Old 02-21-2019, 04:58 PM   #276
Canuck
Frozen Garage Hell
Canuck's Avatar
Thanks! I really appreciate the support.
- Craig
1966 Canadian (B5234T, C4 up front, Supra out back and a nut in the middle) http://forums.turbobricks.com/showthread.php?t=328003
1981 242 (B230FT, LH 2.4...and a few other things)
YouTube channel covering Canadian build https://www.youtube.com/channel/UCsx...n3CiBQFd4rMyXw
Old 02-24-2019, 09:47 PM   #277
Canuck
Frozen Garage Hell
Canuck's Avatar
Quick update.
Things are still moving at a glacial pace...at least it matches the weather. The floor frame got welded in with about a thousand screws to secure the panels! I know it's overkill - but it won't rattle.
I spent an entire weekend getting the final fitting done on the panels and building the dead pedal. It's now done.
I have since turned my attention to the projects that were left half done and have started getting those done.
Things like engine mounts.
Done.
Then the oil pan has been half done for about 6 months - so I fitted up the various parts.
And then welded it all up. No leaks.
I'm not sure what I should attack next...could be interior rear floor pans or I could get the anti roll bar installed. Both need finishing.
Old 02-24-2019, 10:24 PM   #278
evolvo67
evolvo67's Avatar
Craig, how do you check for leaks, water? I was taught many years ago a great way to check welds for leaks and I've mentioned it a time or two here on TB. A pint of rubbing alcohol with a few drops of red food coloring. For your pan I'd guess about a cup of this poured into the pan a swished over all the welds would do. Put the extra back in the bottle. If there are cracks or pinholes they show up as red lines, it's sort of a poor man's NDT!
Bored member
Old 02-24-2019, 10:26 PM   #279
Canuck
Frozen Garage Hell
Canuck's Avatar
That's a great idea Alan - I normally use windex as it's easily seen. I'll be coating the inside with a bit of Devcon to ensure no leaks.
Old 02-27-2019, 06:14 PM   #280
Canuck
Frozen Garage Hell
Canuck's Avatar
Tada - we've got an oil pan video.
Old 03-06-2019, 01:37 PM   #281
Canuck
Frozen Garage Hell
Canuck's Avatar
