Old 06-04-2014, 07:03 PM   #1
242Bleek
k-jet groupie
242Bleek's Avatar
Default 83 245T fuel pump fuse and relay extremely hot.
I've been dealing with this issue for a while now. The car is an 83 245T. I was told to begin with a new engine harness as mine was completely rotted away. So today I just finished installing it. I let the car run for a while and I go back to shut it off and the inside is filled with light smoke from the plastic around the relay plug melting. If you put a plastic fuse in the fuel pump spot it will melt completely away. I was told it was normal for the fuel pump circuit to get a little hot but this is not normal. I just installed a brand new fuel pump relay, new in tank pump, and have checked every single wire involved.
Anyone have this happen before or know where to look to fix it? Thanks
Originally Posted by TestPoint View Post
The D24 did not accelerate, it accumulated speed.
82' 242t 16v-Every mod known to man kind
72' 162E-B30 (no the 2 isn't a typo)
83’ kjet with 245 attached
98’ s70x2
95' s10 awd LS 1000+club
VFBG
242Bleek is offline   Reply With Quote
Old 06-04-2014, 07:12 PM   #2
Lord_Athlon
Just damn
Because theyre new doesn't mean they aren't drawing a lot of current.
Check the grounds for the pumps. The intank is on top on the left side in the trunk, and the undercar is under the carpet for the rear seat. Which fuse is getting hot? They have two.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 06-04-2014, 07:50 PM   #3
dobber13
That happened to a while ago and the problem was weak connections. Pull the wires out of the connector at the fuel pump relay,use a small flat head screw driver to release the tabs that hold in each female connector.
If the plastic is melted just cut the plastic off.Make sure you know where each wire goes. once you have them all out of the connector you can cut back the wire to install new female connectors on good wire.
I think the one that is burned up is yellow/red. I didn't bother with a new plastic connector until I was sure that solved the problem.
You also want to check the wires at the fuse box because those can get hot also ,make good tight and clean connections on all fuses and wires.
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 06-04-2014, 08:11 PM   #4
vlvman
vlvman's Avatar
/\This and /\That.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 06-04-2014, 08:33 PM   #5
242Bleek
k-jet groupie
242Bleek's Avatar
It's the red 16A fuse in the middle. It seems the the red wire which I think is constant power to the relay is the one getting hottest and melting the plug. I will check all the connections.
Old 06-04-2014, 08:47 PM   #6
benski
Post
One of my favorite tools for making things clean is a Dremel with a stainless brush. Wear eye protection, of course, and then GENTLY crimp the female connector so it's about as tight as it can be and still fit on the male side. I also use a little NoAlox or some other paste on the junction to keep them from oxidizing. And yes, check all your connections, grounds included..
