Old 04-11-2012, 03:29 PM   #151
klr142
Turbo, what?
klr142's Avatar
Sweet. Must feel great!
Did you drive it at the Nurburgring? I'm planning on renting a prepped car late August or early September and going around it...
Old 04-11-2012, 03:46 PM   #152
JW240
All idiot, no savant
JW240's Avatar
I took the car for a short test drive after fitting the wheels, felt very stable yeah and much better than with the old (badly) worn out tires that were on the other set of Polaris rims. Those wheels came from a 940 with worn out suspension so they were worn to positive camber lol. Coupled with the ~-1.5 camber my car has makes for an interesting driving experience when the road isnt 100% smooth.
I drove it on the ring in the summer of 2010. Planning to take it back there this summer a few times. The ring is about 150-200 km away so i should visit it more haha. Drop me a pm if you like when you are there, i might have time to go for some laps then too.
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 04-11-2012, 03:48 PM   #153
JW240
JW240's Avatar
oops, dp.
Old 04-11-2012, 03:53 PM   #154
klr142
Turbo, what?
klr142's Avatar
Will do!
Old 04-11-2012, 04:10 PM   #155
Gerb
What did you pay to fix the rims? I have a set of alloy's for my wintertires but they are pretty messed up; Swedish winters plus snowchains....
Gerb is offline   Reply With Quote
Old 04-11-2012, 04:16 PM   #156
volvo78244
Ring apprentice
volvo78244's Avatar
Originally Posted by klr142 View Post
Will do!
Double that pm, I'm always in for some fun.
Rims are looking great JW. I plan on having my second set coated black, not sure though.
Time to test them on the ring, name that date.
2019 Peugeot Expert
2005 V70 - 2.4D
1992 740 B230FD
1982 242 B230FK
volvo78244 is offline   Reply With Quote
Old 04-11-2012, 04:45 PM   #157
Turbosteen
I was born at a young age
Turbosteen's Avatar
w00t, two tb meets this year lol
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 04-11-2012, 05:27 PM   #158
JW240
JW240's Avatar
Yo Gerb, prices are here: http://www.wheelcare.nl/id29.htm
"Rand oplassen, afdraaien, stralen en poedercoaten t/m 18" €57,50" ex btw. Turnaround exactly 1 week.
Time for the Nordschleife meet this year? No date set yet
Thnx! Really happy about the result and it is nice to see the rims that i've had since end of 2010 finally on the car.
I would like to go to the circuit of Zolder as well, maybe before the Nurburgring meet this year. Need to check the price and availability on the skylimit events.
Old 04-11-2012, 05:41 PM   #159
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
wait a minute! theres a tb meeting in germany this year?!
Old 04-11-2012, 05:45 PM   #160
JW240
JW240's Avatar
Nordschleife, around July, every year since 2008
Old 04-11-2012, 05:46 PM   #161
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Where have you been!
Old 04-11-2012, 05:47 PM   #162
DennisvdB
DennisvdB's Avatar
I just read here there are more TB meets at the Ring this year ;)
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 04-11-2012, 07:40 PM   #163
spourcyrous
Amazing! Have been following this one for years, love the color, love the polaris, everything.
spourcyrous is offline   Reply With Quote
Old 04-12-2012, 03:53 AM   #164
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
u be there ?
Old 08-12-2014, 04:00 PM   #165
JW240
JW240's Avatar
Default still going strong!
Some small updates. Over the last 2 years it has remained my DD (and still is!). Worked on a few things to make it better suited for that.
At a huge music festival campsite, ideal car for that! Loaded with bikes, camping gear, drinks, food, tools, etc etc! Saw more 240s there, damn hippies!
Bought a Truetrack from www.bakaxel.se. Not installed yet
High preload version.
Turned a set of new bearings into set-up bearings. The material was surprisingly easy to cut (removed ca 0.03 mm IIRC) and gave a very good surface finish. Thanks Volzuki!
Autumn 2012 I repaired the rear brakes. Dust covers were ripped etc.
New inner tie-rods at that time too.
Autumn 2013 I replaced the front wheel bearings. They were filled with mud and the seals were worn.
Found out why the rear end was so noisy:
Severe cracks in the poly bushings of the torque rods. They were used since 2007 and roughly 30K miles? Replaced them and that improved things. Still need to make spherical bearing inserts for the trailing arms, those still have rubber bushings that are worn worn worn!
While I replaced the front wheel bearings it was time to give the calipers some attention as well. The inner pads were worn to the last 0.5 mm and the outer pads were still fine.
Pistons cleaned/polished, new seals, new covers, new bleed nipples, pads, mounting hardware etc. The braking imbalance between left and right mostly is gone now!
The pedal is slightly soft after a good bleed, not sure where I can find the culprit. I think the pads wear evenly now but to be honest I haven't really looked hard. Nothing was wrong when I changed wheels so. Oh speaking about wheels, I bent one of the Polaris rims. Pothole+high speed+very stiff sidewall = damage. Now cruising on borrowed Multi-X.
Everyone likes shiny parts!
For now good enough, never needed more brake. This only cost a little money and lets me go on for enough time. Then I can see what to upgrade to when the engine is making more power.
Other small stuff:
-Removed the cone filter and fitted a 240 Diesel airbox. Made the intake piping from some old stuff that I had laying around so i need to address that. Car runs much better now the AMM isn't soaked in oil. The cone wasn't to blame for that, it was the short distance between the PCV return and the AMM.
