Old 09-25-2019, 04:11 PM   #801
klr142
Turbo, what?
klr142's Avatar
Well, new house has been purchased and the garage is just about set up. Sadly, it's maybe smaller than the last one just with a bit more depth. The car has been rotting outside at the shop since at least June and I hope to finally get it back in a garage long term after washing it in the next few days. It's been mostly outside since August of 2017 when our S60 was purchased as that got the prime spot in the garage.
I don't expect to be doing anything with it aside from getting an oxygen sensor bung added into the current header so I can monitor and fine tune it with the AEM Uego setup I bought earlier this year.
In real news, it's registered as a classic/special interest vehicle now so I can drive it again! Only to special events... Haha. Good enough though, with how much use it has been getting anyway! I'll just need to get back to organizing events or going to other people's events again when I want to drive it.
Old 09-25-2019, 07:39 PM   #802
Coupid
Coupid's Avatar
That's awesome to hear the 244 is still alive and kicking! You'll have it whipped back into shape in no time
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 09-26-2019, 04:30 PM   #803
klr142
Turbo, what?
klr142's Avatar
Well, I don't know about that... I have to make the General Leif run with my free time and then go race it! But maybe this winter I'll dig into it some. We shall see!
Old 10-02-2019, 03:12 AM   #804
mblue240
mblue240's Avatar
'Bout time! You can also drive it for maintenance and stuff...I take my car out for "tuning" every once in awhile.
-Michael
Tbricks build
Yep, Michael is right.
Old 10-08-2019, 08:22 PM   #805
klr142
Turbo, what?
klr142's Avatar
Yes, indeed! Did you take your front license plate off? I'm probably going to.
On another note, I got the AEM UEGO wideband installed and it's read properly 3 out of probably 10 key cycles... It hovers around 13.4-13.7 regardless of what the engine is doing and flickers every once and a while to 14 or so. I don't know why, and haven't had a chance to look into it.
The check engine light also turned on, and I haven't looked into why, but it's probably something to do with the tuning I was trying while trying to get through DEQ? I'll find out one day.
It's stinky like it's burning oil(maybe valve guides/seals but the cylinder bores aren't great either), and I have some lightweight factory rods(9mm) and some new oversize factory pistons if I want to rebuild this motor or another one with factory parts someday. I'm undecided if I want to use factory or something modern(lighter weight and coated), though. It should probably be modern as the car doesn't get used much anyway, so who cares about 200k mile longevity as long as it's done well it should be fine and better for my needs/wants? My ported, big valve 530 head would be nice to put on to give it more performance again, but at that point I should probably just yank the engine. Bearing Service isn't cheap to go through it all, though!
While I'm driving it around with the S60 at the dealership for a new injector(!), the right taillight's parking lights don't work. Stupid taillights...
There's some suspension noise over bumps up front(always has been from the rear shocks, I think the bolts that go through the frame rails have hollowed out their holes a bit), but I just had some used coil-overs delivered from Harald that I can one day get around to installing. It may or may not fix the problem.
Then there's the part where it's been neglected over the past two years and sitting outside without being washed regularly enough. I washed the car finally and it looked like crap still wherever there was stuff on the paint. Then if you ran your hand over the paint, it was like fine sandpaper so I ran my "clay bar" wipe over most of the top surfaces and it's sooo much better, but there are defects in the paint all over the place that are still there. Even in the clearcoat. DON'T NEGLECT YOUR CARS, PEOPLE!
One day I'll have a professional try and do some paint restoration on it, but I don't think it'll help as much as I'd like. Maybe it'll get taken down to metal and stitch welded one day when I become rich and famous.
Old 10-08-2019, 10:01 PM   #806
Those inserts are brand new!!
Old 10-09-2019, 12:27 AM   #807
klr142
Turbo, what?
klr142's Avatar
Haha, but the coil overs are not! Thanks dude! I might want to grab new sleeves, springs(beehive so they don’t rub?), helper springs and the lux steer stuff before I install them someday. I feel like 450 will be a little stiffer than I want for the car, considering it’s so nice and cushy now before it crashes on the bump stops... We’ll see.
Old 10-09-2019, 12:54 PM   #808
I thought you drove my car on this front suspension before. Pretty sure that it will feel overdamped with anything lighter.
