mschultz373
- Mar 11, 2020
- dirty coast
Yesterday I finally buttoned up and started a 940T wagon project car I've been working on since March. She starts strong and even drives seemingly fine for the most part. (I can't drive her long or far since I don't have her registered yet... only around the block.)
But there is slight smoke coming off the exhaust side after idling for several minutes and after driving briefly. There is more after driving, but not like plumes of smoke or anything. The car's driving and idle do not appear to reflect any problem and I had the head decked and put a new head gasket on just a couple weeks ago. However, I am trying to be cautious with running her too long as currently there is no temp reading getting to the gauge and I don't want her to overheat...
There is no noticeable smoke coming out of the exhaust at the tail pipe.
I am not running gaskets between the turbo and the downpipe, nor between the exhaust manifold and the turbo - did I miss a gasket in either place?
Also, there was a failed seal for the coolant return banjo bolt when i first was filling the cooling system. I replaced the seal and it is not leaking now, but it did leak a good bit of coolant around that area. I've thought that the heat of the exhaust side could be burning off that coolant?
I did not rebuild the turbo but the car has 124k miles on it. I've also thought it could be a bad bearing inside the turbo...
any thoughts or ideas for troubleshooting? Particularly if I missed a gasket. thanks everyone
