Fresh Air Inspector
- Nov 4, 2018
- LaHave, Nova Scotia, Canada
Hello All,
Other projects have conspired against working on the the 940. My last post on this subject was in Nov of 2018.
I did manage to swap the rear axle; 4:10 to 3:73 (majority of my driving is highway).
Yesterday I started looking at the actual engine swap requirements. To clarify, my wagon is a 'non-turbo' (NA), and the donor is a turbo. Both are 1994 940s manufactured within months of each other using LH2.4. The NA engine compartment is a mirror image of the turbo; ABS is on opposite fenders, same for the air filter housing, MAF, battery, washer fluid container, etc.
It has been suggested that this is an easy 'plug and play' swap but I feel it isn't. According to a chap on YouTube that did the same swap (took him 7 days). The wiring harness under the dash was swapped by 'cutting/soldering'. (https://www.youtube.com/watch?v=4blRkU5Rvoc this is a '7 day' video)
According to the Mitchell wiring diagrams, there are differences but the sensor connections do end up at the same pin outs on the ECU.
Some questions to challenge you;
1. Has anyone done this exact swap without the 'under dash wiring nightmare'? I've already had the complete dash apart to replace the dual diaphragm HVAC servo (PITA). So I'd rather not do it again.
2. I can rewire the MAF connection BUT the ABS pump will conflict with the MAF due to the design of the hose between the MAF and turbo. I could remove the ABS system completely to work around this.
3. The turbo does not use the WOT output on the TPS. The purpose in the NA cars is to enrich the fuel. Pros and cons of leaving it connected or not?
4. The turbo uses an 'air preheating resistor' in the hose between the MAF and turbo. Pros and cons of its purpose and how/where to best connect this to the NA engine harness?
5. I would prefer to move the battery to the drivers side (like the turbo), to allow me to use the factory air filter housing (yes, the ABS pump would need to be moved/removed). To do this the under hood 'power distribution' needs to be changed. Anyone done this?
As always, your feedback is appreciated!
