Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
1988 240 DL. Brake, parking brake, battery lights on. I know this is often an alternator issue. But there is also a horrid squeal. Could it just be a belt?
It could be the alternator bearings are seizing or with bad bushings it is far out of alignment. Check for a charge light when the key is on. No charge light you need to check that circuit and fix the light. Then check for the alternator charging when the light circuit is working.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