-Switched from E85 to normal gasoline/E10. First I didnt change the chip and LH adapted well to it. Now I made a new chip for better WOT mixture (around .80-.85 lambda is what I shoot for, was .75). Car pulls well even before the chip change, 5.9s 0-100 km/h with a careful launch (to keep the engine mounts and clutch in one piece). Found out that it is pretty well matched to a 535D haha.
-Brodit charger/phone holder installed.
-Stuff I forgot.
Plans:
-Better speakers (and small subwoofer in trunk)
-Some soundproofing (doors, floor, dash?)
-Spherical bearings in the trailing arms of the rear axle. Have designed something, just need to find time to make it.
-Install truetrack, paint rear axle
-Remove rust on right side near rear wheel
-Paint side trim on doors and attach one that is falling off
-Install the new shadowline stuff
-New windshield
-New/better catchcan. After new airfilter this was just ziptied near the radiator
-Install windshield washer reservoir.
-Some homebrew bracing for the front axle
-Repair bent Polaris rim
Right now the 240 has a few quirks and things to improve but nothing too serious. Gives me time for other projects as well! Multiple projects lined up, Amazon, 760 T6, maintaining the fleet of family cars, improving the workshop etc!
I can't resist to post a pic of one of the nice workshop upgrades, a real milling machine. At 4500 Lbs, 5,5 hp and over 3 feet of travel it is quite a serious mill. Now completely disassembled for repairs.
Old 08-12-2014, 06:39 PM   #166
klr142
Turbo, what?
klr142's Avatar
4,500lbs is a lot!
Glad to hear the old girl is still kicking.
Old 08-13-2014, 05:33 AM   #167
Råda
Volvoretard/Partshoarder
Råda's Avatar
Nice car, seems like a good DD
Jonas
Old 09-02-2015, 03:13 AM   #168
JW240
JW240's Avatar
Not much has happened, except for driving!
Made a chassis brace that I have been meaning to do for a very very long time:
The downpipe was made/designed with this in mind.
Need 2 more Inbus screws for the passenger side of the brace, clamping the tube like that is no good.
First short test drive feels good.
Thinking of adding a piece of flat floor to this brace and capping the front of the tubes (angled) to prevent them from rusting inside and me getting stuck when offroading. Maybe some more flat floor extending to the front of the car, everything that helps MPG is good. last fillups were 25-27 MPG so i'm already quite happy.
300.000 km now. ~50.000 on the +T.
4,500lbs is a lot!
And I added some more:
6000 lbs. Nice for coilovers, flywheels, wheels, etc. 10 hp, 21x60. Last months changed all oils, cleaned lots of things, VFD retrofit with complete rewiring, repaired many little things, some new nuts/bolts/screws, new wipers, saving up for digital readout but at this size that is an expensive affair!
EDIT1: resized pics finally.
Edit B: not much of the list of last year has been tackled. No new winshield, no attached trim, lost another piece (waiting for paint in the workshop). I did repair most portions of the underbody coating and applied new stuff. Attached some loose interior stuff with rivnuts instead of crappy self tapping screws in the floor. Oh and the Polaris rim is fixed, all is good now.
Old 09-02-2015, 03:27 AM   #169
Arn02
Arn02's Avatar
Very impressive workshop you have. Wish I knew how to work the mill, or lathe for that matter.
Which one did you buy? Did you install it yet and if so, how do you like it?
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 09-02-2015, 03:52 AM   #170
JW240
JW240's Avatar
Hi Arno, Thnx! The workshop is a work in progress, I have the machines but I need to clean up or re-organize more often to make the shop/me more productive. Operating these machines isnt too difficult
Last weeks I have been working hard finishing lots of small stalled projects (or selling) so i am freeing up more and more space in the shop. Feels good.
The Truetrack is the 588 high preload model. Not yet installed in the 240, but my brother has the same in his 760. Works great. No noises. On backroads or with one wheel on sand other on tarmac it is still possible to accelerate hard, and/or make nice drifts on gravel. Even when driving away slowly on gravel driveways you feel the truetrack, the inside wheel wants to spin faster and leaves a trail.
Maybe not the real deal LSD for race use but for our use perfect, no maintenance, strong
Old 09-02-2015, 04:50 AM   #171
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
what a nice mill
Old 09-02-2015, 07:56 AM   #172
21x60 is a pretty nice size. Doesn't look that big in the pics.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-02-2015, 09:28 AM   #173
Beachee
Beachee's Avatar
Love your DD. Looks alot like mine. :-)
Beachee is offline   Reply With Quote
Old 09-02-2015, 10:01 AM   #174
JW240
JW240's Avatar
what a nice mill
Thnx, there is one on Ebay.de now (Tos FA3). If only mine was working, I stripped it down to the bare castings for repairs and paint. Still some work to do!
Yeah, the picture is a bit deceiving, the chuck is a 315mm version.
Forklift for scale:
Still working on the VFD retrofit and locating a noise from the gearbox. Already made some parts with it, precision and power seem to be good!
Note the dual feed tailstock with fine-feed and rapid lever etc. Some pretty cool features for a conventional lathe.
Wagon (wheel) twins! Am I correct that your 245 is black? a rare color, only seen a few!
Old 09-02-2015, 01:50 PM   #175
Beachee
Beachee's Avatar
Hello
Yes, it's black -86. Came with a tan textile interior. But it was changed with a blue............. Will be changed with a custom black interior from Edison Bender soon. The pictures is 2 years old by now.
Is not your black too? :-) Engine? My is a B230FT.
