Old 09-07-2018, 04:36 AM   #1
dkrause
Default ISO, Throttle Position Sensor (full range variable) for B230 FT
I am changing from a Bosch 2.4 LH ECU (B230 FT) with a TP Switch to a aftermarket ECU that requires a full rotation variable sensor. Is there a bolt on TPS that would replace the stock switch on the stock throttle body?
dkrause is offline   Reply With Quote
Old 09-07-2018, 04:37 AM   #2
Brotkasten
Jonas
Brotkasten's Avatar
https://yoshifab.com/store/b230-tps-adapter.html
Here you go!
91' 940 B230FB+T M90
Old 09-07-2018, 06:47 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
to which ems you are converting to?
Old 09-07-2018, 10:18 AM   #4
Mogly
280WHP Regina
Mogly's Avatar
Lh3.1 uses a tps.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 09-07-2018, 10:39 AM   #5
A tough rowing ho
850tps is cheap new on Rock Auto fits the yoshifab adapter
Old 09-07-2018, 10:40 AM   #6
Satsukeshi
Satsukeshi's Avatar
I grabbed a throttle body from a LH3.1 240, bolts right on and works with MS3X.
'90 740: MS3X, ID1000 Injectors, AEM Smart Coils, Head Mounted CAS, RSI Stage II Head, Stage III Cam, Shimless Buckets, td04hl-19t, NPR IC, SSQV 4, 3" Turbo Back.
Upcoming Remix... 2.5l Big Turbo FunWagon
Satsukeshi is offline   Reply With Quote
Old 09-07-2018, 03:56 PM   #7
OttoB
Choose Bosch made TPS. Clones can be horrible. And have been
Old 09-07-2018, 05:00 PM   #8
Dirty Rick
Dirty Rick's Avatar
^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^
And That ^^^^^^^^^^^^^^^^^^^^^
Old 09-08-2018, 11:09 PM   #9
dkrause
Haltech Elite 1500
