thismachine13
- Sep 22, 2015
- Kansas City
'89 245 now a week with a +T install. I'm assuming that the added crankcase pressure that the turbo induces is enough to show every weak seal? Thought it was just the missing o ring at the oil separator box. I had noticed oil there and discovered whoever put it in last didn't use an o ring. Removed the oil separator, cleaned it well. Now it seems to be leaking pretty good and maybe at the rear main seal now too.
So is this common for after adding a turbo?
Thanks
Thanks
