- May 11, 2007
- Niketown, OR
There is a bin for lh 3.1. I am about to start experimenting with it myself!
Remember to test X70T MAF's! I'm tracking down linearization tables for 'em.
Thank you! I think I`l try it My friends tells me to build it back to original. But that would be a step backwards in my world I bought the car with the chip, and don`t know its history. But i think this would make it a lot easier.If you have an ostrich you can scale the injectors using injector contant 1 or 4 and use the AMM linerisation table out of the 950 bin with the switch points for that AMM. This should get you pretty close, then you just need to dial it in with the main fuel trim table. And like Kenny has mentioned best to do all of this with O2 feedback disabled so your not fighting the ECU.
Hi! Does anyone have a god guide to match the AMM with the injectors? My 940 got a 3" home made AMM and the 558 injectors.
My chip don`t like me or something and the AFR is too low.. I`m tired messing around with that chip..
I taught i would try Ostrich Then i can adjust fuel on a pc instead of making an AMM every time..
I do not have the drivers license yet, but I have a short farm road to test it.
Is this a good idea? I do not have much experience.
good luck with that. BP had a rom that would allow for datalogging, but it was... inconsistent. you could log wideband, load, rpm and go back and look at that in like MSLVV but you had to convert raw data from the o2 input (not a big deal). I did that when I couldn't address trace mine due to having an ancient ostrich. once I swapped over to the new ostrich, I just live tuned it like an old ms box, watch o2, watch map, make change, rinse, repeat.
it's not perfect, and I would strongly suggest you get someone to drive the car to do it, but that's the easiest way you're going to get what you want.
Also, the checksum needs to be fixed greatly, its working great in IPdown's program but not tunerpro. Jaybee?
Alzo, it seems like the main fuel trim table hardly adjusts idle fueling at all.
Agreed. That's the way to do it.I just save it on Tunerpro, then open lheditor and fix checksum. Open bin in tunerpro again and download to ostrich. Clunky I guess but it works.
Idle fueling isn't controlled by the main table, if you want to control idle fueling you need to hook up a variable resistor to the AMM and adjust it that way.
I have yet to see one of those in an -016 AMM.
Have you ever tried configuring the main fuel table at all or do you just enjoy
your own fantasies ???
YS
Jaybee
I have changed the fueling at idle by 10% on the main fuel table and seen no change to afr (I run in open loop all the time) if what I said is a fantasy I must be imagining the AMM pot enable flag in the XDF? Once you have changed injectors and re scaled them using constant 1 or 4 the idle is way out. I have 580cc/min injectors and have an injector constant 1 of 87, if I flash in a bin with the AMM pot disable then the car will idle at 17 -18:1.
If there is another way of doing this than the way I'm doing it I'm all ears.
You don't need resistors to tune 2.4.. we found the fueling and trigger table for idling..
