Old 04-27-2010, 03:46 PM   #101
J2_
J2_'s Avatar
Looks like alot of blowby in your catch can ?
Lookin' good as always JW !
J2_ is offline   Reply With Quote
Old 04-27-2010, 03:56 PM   #102
JW240
All idiot, no savant
JW240's Avatar
Thanks!
In 2 weeks of driving (maybe 500 km?) the 33cl bottle got about 1/4th filled with beer-colored liquid with a few drops of oil in it. Mostly looked like condensed water to me (smelled a bit like fuel+oil). I cant see any vapor in the clear hose when the engine is running, the hose is semi-see-through (the hose is faded so it almost looks like there is always smoke in there hehe). I was wondering if it was a lot of blowby stuff or not.
Old 06-12-2010, 04:27 PM   #103
JW240
JW240's Avatar
Time for another small update. Still going strong.
Bought an underdrive pulley at KL-racing, 120 mm diameter. Racing-blue! Was cheaper than a new Volvo harmonic balancer. The underdrive part isn't really important to me although it could help a smidge with improving fuel economy and the water pump won't cavitate as fast when the engine sees higher rpms.
Old 06-15-2010, 06:18 PM   #104
Janspeed
your planning on reaching 8000+rpm?
benefit is less rotational mass. 3 beltrows, good buy, i need to remeber that...just like your gearbox/downpipe support bracket < a thing of beauty!
how is your car holding up? is it reliable?
Old 06-15-2010, 06:21 PM   #105
Janspeed
Originally Posted by JW240 View Post
Thanks!
must be blow-by watervapor , E85 burns very clean.
Old 06-16-2010, 07:06 AM   #106
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
This... i need to get around fixing mine for 3" its not suported anymore.
Anymore updates on the car?
Old 06-16-2010, 02:35 PM   #107
JW240
JW240's Avatar
8000 rpm? in my dreams
No plans to turn up the rev limiter yet, i rarely go over 6K anyway, although it keeps pulling very good up to those rpm's
Martijn gave me a water pump with the stamped impeller (almost brand new one from a rebuilt block). Those water pumps can cavitate at higher rpm's I've been told. This pulley minimizes the chance that it will cavitate.
Yeah the support is nice to have. my exhaust never scrapes on the road, not even on speed bumps and (easy/light) dirt roads. No resonances etc.
Car is holding up great, no problems. I need to tighten some suspension stuff, still a few clunck noises on speed bumps, need to replace fuel filter and install a better radiator, small stuff. Has been reliable so far, the road holding is good too!
Today I did a few tests where traffic allowed (=no traffic) and noticed that it suffers a bit from the wagon pendulum effect (front end stays planted but the back tries to come around slightly after steering input), especially when (engine) braking. Maybe i need to adjust the shocks in the back? and drag less crap around in the trunk
I bought this last month, time for musica.
Ebay special Alpine MRV-T300 amp, 2x50w rms, €15 . It is a small amp but don't be fooled by the size of the ball bearing it is resting on, thats a ~200mm unit (used as a Presse-papier as you can see).
Not sure where/how I am going to install it yet.
Old 06-16-2010, 03:46 PM   #108
klr142
Turbo, what?
klr142's Avatar
What swaybars do you have on it? Sounds sort of similar to having too large of a rear bar and too much roll up front, just like all 240s...
Old 06-16-2010, 04:37 PM   #109
JW240
JW240's Avatar
25mm front (with spherical bearing endlinks) 22 mm rear. Good to get feedback from you, you have tried+tested+autoXed much more than I have
Old 06-16-2010, 05:30 PM   #110
volvo78244
Ring apprentice
volvo78244's Avatar
+1
Need to do some work on mine too. I was thinking today of bending a piece of stainless steel as a support bracket.
2005 V70 - 2.4D
2003 S60R (sold)
1998 S70R (sold)
1993 960 B204FT
1992 740 B230FD
1990 960 B204FT
1987 340 B14E Variomatic (sold)
1982 242 B230FK
volvo78244 is offline   Reply With Quote
Old 06-16-2010, 06:47 PM   #111
klr142
Turbo, what?
klr142's Avatar
Cool. Maybe next will be a set of Ben's roll correction spacers then. Once they're available, anyway. I can't wait to see what they do for my car.
Another thing that helps give the feeling you describe is the stance of the car, more rake increases that feeling of the rear wanting to swap places with the front under deceleration. Some of it is normal for the car want to tighten in, but if it's really feeling like it wants to loop around, stiffer front, softer rear, and/or less roll in front, and/or lowering the rear/raising the front will help.
Old 07-29-2010, 12:09 PM   #112
JW240
JW240's Avatar
During my visit to the Nürburgring I had a chance to test the car properly and there I didn't experience the issues i described before. Maybe because I drove a bit slower there because I had to get used to the track, I dunno. The car performed well. Very predictable and enough power to haul around the track up the hills with ease, even with 4 people in the car. Brakes didn't fade. The tires are the weakest link now, first a set of good tires with 16/17" rims. Maybe Tethys. It depends on what I can find for a good price.