As for beehives and helpers: these sleeves were worn from being used with 7" 250#s before, and there is little benefit from a helper if you use the 10" springs included. There is really no need to replace the sleeves. Additionally, be wary that you might encounter clearance issues between your wheel/tire package and bottom spring pervh. That mentioned, you could try 450# 8" springs with tenders if you are really that worried about it.
One last note: it will be low. Would consider having Ben cut you spacer plates if you end up being unhappy with the ride height/available droop.
Old 10-09-2019, 03:34 PM   #809
klr142
Turbo, what?
klr142's Avatar
As for beehives and helpers: these sleeves were worn from being used with 7" 250#s before, and there is little benefit from a helper if you use the 10" springs included. There is really no need to replace the sleeves. Additionally, be wary that you might encounter clearance issues between your wheel/tire package and bottom spring perch. That mentioned, you could try 450# 8" springs with tenders if you are really that worried about it.
I likely have driven your car on this setup before, but I didn't pay much attention to the ride as I was mostly likely paying attention to the power.
To clarify, even with the 10" 450lb springs in there it'll be low because you can't raise the lower perch as high as one might want due to the clearance issue the lower perch will create with the wheel/tire? Or if you go higher the car will not have much droop travel at that point anymore? The point of the helper would be to help keep the inside wheel on the ground to the extent of droop possible after the main spring comes unseated(if it does with the 10"?).
Thanks for the further information!
Old 10-09-2019, 03:37 PM   #810
The 10" spring will always have a little bit of preload if the car is not absolutely dumped. You will likely want it as high as it will want to go as well, for what it's worth.
Old 10-10-2019, 11:48 AM   #811
klr142
Turbo, what?
klr142's Avatar
Ah, ok. So there isn't much droop, you're saying. That's not optimal for uneven surfaces. I guess I'll play around with it one day and may need something else. I scraped my exhaust twice this morning going over a speedbump slowly enough already... *sigh* These are Saab length inserts, correct?
Old 10-10-2019, 12:41 PM   #812
Correct. Like I said, get a spacer for the strut mount so you can get your strut travel optimal, based on the fact that you aren't into hot sexy stance anymore
Old 10-10-2019, 01:26 PM   #813
klr142
Turbo, what?
klr142's Avatar
Well, it's not exactly anywhere near factory ride height as it sits... It tucks the tires some up front, barely, so we shall see.
Old 10-10-2019, 01:31 PM   #814
in that case if you wanna keep it at that ride height, throw on the 450s as is and see what's what.
Old 10-10-2019, 01:41 PM   #815
klr142
Turbo, what?
klr142's Avatar
The height probably won't be an issue if I have stiffer springs, so that's likely what I'll do, but I may need to go higher to get some more weight on the rear tires at some point. We'll see when I one day get around to putting it on the scales.
Old 10-10-2019, 02:05 PM   #816
In that case just lower the ass end of the car. Some shocks, springs, and adjustable perches will only set you back $600 new, unless you decide to fab yourself some fancy ass QA1 coilovers or something.
Old 10-10-2019, 03:26 PM   #817
klr142
Turbo, what?
klr142's Avatar
Yes, yes. Maybe.
Old 10-12-2019, 07:31 PM   #818
mblue240
mblue240's Avatar
Did you get an SP plate? The 83 and 89 both have SP plates, since they wouldn't let me run trees or the new Wonderland. Once they stop making Wonderlands I'll pay the $15 to transfer my plate back on the 89, but still only run the rear. I have vanity Euro plates for the front on my xmas list. The new '84 needs to get registered as an SP too, but it has the original yellow and blue plates that we should be able to keep.
Old 10-14-2019, 02:20 PM   #819
klr142
Turbo, what?
klr142's Avatar
I did not get a SP plate, I still have the standard tree plate... She just asked me if I wanted to keep the original plates or not, if I remember correctly.
Old 10-14-2019, 05:40 PM   #820
mblue240
mblue240's Avatar
That's weird. I was pretty sure (and was told the same when I registered all the cars) that you can't use any plate that is currently in production. I was able to use the old blue plates on the 142, since they're out of production. I was told if I didn't want SP plates on the others I would need to find period correct plates. That just supports everything I read in my research that DMV employees really have no idea what's going on with registering vintage cars.
