Old 10-03-2018, 07:43 PM   #26
Jack
junkman
Jack's Avatar
Originally Posted by quillc View Post
Whatever it was that Rock Auto (I think) sent me.
I did the same thing (the washers) to the 91 245 that my wife drives on an old set of rubber bushings. Doesn't seem to matter brand as long as you use the washers.
The alternator seems to be the worst/highest wear location.
Yup agree on alternator but did have working AC compressor take a crap .... made noise one day... shet better change bushings... next day it seized up fuk
I hate accessory bushings, sounds like this is the trick
Do you put washer inside and outside of bushing along with spacer or just outside ?
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 10-03-2018, 08:14 PM   #27
quillc
yv1a.com
quillc's Avatar
Just on the outside. As I recall, I had to buy a slightly longer bolt as well to compensate.
The first spacer actually came from a 1965 Dodge D300 truck. They used a spacer in a similar way and I had an extra from my Power Wagon project. On my wife's car, I just went down to Ace Hardware and they had some steel spacer bushings. I bought a few to make sure I had it long enough, cut one piece to length and welded them together to make one piece.
Its a PITA to get the bolt, alternator, bracket and spacer all lined up with only two hands. Be sure to disconnect the battery and the oil pressure warning light (for when you drop the alternator and rip it off otherwise ).
Chris
www.yv1a.com
Old 10-03-2018, 08:34 PM   #28
57plymouth
57plymouth's Avatar
Another reason to swap in an LS.
Sven, the 1991 245
57plymouth is offline   Reply With Quote
Old 10-03-2018, 08:40 PM   #29
brian smith
People -
Recognize: belts are easier to replace than these bushings.
Either go whole hog and re-enginerd it,
or perhaps do as I do: install the belts just tight enough not to slip, verify with tension in under 100 miles of run-in. Next, don't touch it.
Then when they chirp or squeal, adjust them one last time, and add them to your next oil change driven parts order.
Yes the adjuster brackets should work for 60k miles like they originally did. They don't. Sucks, but whaddaya gonna do, complain?
Under this maintenance and adjustment scheme, even the brackets cracked behind the a/c p/s mess generally keep working in their squeaky way of working without fail.
Face it, we drive Volvos, not something you can order a kit from "March" to convert to serpentine belts. It ain't fair, but no 1/8" of magic bushing material cures what ails us.
Hate to throw water on the idea of a better mousetrap than living with mice, but dammit that's how it seems from here.
the howdeedoo:
http://forums.turbobricks.com/showthread.php?t=288872
brian smith is offline   Reply With Quote
Old 10-03-2018, 08:45 PM   #30
Jack
junkman
Jack's Avatar
Originally Posted by brian smith View Post
People -
They didnít last 60k. I didnít come to complain. I came to ask whatís worked for who....
Serpentine belt conversion isnít difficult on these
Old 10-03-2018, 09:19 PM   #31
300+hp on the shelf club
Another thing you can do to have longer lasting bushings on the upper alternator bracket on a 240 is using the later B230 setup. The earlier B230 uses an upper bracket with a long cylinder with the adjuster at one end attaching to the alternator and the other end has the bushing and bolt going into the block. This has a lot of side load causing problems with bushing life and worse with broken bolts. Instead the later setup uses a thick spacer and the cylinder is short on the upper bracket. This also uses a longer upper bolt. But this reduces the side load and that upper bracket issue goes away. If you look up parts for a 93 240 it'll show this upper bracket setup. I put it on my 82 turbo with a Denso 80 amp alternator.
Old 10-03-2018, 09:38 PM   #32
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Dunno, got about 6 years on the Superpro's, pulled them in place of OEM while trying to figure some noise **** out, had nothing to do with them, and they are still VERY serviceable and sitting in the spares pile.
Most of the aftermarket poly ones like URO and such are complete junk. The Superpro's don't turn to hard plastic in 6 months, and they actually stick into the accy bracket sockets.
I did see similar issues with the aluminum ones on a local's car.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 10-03-2018, 11:24 PM   #33
Jack
junkman
Jack's Avatar
You also haz 7/9 .... better bracket
Old 10-04-2018, 02:00 AM   #34
swedefiend
swedefiend's Avatar
Has anyone tried to source a bronze bushing for this application?
Bronze should be twice as hard as aluminum. Even brass bushings would be better durability wise, I think.
Old 10-04-2018, 11:14 AM   #35
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Problem I see with going harder than aluminum is then you start wearing out the aluminum bracket instead.
Old 10-04-2018, 11:39 AM   #36
John V, outside agitator
5. Replacement rubber bushings with a washer added to the outside of each bushing. Three years and counting. I also added a steel spacer on the pivot of the alternator. Blue Loctite on the bracket bolts into the block help prevent them from getting loose (and falling out).
The washer seemed to do the trick. I seem to recall it being a 7/16" fender washer (but you should verify). I suspect its because the force is spread over the face of the bushing rather than just being concentrated at the steel insert. Compressing the bushing slightly helps keep it in full contact with the bushing bore and prevents it from squirming (deforming) under load too much.
The conclusion that I've come too is that these old V belts that we use need some minor amount of flex in the pully system that they run in to absorb the harmonic vibrations that they are subject too. If the material is too hard, the bushing doesn't absorb enough and wears rapidly as the cyclic motion of the vibration moves the bushing against the steel bolt/bushing center. The key is to have enough vibration absorption while preventing rotational movement to limit wear.
This.
When you tighten the bolts the bushing squished and bulges and sits tight in the OD and lasts.
Ideally it should be a slight press fit..about 010"
Surprised it isn't..an easy slide fit, its gonna rattle and wear, rubber, poly or aluminum.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
ó Don Marquis
