Old 07-23-2019, 02:38 AM   #1
c.slopsma
Thumbs up Revvable redblock of choice for itb's with an aggresive cam symfonie
Goodday to all of you.
Got some stuff left over for what could be a nice redblock build.
ITB's, Adjustable cam gear, Modified head & an standalone is what i've got laying around.
Now i was wondering which type of redblock is most suitable to rev. A while back i had
some webers and a cam thrown on an really worn out b23A which seemed to love it. revved
it on the regular to 7k, Didn't even seem to bother apart from blowing oil out of the crank
vent This time i'd like to have an even more aggressive cam ground and hit something
like 7,5 maybe 8k.
Being a budget build and stuff i'd like to stay away from forged rods and machined blocks.
Which base engine should i use?
c.slopsma is offline   Reply With Quote
Old 07-23-2019, 07:10 AM   #2
740atl
educator monkey
740atl's Avatar
I recommend you get a honda engine. They have extremely light pistons and rods which are what you need in order to rev to the moon. Trying to do this on a "budget" with the heavy b23a rods and pistons is fantasy. If you're at all serious about this, you need lightweight rotating assembly (which means lighter forged pistons and rods).
I suppose after hearing advice and still wanting to do it my way, I would find the redblock engine with the smallest bore possible because it would have the lightest internals... If you wanted to stay OHC, a b21F (not the FT), or don't mind pushrods, a b18.... but those are still not great choices.
What exactly are you trying to accomplish?
Old 07-23-2019, 09:09 AM   #3
propav8r
F*ck Edgar
propav8r's Avatar
So what you're asking is "how many rpms cna stock support?
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 07-23-2019, 09:58 AM   #4
c.slopsma
Good point.. The worn out B23A in my 242 was such a fun car to drive, It had a volvo GT6 cam, Weber 45's, 12.5:1 cr, 4.11 gears, welded diff and 7k revlimiter. Unfortunately carburetors and wild cams are a bad match for a engine that also has to do some sort of street driving since the intake air is going to pulse at low revs (<3k) and make for an unstable (undrivable) mixture. At WOT a whole lot of fun and couldn't keep myself from kissing the rev limiter on the regular. The engine didn't fail but i disarmed it to build something slightly more streetable with fuel injection which unfortunately never happend.
At the moment i'm working on a big turbo project for the street & strip 244. But i've gathered and made some nice stuff for an na build. Since the turbo project needs the funds this has to stay a fairly cheap build. Chinese rods might be possible but nothing fancy. Throttle bodies are adapted gsxr1000's, lightweight flywheel is self made as is the adjustable cam gear and such. I'll post some images this evening.
Did you guys happend to have seen the NA build from a guy who names himself Drifts n' lifts on youtube? He seems to revv 7,5k all day on an i believe unopened thin rod bottomend.
Old 07-23-2019, 11:48 AM   #5
Jack
junkman
Jack's Avatar
yeah ok
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 07-23-2019, 12:28 PM   #6
culberro
culberro's Avatar
Fun fact, a NA b230 with "big" rods will rev over 8k without ejecting the internals. A good clean engine, good clean and cool oil, head and ECU to support the revs. Done.
Old 07-23-2019, 03:00 PM   #7
iHateVolvoPeople
Banned
Thatís what Koltan did on drifts and lifts like OP mentioned. Heís on full stand alone with a K cam I believe, or maybe something more aggressive? Also he has a shaved head and some minor port work done IIRC. Stock m46 and welded diff too. His little NA engine does rather well. Itís surely faster than a stock boost factory turbo auto 7/9.
Old 07-24-2019, 03:03 AM   #8
c.slopsma
I'm starting to believe it's doable and am motivated to give it a try. With big rods you mean the ones from a b230fk, fk or forged?
Here are the modified flywheel and cam gear. It's bit of a bummer that because of the timing
wheel the heavy one has to be used, Nevertheless got quite a bit of weight off it. Now
it's about 8.5kg with less off the mass on the outside, Initially it was intended to use it on a
turbo build with diesel pressure plate. So it should be plenty strong for this na engine dough.
Cam gear is original with the center milled out and replaced with a slotted piece of
aluminum. Got the head taken apart again yesterday. This time i'll spend some hours trying
to port it. Would it worth spending any time in the exhaust ports?
The vintage lobe profile GT6 cam i had did it's job well. But i'm looking for something
slightly more aggressive this time. It would be good to know what the rally guys are
using.
