Inside_the_box
- Jan 29, 2014
- Falls Church, Va
I've got an 87 240, the 3 pin connector on the side is broken. I ordered a new one and have removed the distributor. It looks like I need to remove the hall effect sensor to properly insert the connector. How do I remove this? Do I have to drive out the pin holding on the gear on the bottom and pull the shaft up through the top?
