MarioDrivesaBrick
- Jun 8, 2016
- Santa Barbara, CA
Currently I have an 1983 244 AW71 and would like to convert the Chrysler ignition to EZK. I have read that my 83 will require a upgrade from LH 2.1 to LH 2.2. So I would like to ask so questions about the conversions.
For this conversion to LH 2.2 I have read some different things.
1. Is the harness the same between the LH 2.1 and LH 2.2?
I read here that I only need to swap the ECU to a 2.2 and the AMM to a 007, repining the connector for the 007. In this article he talks about also pulling the fuel pump relays and injectors.
Is a 2.1 to 2.2 as simple as unplugging the 2.1 ECU and plugging in the 2.2 ECU and repinning the AMM connector and swapping the AMM?
2. I read here the 2.2 ECU for non turbo is 544, as apposed to here using a 541 for a turbo. I plan to stay NA, so I want a 544, correct? What donor cars have 544 boxes?
Once the LH 2.2 is installed then I can go about installing the EZK.
for the EZK swap I will need the
EZ117K box
power module
EZK harness
004 distributor
knock sensor
IAC 501
I think these posts 1 2 and 3 do a great job of explaining, I just mainly need more info on the LH 2.1 to 2.2 conversion.
Thanks
Mario
EZ117K box
power module
EZK harness
004 distributor
knock sensor
IAC 501
Thanks
Mario