About the handling: I did put a few shims between the rear spring top mount to make the car sit a bit more level, it was really leaning backwards with the lowering springs. Maybe that changed things too (in a bad way).
Pic of my car at the parking lot. No pics of it on the ring though except for one that Homer took, need to put that one online. There are a few in-car movies that probably will find their way online one day.
Before the Nürburgring meet I swapped the radiator, spark plugs (Volvo Penta, one heat range colder than stock) and some other stuff together with Homer. No cooling problems on the ring. Oil went to 95-100C, water temp went just over the middle. Not bad for another second hand (turbo) radiator.
The engine-mounts have always been a bit on the weak side, especially with now it is turbo. After the Nürburgring I noticed more driveline vibration. So I decided to make a 3rd engine mount:
Engine 'shock' of a Volvo 440, fixed to to the intake manifold and the Joshifab strut-firewall brace. We'll see how it holds up. After a short test drive it seems like it reduced the movement of the engine although the shock might be a bit weak. No interior noises though, except for some driveline vibrations on engine braking low speed, but I need to improve the transmission mount first since I think that is the cause of that issue.
Old 07-30-2010, 07:05 AM   #113
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Hey hey, slick looking mount there.
Now that you mention the transmission mount thing, i do remeber that long ago when i installed a Getrag in my 240 Turbo, i used two mounts at both sides of the transmission instead of just one at the back like the standard Volvo solution, and that did seem to reduce engine movement.
How was the 'Ring this year, did you go under 10? ;)
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 08-06-2010, 05:36 PM   #114
JW240
JW240's Avatar
Thanks, yeah the mount turned out good.
About the transmission mount, I found a semi good 240 engine mount (exhaust side), I'll try to make that one work.
On the Nordschleife I drove a ~12:30 (have to check GPS logger to get accurate time). Not bad for a first lap with 4 people in the car and being very social for other drivers
In the meantime I found this:
Volvo R-sport steering wheel, made by Momo. Not sure which model it is, it has p/n 8360887. After some good cleaning the leather came out great! The hub is for a 740 so i need to source a 240 hub though. The hub fits (same spline count/diameter) but the hub jams on the 240 horn contact ring etc.
Old 08-06-2010, 09:58 PM   #115
J2_
J2_'s Avatar
Wanna sell that 740 hub? Let me know ;)
Old 10-27-2010, 05:13 PM   #116
JW240
JW240's Avatar
Default Wumbo
The other 2 are still in the mail. They look a bit rough but no curb rash.
Plan: media blast, powdercoat in nice color, save up for good tires.
Old 10-27-2010, 05:50 PM   #117
Mr.Borrie
Mr.Borrie's Avatar
Nice where did you get em
Old 10-29-2010, 03:14 PM   #118
Wagner
Wagner's Avatar
De aap komt uit de mouw! Real Polaris wheels. A definite upgrade over Virgos. (i have no idea what that means, something with apes possibly )
I vote for silver or white.
Old 10-29-2010, 03:53 PM   #119
gj940
gj940's Avatar
Nice wheels JW, gonna look great on your ride.
Dutch 940 LPT on BBS
gj940 is offline   Reply With Quote
Old 10-30-2010, 01:16 AM   #120
J2_
J2_'s Avatar
Welcome to the polaris club ;) haha
Old 10-30-2010, 02:33 AM   #121
Mr.Borrie
Mr.Borrie's Avatar
I just knew you where gonna pop up ans say it
Old 10-30-2010, 06:04 AM   #122
Dirk242
'98 Volvo V70
Dirk242 is offline   Reply With Quote
Old 11-11-2010, 02:01 PM   #123
JW240
JW240's Avatar
lol! It has nothing to do with apes actually More something to say when after a long time the real cause of something is revealed.
I think I'll go for a little bit darker than the original silver. White would look very good too but i might get tired of cleaning the rims
I received the other 2 rims last week, those look better than the other 2.
The tires are old (2005) and not a great brand so I'll probably go for something better if/when funds allow. 215/50 tires on there now. Please ignore the fact that this wheel is fitted on the wrong side of the car (directional tire)
One very annoying thing is that on 2 rims the previous owner had trouble removing the lockable lug nuts. While welding a nut/bolt to the lock they actually welded into the rim, lodging a pretty big chunk of steel in the rim right next to where the lug nut goes It looks fixable though. I found a local company that specializes in fixing this kind of stuff. A complete wheel refurbishment isn't that expensive there luckily.
oh and i got a set of Lokari inner fenders for the rear wheel wells, i think that they'll stay better with those installed. For the winter the 87 degree t-stat found its way back in the engine bay as well (had 82C in there), i think I'll keep it in there for the summer too, hoping that it improves the fuel efficiency a bit too.
Old 11-11-2010, 02:56 PM   #124
Mr.Borrie
Mr.Borrie's Avatar
Wow for a second i thought it was Homers car till i saw its an estate.. looking clean JW!
Old 11-11-2010, 03:15 PM   #125
OldSchoolEuro
We should start a Polaris club.
OldSchoolEuro is offline   Reply With Quote
