joedirt
- Aug 6, 2017
- Beacon Falls, CT
Just thought id share my ride/history
My last project was a 88 ford thunderbird turbo coupe which has a 2.3 turbo stock. Company called Stinger sells pre assembled Microsquirts ready to go for old obd 1 fords, which they called P.i.m.p. (now they are selling MS3s). I had gotten a used Pimp and ran it in my Turbo Coupe for a year or so and it was a great learning experience.
Now my latest project is a ?85 240 wagon with a 5.0 swap that had a 89 Ecu in it. Car ran okay after we fixed the mechanical stuff. But I had the itch again (creams don?t work) so I got another used Pimp.
After dealing with a bad AEM X Series gauge out of the box that was putting out 4.50 volts constantly, I got a replacement controller/gauge and I got the correct signal coming from the analog wire (DON?T FORGET TO GROUND THE BROWN WIRE lol).
Car is running now on the PIMP via tuner studio on a base tune. The engine is stock with the exception of mildly ported stock heads and a big fuel pump. I figured let me tune as I get parts and learn the system.
Ironically enough I have 2 other buddies with Pimps in their 2.3 turbo powered Fords as well (SVO mustang and 88 turbo coupe) and im the computer guy so ill be messing with their ecus as well. The latest one might have a bad ignition driver but im working with Stinger now to figure that out for sure.
Ill def be poking around in here for tips and hints on getting Tuner Studio going
