Old 07-02-2015, 12:13 AM   #1
242Bleek
k-jet groupie
242Bleek's Avatar
Default Anyone running a Saab 228mm Pressure plate?
I must have searched every thread available on this forum pertaining to clutches and none of them have been much help at all, they're composed mostly of people posting pictures of pressure plates they found in the junkyard and talking about how cool it would be if they used it on their volvo
I am looking for a clutch upgrade for my driver 83 245t with M46. The car is making about 200hp and won't really be making much more than 250hp. I had a spec stage blue puck whatever whatever $450 thing and it took a sh1t after 3 months and spec told me to eat it, kinda over expensive clutches for now.
I keep hearing about the saab 228mm pressure plate having the same bolt circle as the original 215mm plate with the exception of 3 dowel pins. Anyone running this? I know the 240mm is better but I think it might be overkill for this car and don't want the hassle of redrilling the flywheel. Would the 228 be up to my goals? What is the right disk to use to match the m46 input splines? I was thinking maybe a 228mm disk from a dog dish setup? Thanks
Originally Posted by TestPoint View Post
The D24 did not accelerate, it accumulated speed.
82' 242t 16v-Every mod known to man kind
72' 162E-B30 (no the 2 isn't a typo)
83’ kjet with 245 attached
98’ s70x2
95' s10 awd LS 1000+club
VFBG
242Bleek is offline   Reply With Quote
Old 07-02-2015, 12:55 AM   #2
Pretty sure the 228mm Saab bolt pattern is different.
Old 07-02-2015, 02:04 AM   #3
John V, outside agitator
Yep just made a hideous massive dogdish 60-2 "thang" into a flat flywheel last last week for a local 240 perv and since i had a couple of early 9000T Saab 228 pressure plate i did that for the bolt pattern---mainly cause he has a new disc..
Its different by a couple of mm..
Its Saab 900T 215mm and Volvo flat flywheel B21T 215mm pressure plates which directly interchange..
Early 9000T16 228 though looks to be a good 'un..good price. (around 88-90 bucks)
way more torquez and heavier car means need more clamp..
Maybe the OP wants a new bolt circle...Easy enough..
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-02-2015, 09:32 AM   #4
242Bleek
k-jet groupie
242Bleek's Avatar
So what I gather is I would still need a new bolt circle if were to use a 228mm? Is there any advantage to running the 900t 215 mm plate over the Volvo 215?
Say I were to punch out a new bolt circle and do a 240mm plate what would be the right disc to use with an m46? I looked it up and it seems the original f25 5speed that came on those 9000's had 14 spline input?
Old 07-03-2015, 08:21 PM   #5
MrBrown
You like popsicles?
MrBrown's Avatar
The Saab Viggen 228mm pressure plate I have bolts directly up to the stock flat flywheel. The dowels are off tho. If you have them removed and redrilled you would be good up to 300+
GhettoFab build thrizzie
Old 07-03-2015, 09:30 PM   #6
Check again.
215 900T direct to Volvo 215
Bolts and dowels off by no more than 3mm but off they both are.
Old 07-03-2015, 11:05 PM   #7
MrBrown
You like popsicles?
MrBrown's Avatar
Just did. Here is my proof
I was missing one bolt but it will bolt up just fine.
Old 07-04-2015, 08:33 AM   #8
MrBrown
You like popsicles?
MrBrown's Avatar
Check again.
Oh wait you said 215 900T directly interchange. I cannot verify that.
I have a 228 9000T and it bolts straight up.
Old 07-04-2015, 08:19 PM   #9
aaron740gl
aaron740gl's Avatar
Will the clutch disc for the td24 (the one folks are using for m90swap with dogdish) work with this pressure plate?
91' 744se with some stuff done to it
aaron740gl is offline   Reply With Quote
