Old 09-27-2015, 11:53 AM   #1
242Bleek
k-jet groupie
242Bleek's Avatar
Default 83 245t-AC goes warm under boost
Hi, I Just brought this car back from the dead and never really knew how the AC worked. I recently put a new old stock york compressor on it and the ac blows somewhat cold at idle, I know its not going to be very cold being a york using 134. But when I take off and get into boost its seems as if the ac completely shuts off as long as I'm at full or part throttle and will start blowing cold again when it comes back down to an idle. Seems like the higher the RPM's the warmer it gets gradually.
Not only that but when I get into boost the ac blower fan will divert all the air to the floor vents, and starts working properly again once out of boost, I realize this could be because its losing its vacuum signal but how could it keep a vacuum signal under boost? The check valve is good. This car has a B21F intake if that makes a difference.
Was wondering if somehow these two issues could share the same root cause or if any has ever seen this before. Thanks.
Originally Posted by TestPoint View Post
The D24 did not accelerate, it accumulated speed.
82' 242t 16v-Every mod known to man kind
72' 162E-B30 (no the 2 isn't a typo)
83’ kjet with 245 attached
98’ s70x2
95' s10 awd LS 1000+club
VFBG
242Bleek is offline   Reply With Quote
Old 09-27-2015, 12:13 PM   #2
MistrThou
Death Metal Mog
MistrThou's Avatar
You may have a bad vacuum check valve. The door actuators are controlled by engine vacuum. If you have none, they don't function. You may also have a vacuum leak under the dash somewhere.
Originally Posted by Old Guru
Current cars: Something old, something new, something borrowed, something Maroon.
MistrThou is offline   Reply With Quote
Old 09-27-2015, 02:35 PM   #3
smoothdurban
I do my own stunts
smoothdurban's Avatar
If I am not mistaken isn't there an AC compressor interrupt when under high boost? The idea being when you need to pass someone or suddenly accelerate the AC compressor clutch is disengaged so maximum engine output is given to accelerate.
I forget exactly what pressure interrupts the AC clutch but I am certain this functionality is normal. Perhaps you interrupt switch is faulty or needs adjustment and causes the clutch to disengage at to low of a boost level?
Update
I found the green book that talks about it.
Is the installation instructions for B21FT intercooler.
It says the vacuum switch should cut out the AC compressor at 8 +/- 0.3 PSI and 3000 RPM.
Feel free to PM me your email and I send you a copy of the green book.
1983 242 Turbo w m46 139,000 km's going to LH2.4 this winter
1991 240 Wagon w m47 Winter DD 430,000 km's!
2005 S40i Sedan w M56 Summer DD with 137,000 km's
Old 09-27-2015, 09:31 PM   #4
242Bleek
k-jet groupie
242Bleek's Avatar
Update
Thats wierd, this car was not factory intercooled, I added one and did not add that switch to it. It seems like it cuts off much sooner than 8 psi, almost right away when boost begins to register.
Old 09-28-2015, 11:07 AM   #5
dobber13
Update
Not to steel the thread but does the newer type compressors that replace the York in a 240 have the same interrupt switch?
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 09-28-2015, 01:02 PM   #6
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
It's not the compressor.
On the very very last of the 240T factory TIC cars on the rack of relays behind the driver side headlight (only present on those cars), there are 3 relays:
-Turbo+ "IBS" (Intercooled Boost System) relay for ~+2psi above 3720rpm to the 10.5 from 8 or whatever. (different looking relay in a different location, but does the same thing as it's earlier larger squarer shaped cousin over by the coolant bottle usually on dealier TIC models).
-2x bosch 5 pin relays, one for the aux pusher fan with a temp switch in the lower radiator hose, 1 for the A/C interrupt, which I believe is done at +3PSI and over 3720RPM since the wiring runs over to the 3psi firewall switch for the A/C cutout relay. +8psi would be nice, however, but I don't think there's any switch that senses +8psi.
The rotary compressor has a higher redline draws a lot less power. I probably wouldn't keep the A/C interrupt in that case. Ironically, the old york thing draws so much more power you probably have to use a little more boost to power, it, which would then mean you'd be more likely to engage the cutout.
I don't think they really wanted to to be revving the old york compressor over 4K much at all.
But if not factory TIC or if they didn't add that cutout dealie to your car's electrical, IDK. I've seen it on dealer intercooled cars once in a while, but rarely.
Old 10-02-2015, 07:35 PM   #7
242Bleek
k-jet groupie
242Bleek's Avatar
Thanks for the input, I clamped off the inlet hose going to the heater core with vise grips and now the AC works phenominal all the time Sorry to waste your time with the AC issue. Im guessing this is a bad heater control valve that cant hold the coolant back when it builds pressure with RPM?
Also the vacuum check valve was bad, replaced it and this corrected the issue of the ac going to the floor.
