Old 05-09-2018, 10:22 AM   #1
bartman
Default Cheap Wheel Ideas for Slicks
Looking forward to track days soon and was curious who has any thoughts on some cheapie steelies that would fit my 240. I plan to purchase the biggest street style slicks that will fit. Ideas ?
bartman is offline   Reply With Quote
Old 05-09-2018, 11:20 AM   #2
Pro Sneaker Peddler
What kind of slicks?
Old 05-09-2018, 11:22 AM   #3
Street style.
Old 05-09-2018, 11:23 AM   #4
Pro Sneaker Peddler
Street style.
Old 05-09-2018, 01:34 PM   #5
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Street style.
Track days or Drag Days? Two completely different things...
And really you want 15" alloys as they are much lighter for drag slicks
#79WDP
Old 05-09-2018, 03:35 PM   #6
Pro Sneaker Peddler
I'd get some Method 15x8-9s for track days, stick with the cheapest, widest wheel for drag slicks.
Old 05-09-2018, 07:18 PM   #7
sbabbs
sbabbs's Avatar
I got 8 inch wide M/T drag slicks on 7 inch wide 15 inch aftermarket aluminum wheels. Hard to find a stock aluminum 7 inch wide 15 inch wheel. I think the only ones are the 780 bertone wheels. 9 inch wide drag slicks don't fit on a 240 too well, but might with a big hammer or just the right offset.
Old 05-09-2018, 08:43 PM   #8
Pro Sneaker Peddler
Bmw wheels are cheap and easy to adapt. 15x7 and 15x8 available for next to nothing.
Old 05-10-2018, 09:43 AM   #9
bartman
Drags
Old 05-10-2018, 10:42 AM   #10
Pro Sneaker Peddler
Ok, get some e34 15x8s
Old 05-10-2018, 12:17 PM   #11
cosbySweater
cosbySweater's Avatar
Get cragar unique 83s, 40 bucks each from summit and they have the 5x108 and 5x114.3 bolt pattern I run them on my drag car
1982 Ford Fairmont Futura
1995 Porsche 993
Old 05-10-2018, 12:21 PM   #12
t8fanning
8v are still cool, right?
t8fanning's Avatar
Didn't a couple people put 24x8 ET Drags on MSWs or stock 740 steelies?
1982 242 Turbo.
Old 05-10-2018, 12:59 PM   #13
DMFWallace
Ignoramus Bigotus
Diamond Racing are cheap and you can spec out diameter, width, offset, and bolt pattern to suit whatever you've got. The SC series wheels are like $70 a piece or something.
I hear they don't make good street wheels but for a dedicated drag set I think they'd be cheap and functional.
Call em up and ask for a quote on some 15x8 or 15x10 with -12 offset and a 5x108 bolt pattern
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - For Sale?
'97 854R - Waiting to get fixed
'06 XC90 V8 - Family Hauler - Wifemobile
'04 XC70 - Impulse buy of the year
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 05-10-2018, 01:22 PM   #14
cwdodson88
In the same boat. Just started pricing out a multi purpose semi-slick or DOT legal road slick. 15x8 seems to have the most options for tires, but finding steelie 15s with adequate brake clearance is a giant pita.
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-10-2018, 01:56 PM   #15
cosbySweater
Old 05-10-2018, 02:08 PM   #16
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
60' 1.66
1/8 6.53 @ 113.3mph
1/4 9.99 @ 140.4mph
20psi 11.5deg timing E85
3140lb no driver
3320lb with driver
Old 05-11-2018, 09:16 AM   #17
roccodart440
A better idea than running slicks would be a sportsman pro. I've been running them for years. They are a drag slick compound, wrinkle wall design but with full tread. Cheater slicks aren't fun if you get so much as a sprinkle of rain.
roccodart440 is offline   Reply With Quote
Old 05-11-2018, 06:39 PM   #18
A tough rowing ho
I had some used Hoosier Cantilever 23.5"x10" designed to fit on a 6" rim. I think they were made for a Miata? I had an issue with them hitting the upper shock bolt at standard ride height but we're ok with it lowered after some wheel well hammering before I lifted it back up and ruined the sidewalls.