Old 07-24-2019, 01:30 PM   #9
chuck that flywheel in the trash... its a grenade waiting to happen.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-24-2019, 02:10 PM   #10
https://www.acm.se/category/acm-8v-sohc
Old 07-24-2019, 02:12 PM   #11
http://www.forums.turbobricks.com/sh...d.php?t=337311
Old 07-24-2019, 02:46 PM   #12
sbabbs
sbabbs's Avatar
using.
Get a JohnV billet steel or TTV billet steel flywheel with the sensor holes... OR this..
Also I had B23ft with forged crank and forged pistons and over revved it and turned a rod bearing. As stated want to rev use later b230 or fully raced out b23 with racing crank and rods and pistons..
Old 07-24-2019, 03:26 PM   #13
The Librarian
According to Volvo the stock B21/B23 crank is good to 8000 rpm.
http://hiperformanceautoservice.com/...EngineDocs.pdf
Originally Posted by R-Sport 16 Valve Engine Press Release
Crankshaft and conrods.
The crankshaft is the standard version, it is already so strong that it can
take up to 8,000 revs.
They did however have special con rods available for use at higher rpm.
Old 07-24-2019, 04:41 PM   #14
culberro
culberro's Avatar
Just the stock 13mm rods.
That Flywheel is probably not the best for high rpm use. Definitely don’t want it coming apart. The older “flat” flywheels have been fine at those revs, in my experience.
Sbabbs flywheel bomb also had a slipping ceramic clutch, which didn’t help keep the FW in one piece.
Old 07-24-2019, 05:01 PM   #15
c.slopsma
In that case i'll start looking for a flat faced flywheel. Such a shame not to use the stronger
diesel pressure plate that is laying here new in the box. The idea to lighten it this way came
from the folkrace site. Those guys seem to get away with weakening it even more.
https://folkraceshop.se/skelettsvanghjul-volvo-b230
Made an appointment to take a look at a possible bottom end. The engine is a B230F from i
believe a 740. It's fuel injected and has the distributor on the front, should be low on miles
and fair priced. I recall to have read that the later (88+) engines with smaller main bearings
would have less issues with crank flexing. Would this engine get me to where i need to be with
swapped or forged rods or do i need to look further for an 88+?
Old 07-24-2019, 08:05 PM   #16
RvolvoR
A honda k20/k24.
Old 07-24-2019, 08:31 PM   #17
BEAMS would be easier
Old 07-26-2019, 10:33 AM   #18
c.slopsma
These are the throttle bodies. They came ogiginally on a suzuki gsxr 1000. The bottom plate
is made on the mill and they are spaced to suit. Intake ports and manifolds are ported by
instructions i found on here on the board. I've still got te get myself to do the exhaust ports
since i kind of hate porting stuff. Hoping the engine is going to be what's expected. If someone
lives in europe and has a leftover set of 13mm rods send me a pm please.
Old 07-29-2019, 06:52 AM   #19
J2_
J2_'s Avatar
//edit.
Pm send ;)
J2_ is offline   Reply With Quote
Old 07-30-2019, 02:35 AM   #20
c.slopsma
What do you guys think of this cam. It's made by Catcams from Belgium. It requires solid buckets and stronger valve springs but that is something i could live with. How would it compare to say something like the kg7?
Old 08-01-2019, 02:32 AM   #21
c.slopsma
Slowly starting to get there. The quest for rods ended thanks to J2 who sold me his set of used 13mm rods. Yesterday after some slight delay i went to take a look at the offered b230f. Was low at expectations since the guy selling it didn't know how many miles were on it, only that the previous owner replaced it recently. Removed the number 4 sparkplug and it showed that it had been running rich for a while. Expectations went even further down. Took the endoscope out of the case to look in there and to my surprise it seemed to be in a very good condition so i took this badboy home including an extra old style flat flywheel, Score!. Unfortunately the trunk off my nice bmw touring with beige interior will never be the same again
Old 08-01-2019, 02:36 AM   #22
John V, outside agitator
You sure that is safe with the 35mm buckets??? That's a lot of lift.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
ó Don Marquis
Old 08-01-2019, 05:04 AM   #23
c.slopsma
It requires 37mm solid buckets which uses lashcaps to set valve the clearances. What are your general thoughts on this cam?
Old 08-01-2019, 09:44 AM   #24
Get the compression up to a nominal 11.5 and it should be a fun cam since you're going ITBs
Have you done a calculation for dynamic compression ratio?
Old 08-01-2019, 10:33 AM   #25
c.slopsma
Thanks for your reply. With the current setup i'll end up with close to 12:1 static, Which i thought would be in the ballpark for this cam. would you agree?
