Squirterizational mod RENTAL KIT for INCREASED PERFORMANCE
I too have a block on the stand here in Colorado....please add me after Ken and I'll drive down and pick it up
Ok but that will be up to you guys to work out but will need to be quick about it to stay within the 10 day time frame , and it'll be deducted from Ken's deposit if you break or lose anything.
Hey to help keep track didya notice the clever use of color coded bolts? Black kit/Gold kit...Didya check the pilot diameter?
It's supposed to be 1/4"---like the first drill size.
I saw that, thanks again for giving this another shot.
:nod:
I'll test fit them on a low mile B21FT block I have here, and see how things go.
I had to get a few more parts to complete the kits and make it easier to get good results.
An extension for the counterbore aka spot face cutter was needed so the drill chuck would clear the main journal.
The 8x1m tap needed a 1/4" by 6" socket extension, a tap handle, and two layers of 5mil plastic to take the extra slop out of the tap to extension fit, but loose enough to let the tap find it's way square into the bore.
It's fun to do but you need to keep track of the steps, and take your time.
So on with the show...
In the interest of accuracy in the field the block was shimmed up level.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit2_zps112b478c.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit2_zps112b478c.jpg" border="0" alt=" photo SquirterKit2_zps112b478c.jpg"/></a>
The bushing fixture is set in the lathe drilled and tapped out main bolt.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit4_zps00057622.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit4_zps00057622.jpg" border="0" alt=" photo SquirterKit4_zps00057622.jpg"/></a>
The Dewalt 106 drill has a ball level in the back of the handle so it is possible to drill fairly perpendicular freehand.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit3_zpsc7fa44b9.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit3_zpsc7fa44b9.jpg" border="0" alt=" photo SquirterKit3_zpsc7fa44b9.jpg"/></a>
Picking a spot @ a 1/4 drill bit width from the edge using medium pressure and nice and slow with the drill at only about 600rpm the cast iron cuts quickly and easily.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit5_zps405c0397.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit5_zps405c0397.jpg" border="0" alt=" photo SquirterKit5_zps405c0397.jpg"/></a>
The block wall into the oil gallery is about 3/8" or 8mm thick at this point, and the gallery is around 1/4" or 6mm wide, so be careful and let up when the sound changes and punching through is imminent.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit6_zps72119c8d.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit6_zps72119c8d.jpg" border="0" alt=" photo SquirterKit6_zps72119c8d.jpg"/></a>
Next the counterbore is run at half speed or @1250rpm with light pressure to cut it flat, and then just a touch at full speed 2500 rpm to smooth the surface.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit7_zps7deea186.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit7_zps7deea186.jpg" border="0" alt=" photo SquirterKit7_zps7deea186.jpg"/></a>
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit13_zpsce987589.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit13_zpsce987589.jpg" border="0" alt=" photo SquirterKit13_zpsce987589.jpg"/></a>
Drill again..
The fixture is repositioned by wiggling the drill bit back and forth to find the center, and tightened in place.
Drilling the 7mm pilot hole for the tap is tricky as it tends to grab in the 1/4" hole.
Very very light feed pressure, half speed, and the chuck not so tight so the bit can spin in the chuck when it grabs instead of snapping the bit off.
Now the hole is faced, piloted and ready to tap.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit8_zps7fa718d0.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit8_zps7fa718d0.jpg" border="0" alt=" photo SquirterKit8_zps7fa718d0.jpg"/></a>
The fixture is left in place and used as a guide during the threading operation.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit9_zpsae869963.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit9_zpsae869963.jpg" border="0" alt=" photo SquirterKit9_zpsae869963.jpg"/></a>
You'll feel the tap hit bottom and stop, don't push it and ruin the threads.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit10_zpsa43a57e3.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit10_zpsa43a57e3.jpg" border="0" alt=" photo SquirterKit10_zpsa43a57e3.jpg"/></a>
The pointed tip of the tap is ground off to get the threads further down the bore all the way into the oil gallery.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit11_zpscd1500fe.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit11_zpscd1500fe.jpg" border="0" alt=" photo SquirterKit11_zpscd1500fe.jpg"/></a>
The finished product.
<a href="http://s255.photobucket.com/user/redwoodchair/media/JVAB%20Squirter%20Kit/SquirterKit15_zpsdffe6174.jpg.html" target="_blank"><img src="http://i255.photobucket.com/albums/hh136/redwoodchair/JVAB%20Squirter%20Kit/SquirterKit15_zpsdffe6174.jpg" border="0" alt=" photo SquirterKit15_zpsdffe6174.jpg"/></a>
Most guys get them from me since I'm such an all round swell fellah and invented the kit and fought with some so called moderator to get this Loaner Kit idea made into a sticky.
I've been selling them for 15.50 each.
Sometimes 16.80, sometimes 20.40..
I never know till i get them..
And there's never any explanation...
:omg:
Good price, best one I've seen online!
Consider this my official request sir.
Both kits are spoken for at the moment, but I will post in the thread and PM you when one of the kits returns.
It's been 24 hours since you asked for the kit and I haven't received your deposit, nor have you been logged in.
I can provide the kits, but I can't babysit you guys forever.
BigMatteson you have PM regarding the deposit.
Apologies sir, I started a new job last week.
I will gladly concede my spot, I have no need to monopolize the kit, I will have my chance.
