo.
Old 01-15-2019, 10:36 PM   #284
Cwazywazy
Single jingle
Cwazywazy's Avatar
Well, if a diesel is good enough for a Mercedes..
https://youtu.be/2U-Xok19JEo
I don't know what I have
Old 01-15-2019, 11:11 PM   #285
Yeah bro, you don't even know how good a German diesel can be: https://youtu.be/ZgjLaF3BxYQ
Old 01-16-2019, 02:16 PM   #286
Duder
Duder's Avatar
A modern diesel can be an awesome highway cruiser - smooth, quiet, and un-stinky. And as Harald is illustrating, they can make great power too. But I think it may not be the best choice for your intended use case for the El Camin940 anyway - a 2JZ I'm sure will do the forest road bombing job very well. Not trying to change your mind about this car, just offer some different perspective on what diesels can do. Now that they are a dying breed I think in a few years we'll be talking about them like people reminisce about 2-stroke street bikes.
Old 01-16-2019, 09:01 PM   #287
Stiggy Pop
Stiggy Pop's Avatar
I think I have my tongue farther into my cheek than you guys realize
Actually my Dad is all hot on the idea of buying Mom an SQ5 diesel and I think it's a good pick
Old 01-16-2019, 10:45 PM   #288
240wagonguy
now you got me thinking, maybe I should follow thru with the ute conversion on an 88 765 I picked up for $100. I already cut the rear 1/3 of the roof off since a tree had fallen on it years ago. Might as well keep going on it. 2JZ sounds cool too since it needs a new engine/trans.
Old 01-17-2019, 12:38 AM   #289
Is there such a thing as a diesel SQ5??
Old 01-17-2019, 10:14 AM   #290
Stiggy Pop
Stiggy Pop's Avatar
Yes! and they make ALL THE TORQUE
Old 01-17-2019, 03:14 PM   #291
mikezohsix
Actually there is no SQ5 diesel.
The SQ5 is only available with the 3.0 supercharged gas engine.
There's a Q5 S line diesel, which is almost there.
S Line get's you the sport seats some of the suspension goodies, flat bottomed wheel etc..
It's sort of like the BMW M Sport package, not an M3 or M5, but a lot of the looks and goodies without the balls out package.
The 3.0 TDI has around 425 pound feet of torque on an 8 speed trans.
That'll move the little SUV along...
97 V90, gone but not forgotten,
- it's a driving car now with a 350hp all aluminum LS1 with T56 six speed manual transmission, and it hauls ass! Check the for sale section if you're interested in the car - http://forums.turbobricks.com/showthread.php?t=235015.
mikezohsix@yahoo.com
mikezohsix is offline   Reply With Quote
Old 10-07-2019, 09:53 AM   #292
Hilding
Hellö,
Vary naice build. Thank you for sharing.
I have lifted Volvo 745, 5 cm front and rear with 27" A/T tires on original 15" steelies. Now also with 25 mm spacers for no rubbing on full turn.
Rear is lifted with hockey pucks (2 pucks = 5 cm) pressed into 4,8 cm long 3" pipes, also drilled new holes for shocks in rear arms. Front is sawed in two then welded with 5 cm pipe in between of same girth. Made 4.something spacers in pipe for shocks to rest on in bottom. Did chamber mod. Otherwise arm under to short. Original springs.
I like much. Maybe inspire, maybe frighten?
Ladda upp bilder
Hilding is offline   Reply With Quote
Old 10-07-2019, 01:24 PM   #293
Stiggy Pop
Stiggy Pop's Avatar
Originally Posted by Hilding View Post
Hellö,
Ladda upp bilder
Hi, and thanks! I like that ride height and setup, does not look too exaggerated. I have not yet decided if I will lift the car, but do want to get more tire under it like you have. The more utility I can add to the car the more I will enjoy it.
Actually spent a good portion of the weekend in the car with my Dad and he reminded me I've been letting the truck sit unloved in his greenhouse for too long - hey at least it's covered. I've got a reasonably short and doable list of things To Do in order to finish off some things that were left half finished, and those will make it a little more ready for DD type duties. Plan now is to get through all of my house/property work with what's left of the Fall, then pull the truck in and give it some lovin.
Old 10-07-2019, 08:55 PM   #294
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Isn't it funny how you can both love a car and hate it at the same time? I usually hate these wagon turned into pickup trucks but I honestly love this.
Old 10-07-2019, 09:19 PM   #295
2turbotoys
Have you seen me?
2turbotoys's Avatar
^^What he said, usually these pickup conversions are just awful looking. This one is dam nice though!
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-08-2019, 08:44 AM   #296
Stiggy Pop
Stiggy Pop's Avatar
many thanks, really appreciate it. In many ways these kinda comments mean more to me than all of the praise the 242 gets, since we made a lot more decisions surrounding how the thing would look.
Just realized the dates of last posts! Definitely time to get it back in the garage and do something with it besides haul stuff around. Thanks for the motivation!
Old 10-17-2019, 12:08 PM   #297
redblockpowered
redblockpowered's Avatar
The build quality/attention to detail here is really impressive. It's also nice to see I'm not the only one who hasn't thrown their Adharas in the trash.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (320k!)
Old 12-23-2019, 12:07 PM   #298
Chigga 744SE
Taiwan hillbilly
I love everything about this project.
are those 22" AC Schnitzer Type 2 in the bed?
Chigga 744SE is offline   Reply With Quote
Old 12-23-2019, 12:55 PM   #299
Stiggy Pop
Stiggy Pop's Avatar
thanks guys!
I wish they were that legit! They are 22x9 Lexani R-4's I run on my wife's XC60.
Also the bump is well timed because I am going to let the 242 sleep in it's bag for once this winter and get this thing back in the garage. Just need to scrap out an old SAAB then we can get this back in and give it the love it deserves. Basic plan is to finish off the bed, finish some off the more fiddly weather proofing/water management work, start working towards and interior... and then I imagine a lot of hemming and hawing as we consider going back into body work. Basically the "proof of concept" worked, I really enjoy it, time to finish it properly!
Old 03-12-2020, 04:39 AM   #300
nordmaschine
forced instruction
nordmaschine's Avatar
Wee need updates!
I vote for 2" lift and 215/70 R15's.
As for potential diesel swap, from what I now know, I'd steer clear of Mercedes engines. Heavy and too expensive for what they are.
Did you get BMW M51D25's in the US? It's like D24, just better, and it takes great to mechanical injection pumps. M57D30 commonrail is another viable option for those that like too-modern diesels.
I'm currently toying with a V6 TDI 2.5 out of '05 A6 in the back of my shed...
Jetronic is romantic.
Whiteblocks
