Old 07-07-2013, 11:46 AM   #1
Leivon
Default 245 headliner speakers
1989 245 B230f M47
Just a fun little project I did last night.
I know it's the wrong type of wood on part of the box, and the speakers aren't anything great and there are i'm sure a million things wrong with what I did.
All that aside, this is my 3rd 245 and I've always found it such a hassle to have two bulky 6x9 boxes in the back. I could never bring myself to cut through the inside of the tailgate, or put the 6x9's in the bottom of the back door, so 6x9 boxes were the solution. Anytime the wagon needs to be used for hauling a bunch of crap they have to be moved, or taken out completely and it's just not cutting it anymore.
So...... I decided to see if putting them in a shallow box(divider in the middle) and then attaching them to the ceiling in the back would work for me. The main focus for this was practicality and use of the wagons cargo space, and of course they had to be tucked up enough as not to obstruct my vision. I achieved all of this.
It ain't pretty by any means, but it works.
Hopefully this will inspire somebody with audio install skills to take this on and do it right.
Cheers,
Leivon
old 242
Leivon is offline   Reply With Quote
Old 07-07-2013, 11:48 AM   #2
Råda
Volvoretard/Partshoarder
Råda's Avatar
Neat idea, but I'd try to rotate them forward to the passengers
Jonas
Old 07-07-2013, 01:36 PM   #3
badvlvo
Bad for Babies
badvlvo's Avatar
It may make it louder in front, but you want to listen slightly off-axis. And the rear speakers being too bright will screw up the imaging.
If I were going about it that way I would leave them firing down.
Old 07-07-2013, 02:38 PM   #4
Funkee
Funkee's Avatar
thats where fader and balance come in
Old 07-07-2013, 02:49 PM   #5
Mueller
Mueller's Avatar
I like, while not being totally directional, I bet they still sound good.
Old 07-07-2013, 03:58 PM   #6
Leivon
The purpose was solely to get them off the floor in the back, withouth cutting the door cards, or tailgate. They really do sound great compared to: when they were in sealed boxes on the back shelf in my old 244; when they were unsealed in the back shelf holes of my 242, and when they were just recently in the larger volume boxes in the back of my 245(current car) facing either the front or towards the roof.
I really do just wish someone would do this properly with some nice components or a better set of 6x9's. The edge i drilled into is more than strong enough to hold the weight, and it just keeps things a lot cleaner back there.
Thanks for the replies so far, i'm enjoying the feedback.
Old 07-07-2013, 04:03 PM   #7
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
That's still pretty awesome man. Good idea.
Crazychopstick is offline   Reply With Quote
Old 07-07-2013, 05:12 PM   #8
Old Iron
I Roll
Old Iron's Avatar
Great idea, not even a little kid could sit in the third row seat now, but still neat idea, I always thought about cutting a hole in the wheel well panels, but this is a more clever idea.
Turbobricked
Old 07-07-2013, 11:53 PM   #9
badvlvo
Bad for Babies
badvlvo's Avatar
Still wont fix it if they don't fire the right direction.
Old 07-07-2013, 11:55 PM   #10
Matt
ICY HOT STUNTA
Matt's Avatar
its like a cherokee
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 07-07-2013, 11:57 PM   #11
Chance
1 throttle plate per cyl!
Chance's Avatar
Originally Posted by Matt View Post
its like a cherokee
This. Great idea man really like it
DD's
2010 Jeep Patriot
2015 Dodge Journey
Currently restoring:
'66 122s 2dr - B20 dual webers/M41
Projects:
'83 245 - SBC 388 stroker with Jenvey 45 ITB's
Chance is offline   Reply With Quote
Old 07-08-2013, 01:28 AM   #12
Jack
junkman
Jack's Avatar
good idea man
some suggestions - get a carriage bolt so that the nut wont rub the headliner
migh want try match the headliner arch instead of just a flat piece of wood
bottom line - good job
Make old cars great again
Old 07-18-2013, 01:13 AM   #13
swedishiron.com
I sell Volvo parts!
This company:
http://www.backesljud.se/
Used to make speaker boxes that sat above the rear wheel wells, so you didn't lose as much space in the cargo area.
Try searching internet archive to see some older pictures of the product(s) for ideas...
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 07-18-2013, 01:16 AM   #14
olov
doing something stupid
olov's Avatar
not bad
and about the direction, your rear door speakers/etc face forward? no they face 90* from the outside wall, this is no different
Old 07-18-2013, 08:54 AM   #15
Leivon
Originally Posted by olov View Post
not bad
although my reasoning for the direction was pure and unadulterated laziness, i was able to justify it for this very reason.
would someone just do this properly already.
Old 07-18-2013, 11:50 AM   #16
jpbturbo
Mens Classic Fit Polo
jpbturbo's Avatar
Frequency response changes as you get off axis.
A fancy EQ would be able to help get things relatively close in your seating position.
A car is a less than ideal listening environment anyway so it's probably not worth that much trouble.
Most of the time in a car the speakers are firing at the side of your legs so it's probably not much worse to have them behind your head in the ceiling.
If you wanted to get really nutty with making everything as accurate as possible I bet one of these would help: http://www.minidsp.com/
Originally Posted by Lord_Athlon
My kia is best kia appliance so cheap.. Oh ****
Originally Posted by Isaac
Ur A LIAR u dident maek 28 psi BOOURNZ!
jpbturbo is offline   Reply With Quote
Old 07-23-2013, 07:52 AM   #17
idrive_MD
nice go at it there sir! Just from reading the thread title for a second, I thought maybe someone got the idea to mount a Jeep Wrangler bar-speaker kit or something.
1989 Volvo DL Wagon, Auto Silver Exterior with Blue leather...auction find for $650! Build thread here
2004 G35 6MT Brembo Coupe, big fat wheels and tires with suspension and exhaust work.
2011 Kia Forte SX 5-door, 6spAuto loaded, the wife's car.
idrive_MD is offline   Reply With Quote
