Old 07-19-2013, 02:18 PM   #1
Belaruski76
Default 4 bar fpr...
I'm sure this has been covered somewhere but when I was researching this mod I didn't see many decent pics so...
http://i763.photobucket.com/albums/x...719_122939.jpg
Stock Volvo 3 bar fpr from my '95 940 on the left, 4 bar fpr from a Dodge Omni 2.2 turbo on the right. Bumps fuel rail pressure from 44psi to 55psi according to the specs. Car does seem a bit happier, I'm running stock everything else except 3" downpipe & exhaust and manual boost controller at 15psi.
Belaruski76 is offline   Reply With Quote
Old 07-19-2013, 02:42 PM   #2
Lord_Athlon
Just damn
Raising the pressure to 4 bar lowers the flow capacity of the fuel system. Did you need more fuel or was this just for fun?
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 07-19-2013, 02:58 PM   #3
propav8r
F*ck Edgar
propav8r's Avatar
First post is actually somewhat useful and contributory. I like this dude.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 07-19-2013, 03:09 PM   #4
Belaruski76
@ Athlon - This was done in anticipation of mods I hope to finish in the next two weeks. I've got a tdo4hl-16t and a 255lph Walbro pump sitting in my office that I hope to install soon. I also picked up an AEM wideband that will go in when I remake the end of the 3" downpipe to fit the dp flange for the new turbo, (I'll weld the extra o2 bung in then). Not a lot of pics yet but here's a link to the photobucket album of what I do have.
http://s763.photobucket.com/user/nlo...%20940%20turbo
Old 07-19-2013, 03:26 PM   #5
Lord_Athlon
Just damn
The only problem I see is that the pumps flow capacity is diminished as the pressure rises. If the wastegate is set for 15, that puts you at 70psi at the rail. Install the wideband and take a look at the numbers at full boost.
Old 07-19-2013, 03:56 PM   #6
jpbturbo
Mens Classic Fit Polo
jpbturbo's Avatar
4 bar is actually 58.something psi.
Part numbers,
BOSCH Part # 0280160260
AIRTEX / WELLS Part # 5G1075
BWD Part # 22823
Originally Posted by Lord_Athlon
My kia is best kia appliance so cheap.. Oh ****
Originally Posted by Isaac
Ur A LIAR u dident maek 28 psi BOOURNZ!
jpbturbo is offline   Reply With Quote
Old 07-19-2013, 04:44 PM   #7
Lord_Athlon
Just damn
True.
