Old 09-25-2017, 09:32 AM   #301
Tfrasca
Tfrasca's Avatar
Originally Posted by toms_elleck View Post
Best car on Turbobricks right now.
While I can't say I agree with that, I appreciate the sentiment!
Old 09-25-2017, 09:36 AM   #302
Tfrasca
Tfrasca's Avatar
Yesterday, I set out to get some sound clips of my exhaust. Ended up just driving around like an *******.
Old 11-13-2017, 09:04 AM   #303
guru69
F
guru69 is offline   Reply With Quote
Old 11-14-2017, 12:17 PM   #304
Tfrasca
Tfrasca's Avatar
This is quickly spiraling out of control:
I plan on getting the T5 installed this winter. Shouldn't be too dramatic, especially now that I have a garage to work in. Doing this engine swap in an open driveway last winter was ridiculous.
The 16v will be a much longer term project. Next year, at the soonest. That said, when I start that, I'll want to sell my 8v head, injectors, fuel rail, intake manifold, downpipe, and maybe manifold/turbo set up. All that stuff would make an OHC swap relatively bolt-on for some 140 owner...
Old 11-14-2017, 08:07 PM   #305
HUB
Needs more cowbell
HUB's Avatar
Love the car as always. Video made me smile. Sent you a PM.
Thanks,
HUB is offline   Reply With Quote
Old 11-15-2017, 01:38 PM   #306
cosbySweater
cosbySweater's Avatar
Ruh roh!!! Looking forward to this!!!
1995 Porsche 993
Old 11-15-2017, 01:49 PM   #307
Pro Sneaker Peddler
Ooooh, more goodies!
PS: have you run the Forge valve backwards yet?
Old 11-15-2017, 01:53 PM   #308
Tfrasca
Tfrasca's Avatar
We're going to have to wait for quite a while. Plus, I just got this thing tuned as is and it rips at 12 psi!
Yup, tried it both ways and it's basically the same, noise and operation-wise.
Old 11-15-2017, 02:53 PM   #309
Pro Sneaker Peddler
Interesting. In my car it makes very different sounds depending on orientation.
Old 11-15-2017, 02:54 PM   #310
Tfrasca
Tfrasca's Avatar
Hmm. Maybe I didn't actually switch it. I've tried so many things so many different ways on this car that I'm losing track.
Old 11-16-2017, 11:00 AM   #311
SquareD
An Anomaly
SquareD's Avatar
Yes! Great progress and a promising update. Love the video. Hooning is why you bust all those knuckles.
Old 11-17-2017, 01:08 PM   #312
Tfrasca
Tfrasca's Avatar
Thanks! It's easy to forget that when the thing just sits for so long. That's why I want to do the T5 and 16v in two separate stages, rather than just ripping the thing apart for another 6 months.
Old 11-27-2017, 05:33 PM   #313
Tfrasca
Tfrasca's Avatar
By the way, I switched the Forge bypass valve around and it makes less noise at part throttle. Nice, audible bypass sound when letting off, but no weird miscellaneous whistling. Thanks, Harlard.
Old 11-27-2017, 06:48 PM   #314
Pro Sneaker Peddler
Weridly enough, it seems to work better mounted backwards
Glad that tidbit helped.
Old 12-17-2017, 06:01 PM   #315
Tfrasca
Tfrasca's Avatar
Boring update:
I have decided to put the 16v thing on hold more or less indefinitely. This car needs so much more work to be totally reliable, so I'll spend my time on the T5, rear end/LSD, suspension bushings, etc.
Also, I have been trying to use a TurboXS HP boost controller to get a steady 15 psi, but I couldn't get any reliable performance out of it. I over boosted it a few times, and during that process, lost a freeze plug. That was really annoying, and I never want it to happen again. All the retainers on the market are for B230s, with no option for a B23. I made this and I think it'll work:
When I was pulling the turbo off, I found that my Aeroquip return hose was on the verge of cracking from the heat. Don't use it for that application, I guess:
Replaced it with a braided steel hose from the local shop:
Hopefully I can just drive it for a while then get the T5 in before the Coastal Range Rally in February.
Old 12-17-2017, 06:38 PM   #316
Pro Sneaker Peddler
Soooo what's your price on the 16v stuff?
Old 12-17-2017, 06:59 PM   #317
Tfrasca
Tfrasca's Avatar
Can't commit to selling yet. I pretty much want to get the 8v running well on 15psi, get the fuel system and drivetrain sorted, then decide if I want to make more power.
I'm 90% sure that at that point, I'll want to make more power.
Old 12-17-2017, 08:05 PM   #318
M.H. Yount
M.H. Yount's Avatar
".....on the verge of cracking...." LOL - I think you went right past the 'verge' line....glad you caught it before it failed in operation. FWIW, I think your approach of taking care of fundamentals first before 'upgrading again' is a sound one.
Old 12-17-2017, 10:09 PM   #319
Tfrasca
Tfrasca's Avatar
Yeah, I guess I should say it was on the verge of cracking clean in half. Lucky I happened to lose a freeze plug before losing an oil line.
Old 12-17-2017, 10:27 PM   #320
LC4CARL
Aero challenged
LC4CARL's Avatar
Love this car!
Life begins at 10PSI.
Old 12-19-2017, 12:11 PM   #321
HUB
Needs more cowbell
HUB's Avatar
Keep up the amazing work!
Old 12-19-2017, 08:12 PM   #322
77volvo245
77volvo245's Avatar
Are you running a b21ft-b23 stock bottom end?
STSmachining
Old 12-19-2017, 11:04 PM   #323
Tfrasca
Tfrasca's Avatar
Love this car!
Thanks, guys. Glad you appreciate it!
Stock crank and rods, and I'm using the B23ET pistons that were in it from a previous rebuild. I also put BMW squirters in it, but whatever.
Old 01-08-2018, 04:07 PM   #324
mocambique-amazone
Hello Tfrasca, where did you find this downpipe flange TD0$ -> 3" ?
Thank you, very nice car. Regards, Kay
Originally Posted by Tfrasca View Post
So, here's the radiator solution I came up with. I kept with the overkill theme. I'm super happy with the way the mounting system came out. I just copied the stock set up, but had to move the whole thing forward a couple inches for fan clearance. It uses all the stock 140 bushings, so vibration shouldn't be an issue. Noah's welds are great, and it was rad to watch that happen.
This is what I ended up doing for the alternator bracket. It's bolted to an M12 stud that I tapped into the block, and the tensioner is made from a combination of B20 parts and a generic curved arm from the local parts store. It's pretty tight between the idler arm mount and the alternator, but I'll have to wait and see how much engine movement there is.
Here's the beginning of the 3" downpipe. You can also see the repair I had to do to the exhaust housing stud when it snapped off yesterday. I ended up having to drill it out completely and cut a shoulder on the backside to use a bolt. Pretty lame, but it'll work.
Pretty slow progress, but now that the radiator is mounted I can work my way forward with the intercooler and oil cooler, and things should progress pretty quickly from there.
Old 01-08-2018, 04:30 PM   #325
Stiggy Pop
Stiggy Pop's Avatar
Going back a few posts but I also found my aeroquip drain hose cooked through during an engine pull. Actually mine was cooked THROUGH underneath a DEI heat sleeve, I can only assume it didn't leak because it was on top of the hose at a bend.
I replaced my hose with same and put it on the consumable list. My hose cooked through despite being wrapped in DEI heat sleeve then sprial wrapped in DEI heat tape. I just don't think any rubber hose is going to survive surrounded by a header. The braiding won't hurt, but I would plan on keeping an eye on that hose all the same.
'79 242
943 pickup
