Old 05-17-2007, 01:00 PM   #1
jpbturbo
Mens Classic Fit Polo
jpbturbo's Avatar
Default The Belgian Wonder - Joshua Brown's 1984 242ti
I've owned this car since may of 2005 when it looked like this,
At the time it needed,
  • Radiator.
  • Intercooler and piping
  • Turbocharger that didn't leak a quart of oil every minute.
  • Ignition Coil
  • plugs/wires
  • Fuel pump wiring/relay that didn't suck
  • Tires
So far I've managed to take care of most of those things except for the tires and fuel pump wiring.
Keep in mind that most of the time I was working on my old 245 and not on the 242.
Now it looks like this,
Because I'm lazy I have a bunch of parts to go on,
  • KG2T cam
  • MSnS-E v2.2board with relayboard
  • Triangle/BNE/kaplhenke camber plates
  • stiffer springs/coilovers to go with^^
  • flathood needs painting
  • boost gauges/AFR etc...
  • B21F intake mani
  • Pioneer MP3/CD head unit
  • HKS ssqv bov
I'm sure I'll remember more things that I have(to do) when I get home.
I'll also have more pics.
-Josh
Originally Posted by Lord_Athlon
My kia is best kia appliance so cheap.. Oh ****
Originally Posted by Isaac
Ur A LIAR u dident maek 28 psi BOOURNZ!
jpbturbo is offline   Reply With Quote
Old 05-17-2007, 02:03 PM   #2
Nick
Nick's Avatar
Awesome. Thats a clean car! Be sure to keep us updated.
-Nick
S30 & E30
No mas Volvo.
Nick is offline   Reply With Quote
Old 05-18-2007, 09:26 AM   #3
jpbturbo
jpbturbo's Avatar
Here are some more pics,
Soldering up the relay board.
The relay board is done now and so is the MS to RB cable.
I'm going to end up mounting the relay board on the drivers side in the engine bay where the stock 240 turbo k-jet ignition thing sits under the little sliding plastic cover.
I had a friend of mine throw the 90+ on his milling machine and open it up a bit.
After this pic I used a grinding wheel to smooth things out a bit more.
The .52 compressor housing.
This doesn't look good.
Just not appealing to me for some reason.
Old 05-18-2007, 11:44 AM   #4
peacereef
peacereef's Avatar
im glad to see i have the same hidious white jank hood handle.
peacereef is offline   Reply With Quote
Old 05-23-2007, 05:13 PM   #5
jpbturbo
jpbturbo's Avatar
The Fuel Pump wiring is working now.
Seems in all that mess the wire that connects 31b on the relay to a signal output on the ignition module was disconnected.
This weekend should see the oil feed gasket fixed and the other virgos with better tires put on the car.
Old 05-23-2007, 05:18 PM   #6
Biesey
Biesey's Avatar
wow josh the car is looking good! and i hate 240 wiring.
- Dan
2002 A4 | 1986 280GE | 1971 1800e
Biesey is offline   Reply With Quote
Old 06-06-2007, 11:54 PM   #7
jpbturbo
jpbturbo's Avatar
The wiring has been a real pain in the butt.
I've had some time off this week so I've been working on getting the K-jet ganked out and the MSnS stuff put in.
I'm in wiring hell right now but it's gonna get better.
The gray 8 pin connector for the engine harness is dead so tomorrow I'm going to be redoing the starter and alternator wiring and putting in a new molex connector to replace the 8 pin thing that is nearly disolved.
I think I've got all the other K-jet wires pulled out and removed
The relay board is mounted where the stock K-jetz ignition module mounts on the bracket by the coil.
I'll try and get some pics of the mess posted up tomorrow.
Old 06-07-2007, 03:45 PM   #8
jpbturbo
jpbturbo's Avatar
moar pics with descriptionas.
My workshop/garage
No more Medusa in the corner of my engine bay.
The shiny B21F intake manifold, it's still gunky on the inside though.
I think a pressure washer will clear it out.
This is the bad old wiring I'm taking care of.
I got the boost gauge installed.
New seals and pintle caps on the greentops.
With the napa part number for the injector seal kit, 2-12085
search keywords, Injector injectors o-ring orings o-rings pintle caps napa 2-12085
The relay board mounted in place.
