ha thanks its just primer. deciding on color. probably a bit darker green. the current setup is:
1979 242
Motor
Rebuilt B23F block about 40K miles ago (*non-turbo)
forged crank and rods, 96.6mm bore, ~10.7:1 CR (head and block decked), Mahle B23E pistons
All shortblock reciprocating parts balanced, including clutch pressure plate
Flywheel lightened ~8lbs
Turbo clutch
Euro #405 head, K cam, 48/38mm SS fluted valves, light port & polish, decked, double valve springs
SAM 4-2-1 Extractor header. 2.5" exhaust with single muffler, alu-ceramic coated
OEM Bosch K-jetronic
3 row Nissens radiator
2.5 exhaust
MSD 6AL box
Suspension
Bilstein dampers, iPd sport springs, iPd 25mm sway bars
All Poly bushings (F&R control arm bushings, F&R trailing arm bushings, torque rod bushings)
Custom control arms, 20 mm wider than OEM (improved camber adjustments)
20mm extended wheel studs on rear axle (in preparation for rear spacers)
upper and lower GT braces
Plans are run 10lb turbo with LH or Standalone system. Welded Diff.
What seats are those?
2fast4u no im not a cop. the name is copa. pronounced like o in coat. but i have been pulled over by thatcher back in the day though. how do you know him?
that car is screaming for a roll cage
pics?Custom control arms, 20 mm wider than OEM (improved camber adjustments)
With no turbo, the weight of the cage could help on the downhills
Physics ftl?With no turbo, the weight of the cage could help on the downhills
