Uncleknucklez
bruspeed
- Apr 15, 2006
- Sacramento, CA
Just finished installing my Quick Steer Roll Correctors this morning on my manual rack 240, they installed great, went with the middle hole for the tie rod.
Issue is after I set the car on the ground, it was obvious I was toed out a ton, started threading in to toe the car in, and after a minute I bottomed out the threads on the tie rods, and the car is still toed out an inch.
Did I do something wrong here? Is there different length tie rods? I’m at a loss.
Another issue is with 15” wheels and a normal offset, you can’t move the tie rods to the outside holes due to interference issues.