Old 10-14-2019, 06:23 PM   #821
klr142
Turbo, what?
klr142's Avatar
Crazy. There are a lot of rules that most people don't know about, so it doesn't surprise me! I guess this makes it easier to blend in? I'm ok with that...
Old 01-12-2020, 03:40 AM   #822
klr142
Turbo, what?
klr142's Avatar
Man, the first post of this thread is sad. No pictures now that OVT's website is gone. I added at least one(old) picture of the car for now at the bottom.
Anyway, the check engine light was for an ECT sensor signal fault, which as most with LH2.4 know is a pain in the butt that is usually caused by a poor ground connection where the two grounds at the fuel rail splice into the wiring harness below the intake manifold. The light was being triggered almost every time I drove it after having it reset so I drove it into work this last Friday expecting it to come on again, but it didn't. So, instead of playing with that, I swapped the white top 16V injectors back in and some Denso Iridium Twin Tip modern spark plugs to take advantage of modern technology in one way and get rid of it in another. The pink body p2 injectors I was running have 4 holes but are a split beam pattern that isn't ideal. I have some larger EV6, more modern injectors in mind for the future if I get around to it. They're larger than turbo injectors though, so overkill for what I'm doing unless using E85. I don't know if I'll need to do that, though, as the General Leif isn't spark limited for MBT on pump gas even. It does have a grooved head though, so maybe that's why. I won't be doing that with the big valve 530 head.
I also got a replacement wideband oxygen sensor kit from AEM under warranty with no complaints and it is working fine now(sensor was the main culprit, I think). Its GREAT to have a working wideband in the car again! I like dialing in the fueling and have been driving around with the lambda correction turned off. I only drive the car 1-3 times a month, but it's nice to get it dialed back in.
Speaking of getting it dialed back in, the pink body injectors required me to take a good chunk of fuel out to get them to reasonable AFRs with lambda feedback turned off! I wasn't expecting them to be that bad. In any case, I went from running the stock Injector Constant 1 value of 131 to 115 and my AFRs were back in line with lambda off. When I put the white top injectors in(that may need to be cleaned as they've been sitting unused for the past 3 or so years), I bumped the IC1 up to 125 and everything was damn close right away. I have tweaked the map a bit more and am happy with it for now I think.
I also burned three different ignition chips(all with less advance than stock) after finding out with the General Leif on the dyno that I've been running too much ignition advance on this car forever, hence the detonation problems. I'll have to get it on a dyno and dial it in more once I get the big valve head back on.
I also played with the idle speed settings to somewhat replicate the more modern cars where they idle high after the car is first started to help the engine and cat warm up. I haven't found the right table(if it exists) where it raises the idle speed for "X" amount of time after starting, so I just bumped up the idle speed when the coolant temps are low. Not ideal, but it helps it warm up a little faster and idles smoother.
I need to find room in my garage to get all the junk out of the trunk as I currently have Harald's coil-overs and some other misc. parts just sitting back there. It has a ton of grip in the wet like that but it's not good for slipping around enjoyment or cornering fast!
Oh, at some point in the past year, the headrest supports broke on my driver's seat so I swapped in a seat Marc had lying around. It also sucks, but it is at least mostly intact. I need to figure something out to replace the seats with something that is actually performance oriented or rebuild my original. I don't take much of any time to look into this stuff or work on this car anymore... The General Leif gets almost all of my car stuff, or I am always researching camshafts....... Hah. More power to come from that thing this year, and hopefully this thing, too!
I will be dropping the General Leif's stock valved 405 head and my 46/38mm 530 head off at a machine shop hopefully later this month to be flow tested. I will also have them shave another .040" off my 530 as it only has .040" off at the moment to bump this car's static compression ratio up further to better match the ENEM K13 camshaft that I'll probably put back in it. It's currently in the 405 head on the General, but we're going to go wilder in that this year.
Here's an almost 2 year old picture(thanks Ansel!), as I apparently don't have much of anything more recent. Makes sense considering the car has been driven probably less than 30 days in the past two years, total. Maybe more, but not much if so!
File Type: jpg 29983214_10155993038131357_5116164190406639115_o (4).jpg (78.2 KB, 115 views)
Last edited by klr142; 01-12-2020 at 04:04 AM.. Reason: Needed a photo! Too wordy, no action.
Old 01-17-2020, 08:59 PM   #823
Jerd
Jerd's Avatar
Excellent. Happy to hear about progress.
