Pdx dl
Cleaned the T5 and M46 bellhousing. Throw-out bearing sleeve installed, new input and output seals installed, flywheel resurfaced, pressure plate on the way. STS driveshaft carrier bearing arrived. Custom crossmember on hand. Going to start with a cable set up. Will need to shorten front driveshaft and order a rear mount.
What am I forgetting?
Birthday next month / any shifter recommendations?
So far I am liking the Summit shifter (Steeda knockoff) better than the Hurst, despite not being as nicely made.
Culberro set me up with a sweet deal on a 3.73 ring and pinion.
To go with with the sweet deal that Harlard gave me on a clutch-type diff.
Should be a good match for the T5 ratios and allow me to go anywhere with the snow tires.
Lol you make it sound like I actually charged you money for that diff. I'm just glad you took it without question!
