Old 11-01-2017, 05:04 PM   #1
jerryc
jerryc's Avatar
Default no temp gauge
95 940T. One year only inst panel.
The gauge used to work fine, no issues. Suddenly it does not move at all. Pounding the dash does not bring it up, as that 'fix' sometimes does on other panel issues.
The wires end in a two wire plug at the sender. Yes I am at the right one.
I believe that if I ground the right wire, the gauge will move if the problem is the sender. So which one? Or can I put a paper clip in the plug to connect the two wires to test, without damaging anything?
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 11-03-2017, 08:23 PM   #2
jerryc
jerryc's Avatar
bumpage; anyone?
Old 11-03-2017, 10:26 PM   #3
84B23F
84B23F's Avatar
Originally Posted by jerryc View Post
bumpage; anyone?
Working....on 1994, there's one power wire at gauge, and two wires that go to block-sensor. So, this block sensor would be a temperature dependent resistor, and one wire would go back to gauge. Both wires would be Yellow, with one having black stripe (I assume) and the other a white stripe.
With ignition OFF, I'd pull temp-sensor connector at block, and use an ohm-meter to see which wire was lower in ohms reading. Then, with someone watching gauge, with igntion on, see what temp-gauge reads with connector off. With your paper clip, touch one end to higher ohm reading wire, then touch an engine ground with your other hand to see if gauge moves...if not touch other side of paper clip to ground....my best estimate...I don't have schematics on temp gauge itself, nor do I know what resistance is at temp-sensor.
Oh this age! How tasteless and ill-bred it is.
-------- Gaius Valerius Catullus
Master Volvo List
Old 11-06-2017, 04:26 AM   #4
Wiring diagram and resistance checks.