Another shot of the relay board,
I just cut a piece of aluminum and drilled holes so it would line up.
Top view
Old 06-07-2007, 03:51 PM   #9
Biesey
Biesey's Avatar
looks awesome Josh, glad to see it coming along!
edit:: the wiring looks miserable...
Old 06-07-2007, 05:08 PM   #10
jpbturbo
jpbturbo's Avatar
It is miserable,
The cabin side of the wiring is redone with the molex connector,
I just have to redo the alternator and starter wiring and I'll be done.
Then I can really get down to the MS wiring which isn't really that big of a deal at all.
Old 05-12-2009, 02:14 PM   #11
jpbturbo
jpbturbo's Avatar
2 years later and I still haven't finished.
I'll go ahead and throw some pics of the BNE parts in here though.
Old 05-12-2009, 03:09 PM   #12
pwschuh
Rolling...
Good to have you back here Josh.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 05-12-2009, 03:46 PM   #13
volvo78244
Ring apprentice
volvo78244's Avatar
I'm just a little confused about the Belgian Wonder
2005 V70 - 2.4D
2003 S60R (sold)
1998 S70R (sold)
1993 960 B204FT
1992 740 B230FD
1990 960 B204FT
1987 340 B14E Variomatic (sold)
1982 242 B230FK
volvo78244 is offline   Reply With Quote
Old 05-12-2009, 04:20 PM   #14
jpbturbo
jpbturbo's Avatar
What's to be confused about?
It was made in Belgium(see my sig).
Old 05-13-2009, 01:25 AM   #15
volvo78244
Ring apprentice
volvo78244's Avatar
Ah, of course. It's clear what we Belgians are good at
Old 05-13-2009, 01:32 AM   #16
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Nice work, doodah.
Haven't seen you around in quite some time.
Old 05-24-2009, 02:56 AM   #17
240Psycho
still trying
240Psycho's Avatar
YAY the 242 will live!
excelent work Josh. keep it up.
..::VFBG::..
Kyle with a
'91 244 2.5L 16V turbo
00 S70 T5
81 242 T
79 242 GT
240Psycho is offline   Reply With Quote
Old 07-03-2010, 11:15 PM   #18
jpbturbo
jpbturbo's Avatar
Well,
I've moved to a different state and the 242 is stuck in exile.
I have procured a billet fuel rail that will be mounted to the head for the EFI injectors.
I also have a lightly crunched IC out of a chevy diesel truck that will be getting chopped and have custom end tanks made so it will fit in the front.
The chevy IC is larger as far as height and width go than the powerstroke IC I ran in the 245 but it's also thinner.
-Josh
Old 07-04-2010, 12:14 AM   #19
pwschuh
Rolling...
Awesome Josh! Glad to see this project getting some life in it again.
Old 07-04-2010, 01:03 AM   #20
towerymt
the real Towery
towerymt's Avatar
I have a PSIC that has been cut shorter, if you're interested. Still super wide, but only about 13" tall. Metal end tank variety.
I also have some nice end tanks that will work on a 3" thick core.
Old 07-05-2010, 12:51 AM   #21
jpbturbo
jpbturbo's Avatar
I think I'll have to pass on those right now.
Old 08-11-2010, 10:43 AM   #22
jpbturbo
jpbturbo's Avatar
I went and picked it up this weekend.
Old 08-11-2010, 11:03 AM   #23
DNAsEqUeNcE
†John3:16
sweet! Let the building begin!
Old 08-11-2010, 11:56 AM   #24
jpbturbo
jpbturbo's Avatar
The bumper got a little kink in it after a turn that was a little too tight.
The drivers side mount tweaked just a little bit.
Old 08-16-2010, 09:53 AM   #25
jpbturbo
jpbturbo's Avatar
Thumbs down Rust
Started pulling the carpet out yesterday and found the expected rust behind the front seats.
The drivers side had an actual hole all the way through where the passenger side just had a big puffy rust spot about to be a hole.
Time to read up on the best way to fix this stuff.
My neighbor's got a welder(flux core wire feed at the house and a good mig setup at work) and he's offered to help me do any welding I might need.
My other neighbor also rolled by in his beautiful 1980 245(baby poop yellow) while I was out poking around and we had a good chat about Volvo's.
